Lift on 275/70/18 ?
Discussion in 'Suspension' started by lbcdan, Feb 18, 2018.
  1. Feb 18, 2018 at 9:14 PM
    lbcdan
    lbcdan [OP] Zip it up and zip it out
    Daniel
    Long Beach, CA
    2018 Toyota Tundra CrewMax 4x4
    Toytec Boss Coilovers, Total Chaos UCA, Icon 57720P Shocks, Toytec Shackles, TRD Off-Road Wheels, SpiderTrax Spacers, BakFlip MX4, Clazzio Seat Covers, Rough Country Light Bar, BajaDesigns Foglights
    I recently upgrade my stock tires to 275/70/18 Falken AT3 tires. I am looking for a lift in the 2" range. I am concerned about lifting too much will make the tires look tiny. I stay mainly on road but I do go camping from time to time and want to make sure whatever I install will be capable off road. What lift are you guys running on a 33" tire?
    12Kaihau1500 and NoRcptn like this.
  2. Feb 19, 2018 at 6:10 AM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
    I have those exact tires ready to install and will also be putting in billy 5100's on the 2nd notch.
  3. Feb 19, 2018 at 6:24 AM
    ToyotaTundraMike
    2015 Tundra
    Running 275/70/18 here with Bilstein 5100’s on middle setting. Plenty of pics in my build thread (link is in signature).
    May jump up to the 6112s later on and put at the 1.9” setting.
    SouthBoundSteve likes this.
  4. Feb 19, 2018 at 6:47 AM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    3/1 lowrange offroad wth 275/70/18 nitto ridge grapplers on a +20 offset wheel for reference
  5. Feb 19, 2018 at 6:51 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    20180119_131547.jpg BFG KO2, 275/70 18 with 3/2 lift.
  6. Feb 20, 2018 at 7:26 PM
    lbcdan
    Daniel
    Long Beach, CA
    Post up pictures when you are done! I am curious what it will look like with the 275s.
  7. Feb 20, 2018 at 7:35 PM
    lbcdan
    Daniel
    Long Beach, CA
    Will do. I am thinking the same thing. I may do the 5100s now to accomplish what I want, then upgrade to adjustable coil-overs later on. I can do 5100s on all 4 corners, 1" lift shackle, TRD rear sway bar, skid plate, and BajaDesigns fogs for the same cost as doing Toytec's ultimate lift kit.
  8. Feb 20, 2018 at 7:37 PM
    lbcdan
    Daniel
    Long Beach, CA
    Dang, a 3/2 doesnt make those tires look small at all. Do you have a link to that lift? How do you like it?
  9. Feb 20, 2018 at 7:37 PM
    lbcdan
    Daniel
    Long Beach, CA
    What lift are you running?
  10. Feb 20, 2018 at 7:46 PM
    Vendeta2k
    Jay
    Bozeman, Montana
  11. Feb 20, 2018 at 7:48 PM
    lbcdan
    Daniel
    Long Beach, CA
  12. Feb 20, 2018 at 8:56 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    Bilstein 6112s and 5160s 1.9 in the front and 1.5 in the rear. Bfg ko2 275/70r18
  13. Feb 21, 2018 at 2:41 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    It's blocks and spacers from the dealer, im guessing ReadyLift? It's ok, but I don't like all the negative that I've read about long term damage and effects it has on vehicle and suspension. It will be coming off the truck soon and will be for sale.
  14. Feb 21, 2018 at 8:47 AM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    Will do.
  15. Feb 21, 2018 at 6:31 PM
    jingjing
    jingjing New Member
    Burlington,KY
    2013 MGM Tundra DC Rock Warrior
    Stock rock warrior package with 18x9 18mm offset with 275/70/18 lt tires, no rub at all
  16. Feb 26, 2018 at 4:52 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    I ran that for the last 3.5 years with my stock wheels, and just replaced wheels and tires. Here are some pictures. I'm running a 2" moto fab spacer lift up front with 275/70/18.
    toyofan87, equin and (deleted member) like this.
  17. Feb 26, 2018 at 5:06 AM
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    Is the 1.9 setting on the 6112s the top setting?
  18. Feb 26, 2018 at 5:38 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    No, the top is 2.5
  19. Feb 26, 2018 at 5:54 AM
    benrichardson87
    benrichardson87 New Member
    Ben
    2014 Double-Cab SR5 Off-Road Silver
    I have the 5100 on middle setting, no lift in the rear just the upgraded shocks image.jpg with 275 70 18
  20. Feb 26, 2018 at 9:18 AM
    Kwikfish
    Tri cities,WA
    16 CM SSM
    Must be a reason i keep reading that everyone goes with the 1.9 then
    MDHinSD likes this.
  21. Feb 26, 2018 at 9:32 AM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    Get's the job done with less ride performance issues.
    MDHinSD likes this.
  22. Feb 26, 2018 at 11:39 AM
    lbcdan
    Daniel
    Long Beach, CA
    I think is what i am leaning towards, but I will add the Toytec 1" shackle in the rear since I have a 2018 with the TSS. Hopefully, the rake will prevent any sensor issues.
    MDHinSD likes this.
  23. Feb 26, 2018 at 11:40 AM
    lbcdan
    Daniel
    Long Beach, CA
    Looks good! I am still on the fence about the 6112 because they are not adjustable (with spanner wrench). I will probably do 5100 for now with adjustables in the future.
  24. Feb 26, 2018 at 2:22 PM
    TheBeast The Beach
    I'm going up to 295/70/18 (35 ish). The 33's were too small with 3/1
  25. Feb 27, 2018 at 7:22 AM
    benrichardson87
    Ben
    It sets about 3/4 inch lower in the front, which is what I wanted for when I haul and tow stuff. Next upgrade is an onboard air compressor and airbags for the rear.
  26. May 28, 2018 at 7:42 AM
    aztundraguy
    aztundraguy New Member
    2017 Tundra CM TRD Offroad
    6112/5160,Icon Billet UAC,Diff Drop,Billet .250 shim Lean Correction, CB Bump Stop Extensions, 275/70r18 w/ 18x9 +12 offset
    275/70/18 with a +12 offset AT3W (33.4”) no rubbing at full compression AF5B0744-CA4D-47B4-89D6-EF8D34FD8EDA.jpg
  27. Jul 17, 2018 at 8:28 PM
    WEAL
    WEAL 2018 CM SR5 4X4 SILVER
    2018 Silver SR5 4WD
    @lbcdan ... any rubbing with the 275/70 AT3W’s on stock suspension? Are they on stock rims as well. Want these tires bc of height, but dont want to level front at least in short term. Heard 285/65’s clear fine, but they’re not as tall. Appreciate any feedback
  28. Jul 17, 2018 at 9:17 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    Ever do yours? Post a pic!
  29. Jul 18, 2018 at 12:27 AM
    bowhun2r
    bowhun2r New Member
    Scott
    Steeler Nation
    275/70/18 KO2's with Method NV +20 offset and TRD-PRO suspension (which is just a 2" front level kit) stock height in rear.
  30. Jul 18, 2018 at 9:11 AM
    aztundraguy
    Picture posted, I had a Bilstein 6112’s with 275/70 and mud flaps no rubbing.
    equin likes this.
