Leveling kit for truck
Discussion in 'Suspension' started by Hammerhead9813, May 16, 2017.
  1. May 16, 2017 at 6:53 PM
    Hammerhead9813
    Hammerhead9813 [OP] New Member
    2011 Blue Tundra Tex Edition
    I have a 2011 2x4 Tundra quad cab. Put new tires on and want to put a leveling kit. New to this and not sure whether to buy one online or take truck in and have a place put what they have in stock. What should I look for in purchasing kit and what labor should run?
  2. May 16, 2017 at 6:57 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I'd get shocks over spacers.
    Bilsteins are good shocks but only go up to 2.5" of lift in front. Toytec BOSS is adjustable from 1" to 3.5"
    Trust me, with spacers, you'll feel every single bump up to your teeth.
  3. May 16, 2017 at 9:04 PM
    Depends on what you do with your truck lots of off roading heavy mild light pavement queen? Stay away from spacer kit its really stiff n rough check out toytec.com boss kit
    T-Rex266 and Law323 like this.
  4. May 16, 2017 at 9:05 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    You've got even more options with a 2x. You can replace the front spindles and get lift that way. I don't know anything about it though. @dragos28 would know more.
    dragos28 likes this.
  5. May 17, 2017 at 4:42 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    I have bilstein 5100's at the middle setting (1.57"). this still leaves a slight rake. I had 4 wheel parts install it and it ran about $500 for installing the shocks, mounting and balancing, and the alignment. as others have said, stay away from spacers. the 5100's are the next least expensive option. i am extremely happy with the way it turned out. you can check out my build thread for pictures:
    https://www.tundras.com/threads/netmonkeys-build-thread.11976/
    Law323 likes this.
  6. May 17, 2017 at 7:18 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    What are you ultimately trying to do? Just level out the front end or lift and level the whole truck?
    -David
    Law323 and T-Rex266 like this.
  7. May 17, 2017 at 8:01 AM
    chphilo
    chphilo Tundra addict
    Western PA
    It sounds like you have purchased the tires already? What size did you go with? The amount of lift you want to get will depend on the size of the tire. Bilstein 5100 is nice since you could adjust how much lift you get. I agree with the above opinion that you should avoid spacer leveling kit.
  8. May 17, 2017 at 9:13 PM
    dragos28
    dragos28 New Member
    dragos
    tundra
    nothing much
    i first started out with a spacer leveling kit. pro comp.
    used the stock coil overs. TBH, the ride was the same as before. if you are just going for looks, spacers are ok. but dont take it off road, they will fail you.
    and on that note, i do have a set of procomp 3" spacers that have been sitting around for quite a while, maybe i'll sell them. PM me.
    rons23 likes this.
  9. Jun 8, 2017 at 11:53 AM
    dmeneses1983
    dmeneses1983 New Member
    Dennis
    2016 Silver Tundra
    I'm running a 4" toytec spacer in the front and a 2" rear block. I like the stance, labor cost roughly $700 which includes an alignment
  10. Jun 18, 2017 at 8:42 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
  11. Jun 18, 2017 at 11:31 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    sub'd, since I'm in the same boat.........just put on new tires and would eventually like to level out the front.
