Lift/leveling kit
Discussion in 'New Member Introductions' started by TundraGurl5.7, Nov 14, 2021.
  1. Nov 14, 2021 at 3:23 PM
    TundraGurl5.7
    TundraGurl5.7 [OP] New Member
    Jessica
    Toyota Tundra TRD
    None
    Hey everyone,
    I’m curious what everyone has done to their trucks to lift them. I have a 2011 Toyota Tundra TRD. I want at least a 3.5-4” lift so I can fit 33s (tires). My husband and I have read that the Trd is already lifted 2” factory. So I was looking at a leveling kit possibly 2” in the front 1” in the back. But not really sure what route to take. Anyone have any suggestions? Any type of brand?
    Thanks much!!
  2. Nov 14, 2021 at 3:35 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Official welcome for your first post... Plenty of valuable information under the Tundra Garage section in "suspension" where members been there, done that, with comments, feedback, brands, Budget, etc....most with wheels and tires combinations too. Good luck.
  3. Nov 14, 2021 at 3:40 PM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    Welcome from Western NC.
  4. Nov 14, 2021 at 4:06 PM
    Pmac
    Pmac New Member
    South of Portland, OR
    2019 CrewMax TRD Off-road
    Welcome. No expert here, but my stock CrewMax TRD OffRoad fit 33” tires without mods. Then I decided to take some rake out by lifting the front just under an inch with Bilstein 5100’s, and got rubbing on the skid plate. Installed a RCI skid two weeks later and no rubs. The truck looks level, but still has just over an inch of rake, perfect for light towing. Good luck!
  5. Nov 14, 2021 at 4:12 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Trd pro has factory 2" lift. Not the trd offroad. I'm running 33x12.50x18 on +12 offset no rubbing and no lift
  6. Nov 14, 2021 at 4:34 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  7. Nov 14, 2021 at 6:29 PM
    TundraGurl5.7
    Jessica
    Toyota Tundra TRD
    None
    Okay thank you. I thought we read that it did. Because I have the Trd rock warriors. I guess we didn’t realize all the differences in them.
  8. Nov 14, 2021 at 7:46 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
  9. Nov 14, 2021 at 10:08 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    I'm running 34's easily with 3 inches of lift up front. I have 1.5 inch lift in the rear, but that isn't necessary. But as others have mentioned, you should be able to run 33's without any lift.
  10. Nov 15, 2021 at 8:07 AM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    Only the TRD Pro is lifted 2".
    You don't need to do anything to fit 33s on your stock rims. Unless you want a lift for looks, it's best to keep it minimal. Even offroad, bigger tires (if you need ground clearance) and minimal lift works best.
    I have 325/65r18s (35x13) with 18x9 +25 offset wheels (stock is +60 so I'm 35mm more outboard), and no lift. It never rubs. Removed mudflaps moved plastic forward... also did the BMC, but it wasn't absolutely necessary. If you put 295/70r18s (34.4") or 285/75r18s (34.8") on stock rims you'll need to do little... definitely won't need the BMC. Moving the tires outboard as well as increasing the diameter, both take away clearance.
    A 2" lift is enough for 37s. Those look very good on a Tundra IMO.
    If you want/need a lift I'd recommend using struts that provide lift rather than spacers... especially if you go offroad.
  11. Nov 15, 2021 at 8:45 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    2017 Limited Crew TRD, Ironman Pros with JBA uppers. Prinsu rack. RSI, RCI sliders
    Eibach Pro kit Stage 1 and set it on the second clip for 3 inches of lift, done.
  12. Nov 15, 2021 at 11:50 AM
    Berdine
    Binghamton, NY
    You're lucky, those rock warrior wheels are worth gold in the toyota community
    WFD473 likes this.
  13. Nov 15, 2021 at 12:05 PM
    TundraGurl5.7
    Jessica
    Toyota Tundra TRD
    None
    Okay awesome. Thank you so much for all the info. I really want 33s. My husband wasn’t big on putting a lift on because we had so many issues with my Jeep’s lift. But that’s why we were looking into at least a leveling kit to lift the front end.
    rruff[QUOTED] likes this.
  14. Nov 15, 2021 at 12:06 PM
    TundraGurl5.7
    Jessica
    Toyota Tundra TRD
    None
    Yeah I don’t want to get rid of the wheels I just want a bigger tire and put the Trd wheels on the new tire.
