Leveling kit or?
Discussion in 'Suspension' started by Erick, Apr 10, 2018.
  1. Apr 10, 2018 at 8:09 PM
    Erick
    Erick [OP] New Member
    Erick
    Thornton Colorado.
    Bronze 2016 SR5 TRD. CM cab.
    HID lights, Duratracs, Bilstein 5100's, 2" Spacer, Sumo springs.
    Well, I got a leveling kit over a year ago, needless to say, I had no idea that I needed an alignment after it was done. I told myself that I'd get my leveling kit installed after I get some new tires. Well, new tire time has come. Got a set of duratracs
    I got my new tires and took truck to get the kit installed and my tires aligned. The tech quoted me over the phone it would cost 550. After I went into the shop they said that it'll cost me 900. I asked why the change, they said it'll take 6 to 8 hours to install. I walked
    I called another places they also quoted me 550 over the phone, I went in, they wanted 790 after they seen it. They said that it's hard to install and it might take all day.
    I called the 1800 tech support number on the leveling kit, the phone tech told me I should be looking at 200 to 400 max to install spacers. He said it should take a experienced tech 2 hours to install or 4 hours for a DIY person.
    I called the 1800 number again, the tech asked me of I had the trd off road package, I said yes, he then told me that I can only get a 2 inch spacer in the front, max. The tech said I should send the 3 inch spacer in and have it swapped for the 2 inch spacer.
    Now my question is... should I get some bilstein 5100 and max them on the front and back and toss the leveling kit, or should I swap the 3 inch spacers for the 2 inch spacers?
    If I wanted to keep the 3 inch spacers, what kind of shocks would I need to buy?
    I want the front lifted as much as possible.
    I'm only looking to spend around 700
    I found a guy that'll do it for 300. I got his number after the manager left.
    Here's the kit I ordered.
    3 inch front and 2 inch rear.
    https://supremesuspensions.com/prod...p-4wd-4x4?rq=yr_2016~mk_toyota~md_tundra&vari
  2. Apr 10, 2018 at 8:17 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Welcome from AZ. Get rid of the spacers you will be much better off doing the 5100 or nicer coil over
    GODZILLA and Eclipsed & Floating like this.
  3. Apr 10, 2018 at 8:21 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Welcome from CA
  4. Apr 10, 2018 at 8:22 PM
    A decent tech can do spacers in 2 hours. Spacers such as Procomp, for example. In coil spacers take a bit longer.
    Bilisteins are a great option and you can set it as you’d like on the clip. If you wanted it level, you can do 3/1.
  5. Apr 10, 2018 at 8:24 PM
    Erick
    Erick
    Thornton Colorado.
    Okay, if I go with this option, what shocks should I go with? 2 of each of these? Or another better option for around the same price?
    https://www.amazon.com/gp/aw/d/B00IL8BMUU/ref=ox_sc_act_image_2?smid=A2TW9P
    https://www.amazon.com/gp/aw/d/B00IL8BMUU/ref=ox_sc_act_image_2?smid=A2TW9PAD7D7YND&psc=1
    What's the best way to unload the spacers? Ebay? Haha.
  6. Apr 10, 2018 at 8:26 PM
    Tundramoney
    Tundramoney Old school
    Earth
  7. Apr 10, 2018 at 8:26 PM
    Erick
    Erick
    Thornton Colorado.
    Thanks for the detailed reply, what shocks exactly do you recommend? Thanks. I agree, I'm sure it'll take more than 2 hours.
  8. Apr 10, 2018 at 8:27 PM
    Erick
    Erick
    Thornton Colorado.
    I see the trend. I had no idea. I don't off road or anything of the sort, maybe a few jobs a year in the mountains, that's about it.
  9. Apr 10, 2018 at 8:33 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Make sure they fit your year of truck.
  10. Apr 10, 2018 at 8:34 PM
    Rica25
    Ricardo
    Tulare
    I have 5100s on for about 6 months now and 1 inch rear lift.....they will ride better than just doing the lift....i have front at highest setting
  11. Apr 10, 2018 at 8:34 PM
    Do you wheel or just want daily comfort?
    The 6112 is a great option too, but are more of a performance shock and may not be rebuildable.
  12. Apr 10, 2018 at 8:35 PM
    Which would be 3” so pretty much level with the 1” in the rear
  13. Apr 10, 2018 at 8:37 PM
    Rica25
    Ricardo
    Tulare
    Mine actually has a rake with that set up
  14. Apr 10, 2018 at 8:38 PM
    Hmmm. I thought 3/1 would be leveled.
  15. Apr 10, 2018 at 8:39 PM
    NCinCO and Eclipsed & Floating like this.
  16. Apr 10, 2018 at 8:40 PM
    Rica25
    Ricardo
    Tulare
  17. Apr 10, 2018 at 8:44 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Eclipsed & Floating and T-Rex266 like this.
  18. Apr 10, 2018 at 8:45 PM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    Welcome. I started the same way - bought spacers and then returned them and bought 5100's for all corners. I set mine in the middle with 1 coachbuilder shim on each side for a total lift of 2" in front. I did not lift the back and I am level. Bilstein 6112's at the 3rd highest setting will get you ~1.9" of lift too.
  19. Apr 10, 2018 at 8:48 PM
    6112 can get ~2.55” max.
    One
    sr5shark[QUOTED] likes this.
  20. Apr 10, 2018 at 8:50 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    Right - sorry was not clear. Top setting will get you to ~2.55".
    T-Rex266[QUOTED] likes this.
  21. Apr 10, 2018 at 8:52 PM
    Rica25
    Ricardo
    Tulare
    Just measured the drivers side on mine it's 39 and 40.5 rear
  22. Apr 10, 2018 at 8:53 PM
    I’ll get you stock measurements tomorrow if you’d like.
  23. Apr 10, 2018 at 8:55 PM
    Rica25
    Ricardo
    Tulare
    Was just wandering those measurements also .....thanks
  24. Apr 10, 2018 at 8:56 PM
    Rica25
    Ricardo
    Tulare
    Is that good measurements for that lift ?
  25. Apr 10, 2018 at 9:04 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    These are my stock measurements (2016 sr5 4x4 w/ TRD):
    LF 37 1/8
    RF 37 1/4
    LR 39 1/4
    RR 39 3/8
  26. Apr 10, 2018 at 9:08 PM
    I’ll get you the factory measurements in the morning.
  27. Apr 10, 2018 at 9:15 PM
    Rica25
    Ricardo
    Tulare
    Sounds about right
  28. Apr 10, 2018 at 10:08 PM
    Erick
    Erick
    Thornton Colorado.
    Awesome guys. Okay, so I'll need the 5100's
    2
    Bilstein 24-232173 5100
    2
    Bilstein 24186971 5100
    Will these fit my 16 SR5 TRD? Amazon said they will, but I'd rather ask you guys.
    Is there anything else I may need? Total price. "Subtotal (4 items): $351.38"
    I really like the kit that T-rex posted. But, it said that the exhaust will need to be modified. I don't know how much that'll cost.
    I seen you're from Colorado. Who do you recommend for a install? (if you don't mind sharing.)
  29. Apr 11, 2018 at 5:44 AM
    Rica25
    Ricardo
    Tulare
    The rear shocks are easy to install the fronts are not bad they take some time but then need to be aligned
  30. Apr 11, 2018 at 6:15 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    I think the tech was getting the TRD PRO and TRD Off Road mixed up. The TRD Off Road (which is what i have) can be leveled. The TRD PRO, with the upgraded reservoir suspension, cannot for some reason get the typical 3/1 level kits. Toyota put in my 3/1 ready lift for $350 with alignment.
