License plate light Disable while In Reverse (DIR)
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by daveeasa, Oct 25, 2021.
Thread Status:
Not open for further replies.
  1. May 9, 2022 at 7:43 PM
    #91
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    Guilty!! My dad passed away a little over a year ago, so i decided to keep his car and use it for commuting. Much better gas mileage than my tundra!!
  2. Jul 24, 2022 at 12:03 PM
    #92
    Joe2019
    Joe2019 New Member
    Joe
    2019 Black Tundra Platinum
    Being an old car stereo guy, I knew I could do this on my own.... also, from being a car stereo guy-OEM connector integration and T harnesses are the way to go. Looking forward to this arriving and getting it installed!
    Thank you for your hard work in putting together a very professional (from what I can tell so far) product.
    daveeasa[OP] likes this.
  3. Jul 24, 2022 at 12:41 PM
    #93
    daveeasa
    daveeasa [OP] FBC Harness Solutions
    David
    FWIW, I gladly pay for plug and play myself even though I can build my own. Nice to start with something that works and then improve from there vs having to prioritize it and test before it’s usable. I got my first DIR built by puppypunter myself. I stalled a few days on the install, then when I went to do it I was impressed with how enjoyable it is as a mod, it's just barely enough work to feel like you did accomplished something by yourself.
    I've done the numbers a bit and I think it would be difficult to beat my price buying everything ala carte. The primary reason for that is the shipping across multiple suppliers, one for wire, one for tubing and heat shrink, one for connectors and terminals, one for relays w connector and tpa. Then there is assembly time and testing to add in as well, and with the license intercept connector specifically, it's much easier to secure the TPA when you have two connectors than when you have to do it with your hands, so if you buy just one you're possibly rolling around under the truck to get it locked in. All of this ignores tool costs, as I use 3 different crimpers and two different wire strippers since the milspec wire is beefier than TXL.
    So far I've helped one guy with a DIY for a 3G Tacoma and he had one mistake which he found and fixed. I think he spent significantly more money and took several hours. As it is for me, it's between 30-60 minutes of work start to finish depending on how fast I'm moving.
    Last bit, these are made to order and I'm a bit behind due to travel last week but I think all of the other orders are all items which I have already built so there's a decent chance yours gets done tonight, definitely something early this week.
    bulldog93 likes this.
  4. Jul 24, 2022 at 3:19 PM
    #94
    Joe2019
    Joe2019 New Member
    Joe
    Sounds great. Thank you so much. Keep up the great work!
  5. Jul 28, 2022 at 5:35 PM
    #95
    Joe2019
    Joe2019 New Member
    Joe
    Received today, installed today. Took about 20 minutes, would have taken less if I had read the instructions... its the harness inside the frame, not the super easy one! lol. Great work on the harness. Excellent quality, very excited! Thank you again!
    daveeasa[OP] and shifty` like this.
  6. Aug 7, 2022 at 1:27 PM
    #96
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Your website currently says that you are not accepting any new orders.
  7. Aug 7, 2022 at 2:16 PM
    #97
    daveeasa
    David
    I am moving right now. Will be back up once the move is complete.
    bulldog93[QUOTED] and shifty` like this.
  8. Aug 7, 2022 at 2:34 PM
    #98
    bulldog93
    Jeff
    Thanks for the info.
    Moving sucks! Good luck.
  9. Aug 26, 2022 at 9:22 AM
    #99
    SFTundra
    SFTundra New Member
    Jimmy
    Is it possible to order the harness or you are still moving?
  10. Aug 26, 2022 at 11:18 AM
    #100
    daveeasa
    David
    I’m still finishing the move but the store is open. I built one of these last night. Just please be patient, expect 2-3 weeks turnaround and I’ll try hard to beat that.
    AggiePhil and bulldog93 like this.
  11. Aug 26, 2022 at 12:37 PM
    #101
    SFTundra
    SFTundra New Member
    Jimmy
    Reason why I asked was that I tried to place an order but it gave error during checkout
  12. Aug 26, 2022 at 10:00 PM
    #102
    daveeasa
    David
    I think you got it through unless there are two Jimmy's interested in 2.5G Tundra DIR?
    I haven't built it yet though but you're #1 in line, I built everything up to yours.
