Leveling with Bilsteins - spring for springs? Input Requested
Discussion in 'Suspension' started by Bloomjtundra, Apr 29, 2020.
  1. Apr 29, 2020 at 8:26 AM
    Bloomjtundra
    Bloomjtundra [OP] New Member
    Josh
    2011 Tundra DC 4x4
    I'm going to level my 2011 SR5 4x4 with Bilstein's either 5100 or 6112. Debating middle setting on the 5100's or the 1.3 or 1.9 on 6112's. No lift in the rear, will use 5100's.
    The truck has under 29,000 miles on it and has never been offroad. I do not need the added performance of the 6112 as this truck will mainly be on pavement (95%+). Is it worth the expense to go 6112 to end up with new springs or are my springs perfectly fine? Bottom line, does it make sense to put on fresh springs at 9 years old and 29,000 miles or is that likely a waste of money?
  2. Apr 29, 2020 at 8:28 AM
    degs
    degs New Member
    2020 MGM Crewmax
    I'd do it. I found a set of assembled 6112's and 5100's for $799 delivered.
  3. Apr 29, 2020 at 8:35 AM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    Your springs should be perfectly fine. The coils can take a beating and many more miles. But the 6112s are pretty sweet and a bit beefier. If you really don’t drive the truck much, I’d get the 6112 shocks and enjoy them for the next 9 years and never have a second thought.
  4. Apr 29, 2020 at 8:40 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    At 29k your truck is darn near brand new. If your coils are in good shape and you don't need the performance of the 6112's, the 5100's are the more economical way to go. That said, if I found the deal that @degs found I would pull the trigger on the 6112's. FWIW, I'm on 5100's, middle setting, mine is a pavement queen and I'm perfectly satisfied with the look and the ride.
    Bloomjtundra [OP] and degs like this.
  5. Apr 29, 2020 at 8:41 AM
    Bloomjtundra
    Josh
    2011 Tundra DC 4x4
    Thanks! It looks like it’s $450 vs $900 for both options with 5100’s in the rear. If I can do better, I’m listening...
  6. Apr 29, 2020 at 8:43 AM
    Bloomjtundra
    Josh
    2011 Tundra DC 4x4
    that’s a deal. Were they assembled?
  7. Apr 29, 2020 at 8:45 AM
    degs
    degs New Member
    2020 MGM Crewmax
    yes. sorry, I wrote built, should say assembled. (edit made)
  8. Apr 29, 2020 at 8:51 AM
    Rngr188
    Rngr188 New Member
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Boss Offroad has 6112 assembled for $699.99 and 5100 rears for $89.99 each so yea $900 is about where you will be. Consider that if you do ever trade your Tundra for one that is pre 4th gen the 6112's assembled can be removed and your stock assembled can be replaced then just switch the 6112's into the newer truck, no dealing with coilover assembly/disassembly.
    glowblue and SC_TRD like this.
  9. Apr 29, 2020 at 8:53 AM
    SC_TRD
    Colin
    Round Rock, Tx
    Best deal I could find as well. And a good point!
  10. Apr 29, 2020 at 8:54 AM
    SC_TRD
    Colin
    Round Rock, Tx
  11. Apr 29, 2020 at 8:56 AM
    degs
    degs New Member
    2020 MGM Crewmax
    check shox dot com. give them a call actually and see what deal they can give you
  12. Apr 29, 2020 at 9:13 AM
    Bloomjtundra
    Josh
    2011 Tundra DC 4x4
    That's a good deal. Would I need anything else to put them on? Have you ever used that vendor?
    Will do.
    Boss gave me the best price I've seen until this Amazon. Would like to support them but this is a good bit less...
    So it seems that the opinion is that my springs are probably just fine but paying up for 6112's would be cool if I'm willing to pay up.
    SC_TRD likes this.
  13. Apr 29, 2020 at 9:18 AM
    SC_TRD
    Colin
    Round Rock, Tx
    I actually bought this same 5100 set-up from Amazon the last time they had it priced like this late last year. It was fulfilled by the same Vendor then too, Trends Auto. I got my shipment super quick and with no issues.
    Only thing needed is to deconstruct your old coilovers and use a spring compressor to put the coil in. Kind of a hassle and scary at times depending on your spring compressor used.
  14. Apr 29, 2020 at 9:24 AM
    Bloomjtundra
    Josh
    2011 Tundra DC 4x4
    Thanks for the info, good to know you've used that vendor.
    I found an article where they did the swap without a spring compressor. They used a jack under the LCA and loosened the preload nut, then lowered the jack. Not sure which way feels more comfortable. I've never done a shock change on anything.
  15. Apr 29, 2020 at 9:36 AM
    Bloomjtundra
    Josh
    2011 Tundra DC 4x4
    Do you have any driver side lean issues? Do I need to mess with a diff drop. I've read tons of posts here, so many conflicting opinions on both. How long have you had this setup on the truck?
  16. Apr 29, 2020 at 9:41 AM
    SC_TRD
    Colin
    Round Rock, Tx
    Definitely don’t need the diff drop, especially if you are going with the lift heights mentioned above under 2”. Don’t waste the time and or money.
    Bloomjtundra [OP] likes this.
  17. Apr 29, 2020 at 9:48 AM
    Rngr188
    Rngr188 New Member
    Chad
    Harrison AR
    I wouldn't recommend that, lots of pressure on the spring. There's only one right way to do it.
  18. Apr 29, 2020 at 9:52 AM
    Bloomjtundra
    Josh
    2011 Tundra DC 4x4
    Do I need any new bushings? The Amazon reviews have a lot of people saying they ended up buying new bushings for front and rear...?
  19. Apr 29, 2020 at 10:00 AM
    SC_TRD
    Colin
    Round Rock, Tx
    I didn’t need anything when I purchased. And once again your suspension is really barely worn in, while taking original front coilovers apart you could take the top hat bushings if needed, but kit should include all brand new bushings.
  20. Apr 29, 2020 at 11:04 AM
    duece292
    Greg
    Green Bay, WI
    I don't have the driver's side lean and didn't prior to leveling it. You can measure or put a level across your bumper to see if and how much yours might lean. A Coachbuilder shim will remedy the lean if you have it. Anything under 2.5 to 2.75 inches doesn't require a diff drop. I've had this setup for about 2 1/2 years now.
  21. May 11, 2020 at 2:01 AM
    Bloomjtundra
    Josh
    2011 Tundra DC 4x4
    All done! 5100s on all 4 corners. Got it done yesterday. No major hiccups. Followed the info shared here and YouTube. Very helpful! Thanks for all of the input.
    AlaskanAssassin, SC_TRD and duece292 like this.
  22. May 11, 2020 at 8:44 AM
    SC_TRD
    Colin
    Round Rock, Tx
    Sweet, I am glad it worked out!
