Lift Kit: "cannot use oem 17 wheels"??
Discussion in 'Suspension' started by 1BadTundra, Mar 4, 2017.
  1. Mar 4, 2017 at 7:26 AM
    1BadTundra
    1BadTundra [OP] New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    I've been searching for an upgrade from my 2.5"-1" level kit to a lift. I was looking at a few and they all mention that OEM 17's will not work. Why is this? I have a Rock Warrior and wanted to retain my wheels if possible. Would spacers solve any fitment issue?
  2. Mar 4, 2017 at 8:12 AM
    Not sure how that would factor into the lift?
    What lift are you looking at?
  3. Mar 4, 2017 at 8:19 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    If the lift changes out the spindles (I.e, Procomp, RCX etc) then most likely the stock wheels will not work due to the lack of proper backspacing. Example: my stock 18s have a backspacing of 6.85", but my lift required 5" at a minimum (smaller pushes the wheel out)
    From what I understand, if you go with a lift that does NOT changes the spindles out, your stock wheels should be OK
  4. Mar 4, 2017 at 8:20 AM
    Bear
    Bear
    Custer, SD
    Spacers would solve this issue as well, but may affect any potential warranties on the lift. FYI
  5. Mar 4, 2017 at 10:22 AM
    1BadTundra
    Clinton
    Too Much to List
    I was looking at the fabtech, and RCX.
  6. Mar 4, 2017 at 11:24 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I have the same problem Clinton. I ordered a 3.5"/1" lift/leveling kit with new UCA's and according to the manufacture I need 6" of backspacing on my wheels. Well my stock 18's are at 6.8xx". So I'm screwed until I buy new wheels. For now and until I get my wheels I'm going to use Spidertrax wheel spacers to get my backspacing out far enough. Good luck with your lift and wheels.....
    1BadTundra[OP] likes this.
  7. Mar 4, 2017 at 11:30 AM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    It is generally because on the new spindle, they move the caliper mounts so that the calipers no longer clear the inside drum of the wheel. Some of does have to due with backspacing wheels.
    040Tundra and Bear like this.
  8. Mar 5, 2017 at 12:44 PM
    1BadTundra
    Clinton
    Too Much to List
    Well this sucks... I like the RW wheels, but really wanna lift
  9. Mar 6, 2017 at 8:52 PM
    Adam61484
    Adam61484 New Member
    2012 Toyota Tundra Rock Warrior
    Westin bull bar, readylift 3in. lift/leveling kit, 33in. tires on factory rock warrior rims
