Lift kit
Discussion in 'Suspension' started by Jim LE 1301, Jul 16, 2018.
  1. Jul 16, 2018 at 5:10 PM
    Jim LE 1301 [OP] Camaro Lover, SSEM # 11,TTC#179
    Is this a good kit and worth $75 ?
    Not looking to go off road, just to give it a small lift and keep the factory 20" tires on for now.
  2. Jul 16, 2018 at 5:33 PM
    BannerLV
    BannerLV New Member
    2014 BRM Tundra 2wd TSS
    I've had this kit for about 3 months now. No complaints. Like you, I don't go off road and I'm also on the factory 20 inch wheels and off road tires. I had it aligned when it was initially installed and got it re-aligned about two weeks later on suggestion of the installer. No problems. I purchased mine through RC at $99 so you got a good discount, IMO.
    Black Wolf likes this.
  3. Jul 16, 2018 at 5:46 PM
    Any pictures?
  4. Jul 17, 2018 at 6:31 AM
  5. Jul 17, 2018 at 8:44 AM
  6. Jul 17, 2018 at 8:55 AM
    ToyotaTundraMike
    2015 Tundra
    There are much better options if you just want the truck to sit level and not spend a ton on a lift. Look at Bilstein/Toytec adjustable front shocks. They are a nice middle ground between spacers and coilovers. Plus you won't lose the wheel travel or have the awkard angles / premature wear on other components that come from spacer lifts.
  7. Jul 17, 2018 at 11:32 AM
    :thumbsup:
  8. Jul 17, 2018 at 11:39 AM
    I was thinking of this one first. And probably will.
    Guess the cheap price got me........lol
    HighDesertSurfer likes this.
  9. Jul 17, 2018 at 11:41 AM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    ToyTec's Eibach coil overs are affordably priced. I think up to 3" lift. Call ToyTec and ask for David. He can give you some decent options to consider.
  10. Jul 17, 2018 at 12:14 PM
  11. Jul 17, 2018 at 2:34 PM
    Mo_Martz
    Mo_Martz New Member
    Great Country of Texas
    2017 White Tundra CM
    So what's the major difference between the Toytec kit and the Readylift kit?
  12. Jul 17, 2018 at 2:40 PM
    ToyotaTundraMike
    2015 Tundra
    Toytec offers a variety of different lifts (spacers, adjustable shock, coil over). Not sure there is much of a difference if you are comparing spacer lifts but Toytecs will most certainly be of higher quality if you are set on going that route over a shock/coilover.
    4x4_Angel and Mo_Martz[QUOTED] like this.
