Leveling Kit
Discussion in 'Suspension' started by jaredmillerdvm, Mar 19, 2018.
  1. Mar 19, 2018 at 12:03 PM
    jaredmillerdvm
    jaredmillerdvm [OP] Mods will never end!!
    Anderson, SC
    2018 MGM CM SR5 TRD Off Road 4x4
    Rough Country 3in leveling kit, SCS Ray 10s, 295/70/18 Toyo Open Country AT2 Extremes. TRD Shift Knob, Console Safe, Driver Side Grab Handle, WeatherTech Laser Measured Floor Liners, Katzkin Heated Leather Seats, Remote Start, TundraTex Frac Harness, Radio Vinyl Inlays, LED Interior Lightening. MGM Color Matched Hood Bulge and Surround, 18% Tinted Front Windows, 90% Ceramic Windshield Tint, 5% Banner, AntennaMast Stubby Antenna, Predator Step Bars, Skid Plate with Integrated Step, Line-X Spray in Bed Liner, Blacked Out Badges, Mirrors and Door Handles, Black Bedside Decals, Bak Revolver X2 Tonneau Cover, Swing Case Tool Boxes, DIY Tailgate Lock, Deck Rail System, Recon Smoked LED Tail Lights With LED Reverse Lights, Smoked Vinyl Wrapped Cargo Light, LED License Plate, Cargo, and 3rd Brake Lights, Dirty Deeds 8" BAMuffler, Black Powder Coated Front and Rear Bumpers, TRD Rear Sway Bar.
    Has anyone notice that one side of their truck is higher than the other? I recently had a leveling kit installed and the passenger side of my truck is higher in the front then the rear however on the driver side it’s a 1/2 inch higher in the rear. I’m not sure if there was a height difference before leveling kit. Is this normal? 2018 sr5 TRD off road CM.
  2. Mar 19, 2018 at 1:14 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Yup, it’s normal. It’s because the gas tank is on the drivers side under the bed.
  3. Mar 20, 2018 at 1:46 PM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    I would double check your measurements, we have seen the driver side side about 1/2'' lower in some cases. As @zcarpenter92 stated the gas tank will naturally pull the driver side down.
    The best way to take your measurements are center of wheel hub to edge of fender, take those measurements and post them up here and I will see what we can do to help you out!
    Thanks
    -David
  4. Mar 20, 2018 at 1:47 PM
    Toytec Lifts
    Denver, CO.
    Thanks
    -David
