Leveling?
Discussion in 'Suspension' started by Angelslure, Aug 17, 2018.
  1. Aug 17, 2018 at 4:17 AM
    Angelslure
    Angelslure [OP] NOT A DUDES TUNDRA
    Stephanie
    Virginia Beach
    Super White 2018 Tundra CrewMax 4WD 5.7L
    Leveling 3”/1”, Tint, Tires 285/75/18, LED strip in hood bulge, changed all interior and exterior lighting to LED, Remote Start, Interior foot well LED lighting, Linex spray bed liner, Chrome and Black step bars
    Ok, i love my ride in my 18’ Crewmax, however I am scheduled to have a level installed tonight...Honestly, will this mess up my ride at all? A little? A lot?
  2. Aug 17, 2018 at 4:58 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Leveled with spacers? If so it will have a harsher ride due to preload on the coilspring. Nothing wrong with a spacer lift unless you do heavy offroading.
  3. Aug 17, 2018 at 12:55 PM
    Angelslure
    Stephanie
    Virginia Beach
    All I know is 3” front 1” rear...then I have to probably get an alignment
  4. Aug 17, 2018 at 1:43 PM
    Nm6300'asl
    2022 DC SR5 4x4
    Alignment for sure, probably spacers up front and a block under leafs in rear. It will be fine as long as no hardcore offroad, speedbumps and potholes a bit harsher with factory size tires but with a 3-1 lift you will prob be getting bigger tires soon. Post some pics after the lift.
    Angelslure[OP] likes this.
  5. Aug 17, 2018 at 1:45 PM
    Nm6300'asl
    2022 DC SR5 4x4
    Btw, super white is the best color!
  6. Aug 17, 2018 at 1:52 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Harsher ride will only be if the spacer is in the coilover assembly. There are 2 types: either coil spring spacer that is mounted in the coil over assembly, and will have a harsher ride due to preloading the spring, or a strut extension, which mounts on top of the strut to just make it a little taller. This will not significantly change the ride. Most leveling spacers are the latter.
    mattyd170 and Angelslure[OP] like this.
  7. Aug 17, 2018 at 1:54 PM
    Boerseun
    Ferdie
    Sarasota Florida
    Agreed on the alignment afterwards.
  8. Aug 17, 2018 at 2:30 PM
    Angelslure
    Stephanie
    Virginia Beach
    Yaaasy good to know
  9. Aug 17, 2018 at 2:41 PM
    15whtrd
    15whtrd Mr. Blonde
    Either way sounds like she needs to extend her bump stops if you don’t want to ruin the shock over speedbump‘s LOL
  10. Aug 17, 2018 at 2:49 PM
    Nm6300'asl
    2022 DC SR5 4x4
    Meh, anytime you extend the coilover by whatever means you will end up with a harsher ride, same reason most guys dont do the full lift on the 6112 bilsteins (i did). Not trying to argue, just want to be realistic.
    Now if you soften spring rates and valveing maybe, but then will that be adequate for the increase in tire weight (from most likely e rated tires) in a size that will fit the lift. Didnt even mention the loss in down travel, care to discuss more?
    Op will have a fine truck.
  11. Aug 17, 2018 at 4:09 PM
    Angelslure
    Stephanie
    Virginia Beach
    Hey thanks you guys for helping...I really do appreciate it...i will post pics before and after tomorrow...the guy who is doing it has a tundra as well and seems as though he knows what he’s doing...his truck looked pretty tough...I’m so excited...and yes I’m pricing tires...I was told I would and I have the itch already...so I’ll prob sell the originals since they only have about 200 miles on them...that will help offset the cost of the new ones...I hope at least a little...:fingerscrossed:
    15whtrd likes this.