  13. Aug 26, 2022 at 10:07 PM
    #103
    SFTundra
    SFTundra New Member
    Jimmy
    yeah it’s my order, it finally went through. Would be a coincidence if another Jimmy also wanted it the same time as me lol
    daveeasa[QUOTED][OP] likes this.
  14. Aug 31, 2022 at 8:00 PM
    #104
    bulldog93
    Jeff
    Installed it today. Nice and easy!
  15. Aug 31, 2022 at 8:41 PM
    #105
    SFTundra
    SFTundra New Member
    Jimmy
    you just take out one of your taillights to plug it in right?
  16. Aug 31, 2022 at 8:44 PM
    #106
    bulldog93
    Jeff
    One end goes between the passenger backup light and its plug. Then a Y-connector goes in line under your truck near the spare.
  17. Aug 31, 2022 at 9:16 PM
    #107
    SFTundra
    SFTundra New Member
    Jimmy
    ah ok thanks, I should be expecting mine in the mail in a few days.
  18. Aug 31, 2022 at 9:35 PM
    #108
    bulldog93
    Jeff
    Just read the directions a few times and you'll figure it out.
  19. Sep 3, 2022 at 7:26 AM
    #109
    daveeasa
    David
    IIRC on the Tundra you use the passenger taillight as it’s closer to the intercept. Thick zip tie is for mounting the relay in the taillight cavity. Hardest part is separating the 8 way connectors without getting dirt in your eyes.
  20. Sep 3, 2022 at 8:02 AM
    #110
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Has anyone done this on a second gen Sequoia?
  21. Sep 3, 2022 at 9:06 AM
    #111
    bulldog93
    Jeff
    The eight-way was a pain and I did get some dirt in my eyes.
  22. Sep 3, 2022 at 10:16 AM
    #112
    daveeasa
    David
    I assume the taillights are different and that there is some complexity as the harness would have to route into the vehicle through a grommet somewhere. We haven’t yet solved for 4Runner.
  23. Oct 26, 2022 at 5:16 PM
    #113
    daveeasa
    David
    Anyone with one of these able to get a rough estimate of the length from the license intercept to the hitch receiver? I’m doing my first Tundra w aux output and not certain how long to make it. TIA
  24. Jan 7, 2023 at 7:41 AM
    #114
    SwitchThrottle
    SwitchThrottle Living in Idiocracy
    2021 Barcelona CrewMax
  25. Jan 7, 2023 at 8:40 AM
    #115
    TXBrit
    TXBrit New Member
    Weatherford TX
    2019 MGM Platinum
    Installed mine a couple of days ago. Nice quality part, does what it says and an easy install.
    Can't ask for more than that.
    biebs96 and bulldog93 like this.
  26. Jan 7, 2023 at 8:52 AM
    #116
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Just ordered mine; moved to a new house with an inclined driveway and huge glares of the sun and moon while backing onto the driveway. The LED’s glare as well so hoping that disabling the lights will help somewhat
  27. Feb 11, 2023 at 5:17 AM
    #117
    Beerdude77
    Beerdude77 New Member
    2018 Silver Sky Tundra Limited TRD CM
    Linex bed, "Toyota" Console Safe
    Just ordered, this is genius! I've struggled with the rear camera since getting my 2018 new and even replacing the head unit with a HD Kenwood didn't help. I came on here looking for a solution after not being on the site in quite a while and as always someone came through! Thanks for developing this, I can't wait to install it. Now if someone can just invent a tiny windshield wiper for the backup camera or a cover to keep the rain off I'll be set!
  28. Feb 11, 2023 at 5:41 AM
    #118
    shawn474
    MoCo, Maryland
    I hope to install mine later today
  29. Feb 18, 2023 at 11:17 PM
    #119
    Redline870
    Redline870 New Member
    Ian
    Central NY
    2021 Super White TRD Pro
    Installed this tonight before I went to pick up the pizza, yes it’s that quick to install. Tried to take a picture in approximately the same spot. What a difference! This really used to bug me, seemed like a glaring oversight by Toyota, a single down facing light could have prevented this. The glare produced a lot of noise in the video feed. It’s perfect now. Super happy with this product!
  30. Feb 19, 2023 at 9:05 AM
    #120
    shawn474
    MoCo, Maryland
    Just installed mine; works like a charm. Always happy to support a fellow member who brings useful quality mods to us
Thread Status:
