Leveling Question + TRD Sway Bar question
Discussion in 'Suspension' started by ToyotaTundraMike, Jan 4, 2016.
  1. Jan 4, 2016 at 9:55 AM
    ToyotaTundraMike
    ToyotaTundraMike [OP] Not A New Member
    2015 Tundra
    Hey guys, I don't know too much about lifts and leveling, but I would like to level out my 15 Double Cab about 2" in the front. (Don't want the 3/1 because I'm afraid it may look a little too small when I only put 33" tires with it)
    What is the best way to give it the extra 2" up front that I want? I have read that adding some front shocks such as Bilsteins will accomplish this, but would I need to add anything else with them to prevent extra wear on other parts of the truck? I don't do much offroading (only the dirt roads that lead to my hunting lease).
    What would my best option be?
    Also wondering about the TRD Sway bar. I know absolutely nothing about them, but have seen many great reviews. Are they only for 4x4 trucks or can I put it on my 2WD?
  2. Jan 4, 2016 at 10:10 AM
    Nit2wn
    Nit2wn New Member
    James
    Alabama
    2013 Crewmax TRD 4wd
    Honestly, I called around for a few weeks at different offroad places before I went back to the dealer. I wanted a level look or just slightly higher in the back. I ended up with a 2.5'' toytec lift in the front end and love it. I just wanted to run a little bigger mud tire on the stock rims.
    12250076_1246017518757790_85682491429647_0970aa9adc84c0ce1cfc833c36da5bc78e97f658.jpg
  3. Jan 4, 2016 at 10:46 AM
    PlatPro
    PlatPro New Member
    Randall
    A silk gloved hand with brass knuckles underneath.
    2014 Platinum, TRD Pro Suspension , Truxedo Bed Cover, Vent Shade Rain Guards, Tint match windows,TRD Exhaust, Linex, Custom Dyno Tune, TRD SwayBar, and just started.
    I have the TRD Pro suspension on my Platinum. 275/60R/20 ( 33/10.5/20) fit with no trimming or rub. I could have squeezed 34s but would have needed some modding. I also stayed with the 33 because I often tow 8-9K pounds and didn't want to trash my gear ratio. Leveled out, 33 fill/ fit nice.
  4. Jan 4, 2016 at 10:59 AM
    cfdfireman90
    cfdfireman90 New Member
    Cory
    Southern NH
    2015 Tundra Limited/TRD Double cab
    Just did exactly what you are talking about yesterday. I bought a 2" front strut spacer on E-bay for a little over $40. It goes between the strut and the strut mount. Therefore it doesn't add pre-load to the strut and maintains the stock ride quality. See pictures.
  5. Jan 4, 2016 at 10:59 AM
    ToyotaTundraMike
    2015 Tundra
    Thanks for the info. Looks good! How does it ride compared to stock? I am wondering if I need one of the coilover kits or if I could just get the Bilstein 5100 front shocks and use my stock coilovers? Would save me around $600, but what benefits would I lose compared to one of the kits?
    Nice, thanks for the info I will be on the lookout for a good deal on craigslist for the TRD suspension. I imagine the dealer is pretty proud of it.
  6. Jan 4, 2016 at 11:04 AM
    ToyotaTundraMike
    2015 Tundra
    Nice, good looking truck! Never thought about doing that, but I kind of want to upgrade the stock shocks either way since some of the dirt roads I go down on the weekends are pretty rough.
  7. Jan 4, 2016 at 1:26 PM
    Is that a bolt on top spacer lift?
    Bolt on top spacers can explode like a grenade
    jlee likes this.
  8. Jan 4, 2016 at 1:39 PM
    cfdfireman90
    Cory
    Southern NH
    I agree with that if you use a spacer that goes between the spring and the top mounting plate of the strut. Which is what looks like happened in the picture. I used one that goes between the top mounting plate of the strut and the strut mount attached to the frame. It is billet aluminum that is machined. What is picured is no more likely to happen with my spacer than without.
