Leveling kits in San Diego or Escondido?
Discussion in 'California' started by yotagabe, Jan 17, 2015.
  1. Jan 17, 2015 at 3:19 PM
    yotagabe
    yotagabe [OP] New Member
    gabriel
    2014 white toyota tundra
    Need to know some good sites or stores around San Diego or Escondido that sell great leveling kits please and thanks! Recommendation: 2.5 or 3.0 or 3.5
  2. Jan 17, 2015 at 4:36 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    The leveling kits are a great cheaper way to get the lift for our trucks. But there are some negatives to be had with them also. With the lift it does change the camber of the truck. So without a upper control arm specific to the lift to fix the camber issue your gonna have premature wear on balljoints and tires. Imo you are better in the long run to save pennies and get a good quality lift. The ride of a quality lift is well worth what they cost. Again this is my opinion. Lol
    Bob likes this.
  3. Jan 17, 2015 at 6:04 PM
    scratchex
    scratchex New Member
    2015 Tundra Limited
    3" lift TRD Exhaust 20" Fuel Lethal Wheels Toyo AT Tires Black Flares w/ spikes
    You could try http://www.4wheelparts.com/ I've been pleased with my recent experiences with them. I believe there's one in San Diego.
  4. Jan 17, 2015 at 6:28 PM
    yotagabe
    gabriel
    Thank you I will look into the upper control arm I didn't know that.
  5. Jan 17, 2015 at 6:28 PM
    yotagabe
    gabriel
    Thank you ..I will check it out!
  6. Jan 24, 2015 at 9:35 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I run the 3/1 toytec ultimate lift with stock upper control arms. No problem getting alignment in spec when the lift was installed. Haven't got an alignment since.
    UCA are a good idea but not crucial unless you go above 3" or the alignment shop can't get within specs.
