Lift Kit Options - 2019 Platinum CM 4X4
Discussion in 'Suspension' started by USAF_Tundra_Guy2019, Dec 26, 2018.
  1. Dec 26, 2018 at 12:46 PM
    USAF_Tundra_Guy2019
    USAF_Tundra_Guy2019 [OP] New Member
    2019 Platinum - MGM
    AMP steps- with more Mod's following
    Can anyone shed light on lift options and kits completed on 2019's. I've called both BDS and Pro-Comp, both stated they have yet to assess the 2019's to match up a lift kit. What is everyone else doing for their 2019.
    Thanks
    MJ_19Tundra likes this.
  2. Dec 27, 2018 at 5:15 PM
    MJ_19Tundra
    MJ_19Tundra Ain't nuthin but a G thang
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    Following!
  3. Dec 27, 2018 at 6:39 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    It's the same as the previous year, and the year before that......... The only difference, where one might encounter an issue, is with the TSS. However, lots of trucks with TSS have been successfully lifted.
  4. Dec 27, 2018 at 7:24 PM
    MJ_19Tundra
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    I have the TSS I believe....the safety package correct?
  5. Dec 27, 2018 at 7:31 PM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    I've done a couple 19's on the Pro Comp kits at the Nashville store. TSS doesn't take a hit. It does when you change the bumpers if you have BSM. But places like Fab Fours make positioning kits to get them back in spec. Look on you vin and see what the MFG date is and get back with me, I know some peeps at Pro Comp and Fabtech
  6. Dec 27, 2018 at 7:33 PM
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    Interesting. I was only aware of ICI Magnum making a BSM compatible rear bumper
    Hattori[QUOTED] likes this.
  7. Dec 27, 2018 at 7:36 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Fab Fours is looking to bring one to the table
    deedubb[QUOTED] likes this.
  8. Dec 27, 2018 at 7:37 PM
    It just needs to be level
    Stroke250, Vizsla and Black Wolf like this.
  9. Dec 27, 2018 at 7:39 PM
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    I can’t wait! Not big on the ICI one myself.
  10. Dec 27, 2018 at 7:43 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    I usually get to spend some good time with them at the off-road expo shows and truck fest venues. The problem is the positioning of how the sensor on the rear is mounted and the angle that its needs to read approaching objects. They got it figured out on the front but they're looking to see if they can make changes to the design of the rear to accommodate the sensor boxes.
  11. Dec 27, 2018 at 8:02 PM
    Vizsla
    Vizsla 2 = 2.5
    The TSS has to be recalibrated if you lift or it will be off. Toyota says no lift, so if you go it on your own and have TSS problems it may be out of pocket.
    There is no TSS sensor in the front bumper, the BSM/RCTA(not part of the TSS system) in the rear bumper has been the same since 2014. The positioning is easy, it is incorporating a big plastic panel in front of it that presents a design challenge, hence the ugly ICI BSM/RCTA bumper.
    831Tun likes this.
  12. Dec 27, 2018 at 8:33 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    I don't think I said there was a TSS sensor in the front bumper. However sometimes because of the style and make of the aftermarket front bumper especially those with pre-runner bar options they get in the way of the TSS sensor. As for the rear box BSM module, with these aftermarket rear bumpers you have to modify the end caps which will give you the space to use the BSM's. Last one I was able to do it on was a Go Rhino BR20 which we had to cut the plates out and fabricate it in.
    Nevertheless good info @Vizsla :thumbsup:
  13. Dec 27, 2018 at 9:15 PM
    Vizsla
    Vizsla 2 = 2.5
    Black Wolf and 831Tun like this.
  14. Dec 28, 2018 at 4:43 AM
    MJ_19Tundra
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    Vin number 10th digit is K....researched and that is 2019.
  15. Dec 28, 2018 at 4:53 AM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Nice! What's you plan with the truck? Or better yet, come by the store tomorrow or sometime and we can plan it out:thumbsup:
    Black Wolf likes this.