  9. Jan 4, 2016 at 2:28 PM
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    Oh it is still likely to happen unless you extended your bump stops as well to limit the up travel. As soon as you bottom out that shock that was designed for the stock wheel travel "SNAP" go's the shaft on the bottom. Top plate spacers will still cause a total failure of the shock if the bump stops are not extended.
    MotoTundra likes this.
  10. Jan 5, 2016 at 12:44 AM
    Nit2wn
    Nit2wn New Member
    James
    Alabama
    Rides like it did before the lift. If you like the factory ride but want it to sit almost level, I'd recommend it. Toytec is a sponsor here so if you want to do it yourself just buybthe kit, but you will need a front end alignment.
  11. Jan 5, 2016 at 6:29 AM
    ToyotaTundraMike
    2015 Tundra
    Thanks for the info everyone, could I get away with just some shocks (such as bilsteins) with my stock coils or should I definitely buy one of the kits instead such as the ToyTec BOSS or regular ToyTec?
  12. Jan 5, 2016 at 6:46 AM
    TruckLife900
    TruckLife900 I'd rather B hunting
    2013 White SR5
    save up and do it right... buy once cry once.
    MotoTundra and Virgils12 like this.
  13. Jan 5, 2016 at 6:54 AM
    ToyotaTundraMike
    2015 Tundra
    I hear ya, might as well. Just seems like a lot of $ for my truck to sit level. Is it recommended to add new UCA's at the same time as one of these coilover kits or can I get away without them if I'm only sitting at 2-2.5" higher than stock?
  14. Jan 5, 2016 at 8:27 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  15. Jan 5, 2016 at 8:29 AM
    csuviper
    Broomfield, CO
    I have the Toytec Ultimate Lift kit and @Sean266 has the Boss Lift Kit with new coilovers and rear 1" block. Both are good and ride is probably very similar between the two. Price is a bit higher but gives you the 3/1 lift vs just a ~2" lift in the front.
  16. Jan 5, 2016 at 9:31 AM
    I have a 2" block in the rear.
  17. Jan 5, 2016 at 9:39 AM
    csuviper
    Broomfield, CO
    I think you are set higher on your front coilovers. I just got the standard 1" block.
  18. Jan 5, 2016 at 10:03 AM
    Yep
  19. Jan 5, 2016 at 10:33 AM
    ToyotaTundraMike
    2015 Tundra
    Awesome, thats what I was looking for. May upgrade in the future to the BOSS but for now I just want a level ride and room for 33's to fit comfortably. Thanks for the info guys! Anyone running this setup? Would like to hear some opinions on it vs stock.
    Is there anything I need to add with this setup to prevent extra wear on other parts? Not sure how the extra 2.5 inches up front will effect other components.
    Also how easy is TRD sway bar install?
  20. Jan 5, 2016 at 10:34 AM
    I haven't ran that exact setup, but it'll be a better ride than stock from what I've heard and read.
  21. Jan 5, 2016 at 11:01 AM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    You will not regret the money spent for this setup. Well worth $100 over any bracket or spacer lift. This will ride and handle better than any of the cheaper alternatives. My buddy has this same setup on his and it works well for the money. As far as the sway bar goes I'm sure it can't be to hard to put on. Only time will tell as I'm looking to putting one on my rig very soon. :anonymous:
  22. Jan 6, 2016 at 1:52 PM
    csuviper
    Broomfield, CO
  23. Jan 7, 2016 at 7:49 AM
    ToyotaTundraMike
    2015 Tundra
    Nice almost forgot about that. I am thinking of starting with the bilstein kit that you posted, waiting to hear back on details from a local craigslist find. Guy posted a "pro comp 2.5 leveling kit for 07 and up tundra" for less than 100 bucks. Says he bought it an ran it for a while and upgraded to old man emu.
  24. Jan 7, 2016 at 8:18 AM
    I dont have any personal experience but from everything I've heard I would not go with this.
  25. Jan 7, 2016 at 11:55 AM
    ToyotaTundraMike
    2015 Tundra
    Okay thanks. Not sure what his kit includes since he quit responding but I will take your word for it and get the bilstein kit until I can upgrade to the boss setup.
    T-Rex266[QUOTED] likes this.
