Leveling kit made front too high
Discussion in 'Suspension' started by Fox Mulder, Mar 13, 2025.
  1. Mar 20, 2025 at 4:06 AM
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    If that is the case I would definitely not expect the truck to sit higher in the front after a spacer install such as an RC 1.75” setup.
    caboj likes this.
  2. Mar 20, 2025 at 2:00 PM
    Fox Mulder
    Fox Mulder [OP] New Member
    2022 Supersonic Red 1794 Hybrid TRD OR
    I agree, makes me think something was botched on the install. Once it warms up here in MI a bit, I’m going to try loosening everything up on the ground and then re-torquing it. Probably have to have an alignment done afterwards.
  3. Mar 20, 2025 at 2:38 PM
    SilveradoSwap
    If you are going to do that it may be worth it to remove one of the towers and see what exactly is going on. Having the front higher would bother me for sure.
  4. Mar 20, 2025 at 4:03 PM
    Fox Mulder
    Yeah, I think you’re right, then I could see what’s up with the spacer, and see if the hat has the bolts cut off or not.
    SilveradoSwap likes this.
  5. Mar 21, 2025 at 3:00 PM
    GoHuskers
    GoHuskers New Member
    Nebraska
    '24 iForceMax, '17 RX350, '15 GX460
    When I measured my hybrid the difference between front and rear is less than what people reported for the non-hybrid, hence, installing the 1.75" spacer would make the hybrid front higher than the rear while installing that same spacer on the non hybrid would make it level
  6. Mar 21, 2025 at 5:27 PM
    SilveradoSwap
    Cant keep up. One person says the hybrid is lower, you say differently, lol
  7. Mar 22, 2025 at 6:38 AM
    Fox Mulder
    Same person actually, lol.
  8. Mar 22, 2025 at 6:40 AM
    Fox Mulder
    In your first post you said hybrids have a lower front, here it looks like you’re saying either the front is higher, or the rear is lower?
  9. Mar 22, 2025 at 9:25 AM
    GoHuskers
    Nebraska
    It sucks typing on the phone....
    What I meant is the DIFFERENCE between front vs rear for the hybrid is less than the non-hybrid; therfore, installing a 1.75" spacer which levels the non-hybrid will make the front of the hybrid higher than its rear.
  10. Mar 22, 2025 at 1:51 PM
    Fox Mulder
    Ahh, that does make sense, and seems to be the situation I'm in. Thanks for clarifying!