  15. Nov 15, 2021 at 12:39 PM
    rruff
    rruff New Member
    The Rock Warrior models came stock with 285/70r17 tires which are 32.7"... technically already a 33. Is this the size you have? What size tires are you looking for? If you want bigger, you're looking in the 34" range. You still won't need a lift but will probably need some plastic manipulation.
    285/75 and 305/70 are both 33.8".
  16. Nov 15, 2021 at 2:27 PM
    TundraGurl5.7
    Jessica
    Toyota Tundra TRD
    None
    honestly I think I have 31s on it right now. I’ll have to look when I get off work tonight and let you know.
  17. Nov 15, 2021 at 4:40 PM
    TundraGurl5.7
    Jessica
    Toyota Tundra TRD
    None
    You are right I do already have 33s (285/70R17) on it right now. They don’t seem it. But they may be worn down.
    rruff likes this.
  18. Nov 15, 2021 at 6:02 PM
    rruff
    rruff New Member
    Tundras just look better with bigger tires. I put 35s on mine and immediately thought... "wish I'd gotten 37s"...
    I'm about 98% sure you can fit 315/70r17 (34.4x12) without a BMC... not that the body mount chop is a big deal. Should clear the inboard stuff too... those rims are 10mm further outboard than the other Tundra stock rims, so that will help. I am pretty sure you'll need to remove the mudflaps, and move the front of the plastic liner forward. Easy. Must be a thread about how to make clearance on here somewhere...
    It's a common misconception that a 2-3" lift gives you clearance, but it really doesn't for <35" tires. If you want to avoid rub even when your suspension is compressed and you are turning, you'll have to do the same mods anyway.
  19. Nov 15, 2021 at 6:07 PM
    TundraGurl5.7
    Jessica
    Toyota Tundra TRD
    None
    Yeah I definitely see what your saying. We have some looking up to do because neither one of us know a whole lot on Toyota’s. I was always a dodge girl when I was younger and my husband was always a Honda man so we’re both steering to different brands I definitely love my Toyota. I just want it a little higher. Haha. I’m trying to figure out how to post a pic on here to show you guys what it looks like now.
  20. Nov 15, 2021 at 6:09 PM
    TundraGurl5.7
    Jessica
    Toyota Tundra TRD
    None
    I still can’t believe I have 33s on there now. I swear when he looked at them a while back they were 31s. He can’t believe that it doesn’t have that 2” lift in it factory cause it does seem to sit high unless we’re just not used to the full size trucks
  21. Nov 15, 2021 at 6:29 PM
    weldit
    weldit New Member
    Van
    2021 tundra 4x4
    New
    The 2011 models must have bigger fender wells. I just bought a 2021 crewmax and installed a 3” toytech/bilstein kit, 17x9 0 offset fuel covert wheels with 315/70-17 toyo mt’s and had to do a body mount cut. My tires rubbed the body mount hard.
    Keep in mind not all tires are true to size. Just because it claims 33” doesn’t mean it’s actual 33”. Some tire companies have actual sizes/specs online.
  22. Nov 15, 2021 at 6:30 PM
    weldit
    weldit New Member
    Van
    2021 tundra 4x4
    New
  23. Nov 15, 2021 at 6:31 PM
    weldit
    weldit New Member
    Van
    2021 tundra 4x4
    New
  24. Nov 15, 2021 at 6:32 PM
    TundraGurl5.7
    Jessica
    Toyota Tundra TRD
    None
    I’m not sure if you can measure it this way but I know back when I bought it and was telling the hubby I wanted bigger tires I believed they measured with a tape measure from ground to top of tire and it was 31 in but you may be right. The ones on there may not be true to size
  25. Nov 15, 2021 at 6:33 PM
    weldit
    weldit New Member
    Van
    2021 tundra 4x4
    New
  26. Nov 15, 2021 at 6:35 PM
    TundraGurl5.7
    Jessica
    Toyota Tundra TRD
    None
  27. Nov 15, 2021 at 7:01 PM
    rruff
    rruff New Member
    Nah, yours and my 2016 are the same. Two reasons you needed a BMC. 1) 0mm offset is 60mm further outboard than normal stock. Thats over 2"... plus the rims are 1" wider. 2)The lift didn't gain you anything...
    That size tire on Rock Warrior rims clears much better.
  28. Nov 15, 2021 at 7:04 PM
    rruff
    rruff New Member
    The bottom of the tire is squished, so that is about right. Good looking truck!
