Lift issues??
Discussion in 'Suspension' started by tgun, Apr 25, 2017.
  1. Apr 25, 2017 at 7:43 AM
    tgun
    tgun [OP] New Member
    Tom
    Northern Illinois
    2025 TRD Pro (Mudbatch)
    Decked 2.0, Wildpeak ATw 35x11.5x18 Class C, bed step, predator steps, Baja s8 amber light bar and S2 amber fogs
    i stopped by my local auto shop asking about installing a lift on 2017 tundra and I was told tundras have had some recall issues with transmission making noise after the angle of drive shaft was changed from installing lift. Anyone else have experience with this?
  2. Apr 25, 2017 at 8:35 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    First I've heard of it. The very first batch of Tundras in 2007 had some torque converter issues but those were all fixed on the spot. Over 50 percent of everyone in this forum have some sort of lift and I've never heard anyone with transmission issues.
    tgun[QUOTED][OP] likes this.
  3. Apr 25, 2017 at 8:50 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Never heard of it either. My lifted Tundra and my friends who have lifted Tundras haven't had issues.
    tgun[OP] likes this.
  4. Apr 25, 2017 at 8:51 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    @ColoradoTJ @csuviper have you guys ever heard of this? I'm relatively new to these trucks and don't want to pass bad info.
  5. Apr 25, 2017 at 8:55 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    Jsena and tgun[OP] like this.
  6. Apr 25, 2017 at 8:59 AM
    Depends on how high and if carrier bearing is dropped.
    TheBeast likes this.
  7. Apr 25, 2017 at 9:01 AM
    Not that I'm aware of. What shop was this?
  8. Apr 25, 2017 at 9:28 AM
    tgun
    Tom
    Northern Illinois
    Maximum automotive in Naperville il. I may have Toyota do the lift so I keep the warranty. Toyota said if someone else does it they warranty would be void. Rrrrrr
  9. Apr 25, 2017 at 9:33 AM
    What type of lift are we talking here?
  10. Apr 25, 2017 at 10:04 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I have not heard of this issue with the transmission noise.
    I have recently been getting some vibrations over the past few months but i believe it is all from my tires that are getting close to needed changed. Did a tire rotation and it helped out alot so i know its that and not what you are describing.
  11. Apr 25, 2017 at 12:51 PM
    tgun
    Tom
    Northern Illinois
    Hmmm maybe it was a fluke experience the body shop ran into.
  12. Dec 31, 2018 at 7:01 AM
    Dyna10
    Dyna10 New Member
    17 CM TRD SR5
    Did you end up getting a lift tgun? I’m having one installed in two weeks and just curious on your experience so far. By the way I’m in Bolingbrook and got my truck from Naperville.
  13. Dec 31, 2018 at 7:07 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    who is doing yours? Have you checked out ATTITUDE PERFORMANCE in Elk Grove ?
  14. Dec 31, 2018 at 7:49 AM
    Dyna10
    Dyna10 New Member
    17 CM TRD SR5
    Symbolic in Joliet is doing mine. I haven’t checked out Attitude.
  15. Dec 31, 2018 at 8:42 AM
    tgun
    Tom
    Northern Illinois
    I had a toytech suspension kit installed. No issues so far
  16. Dec 31, 2018 at 4:27 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    what do you have?
