Leveling 22 Platinum with AVS/Air
Discussion in '3rd Gen Tundras (2022+)' started by 2bak, Dec 22, 2021.
  1. Oct 17, 2022 at 5:57 PM
    #241
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    There is a rather lengthy (8 hour) TSS alignment needed after forking with the height on these trucks. I don't use any of these and haven't seen the error codes (yet). When I finish the rear I'll have the dealership do it. That time isn't based on a quote. It's based on the tech, who does them, telling me about it.
  2. Oct 17, 2022 at 6:01 PM
    #242
    gnc1017
    gnc1017 New Member
    22 Tundra Platinum Hybrid 6.5 Blueprint
    1.75 leveling kit Nitto Ridge Grappler tires (305/55/20) Black Rhino Arches Gunmetal wheels Truxedo Deuce cover w/ TonneauMate box
    Thought that too but double -checked everything we can think of as possible and can't find anything. The connections at the top of the shocks were unplugged but are definitely plugged back in with the keeper covers reinstalled too.
    Thanks for confirming yours is fine. Looking for those confirmations this should work fine with the leveling kit.
  3. Oct 17, 2022 at 6:06 PM
    #243
    gnc1017
    gnc1017 New Member
    Seems that is what they are going through. If that's what's needed, it is what it is. However, is mine the only one that's needed? And if the fix, will be curious as to why. That would result in huge implications on modifying the suspensions if the possible need for that step, especially for as minor as a 1.75 leveling kit.
  4. Oct 17, 2022 at 6:09 PM
    #244
    Jkwolfe09
    Jkwolfe09 New Member
    Jerren
    Should be fixable with a simple alignment. Is your steering wheel slightly off in anyway?
  5. Oct 17, 2022 at 6:12 PM
    #245
    bigblue14
    Craig
    I had an alignment and don't have the errors. I was told I still need to do the TSS alignment for things like that adaptive cruise control, etc... I've only driven about 10 miles so far since picking it up. I don't use a lot of TSS features so maybe that's why I haven't seen the codes.
    gnc1017 likes this.
  6. Oct 17, 2022 at 6:14 PM
    #246
    Jkwolfe09
    Jerren
    I never got any codes at all after leveling mine. I took it to Toyota and had them do the alignment. Wonder what’s going on
    gnc1017 likes this.
  7. Oct 17, 2022 at 6:16 PM
    #247
    gnc1017
    gnc1017 New Member
    Initially thought that too. 2 alignments have now been done (independent shop first but didn't fix alerts), hence the trip to the dealer and they did alignment too.
  8. Oct 17, 2022 at 6:18 PM
    #248
    gnc1017
    gnc1017 New Member
    Hoping yours is good (and it should be). I got the codes without even using the TSS features.
  9. Oct 17, 2022 at 6:18 PM
    #249
    Jkwolfe09
    Jerren
    And the dealer has no solution or what?
  10. Oct 17, 2022 at 6:19 PM
    #250
    gnc1017
    gnc1017 New Member
    Thanks for another confirmation. Do you have air/AVS too?
  11. Oct 17, 2022 at 6:23 PM
    #251
    Jkwolfe09
    Jerren
    Yeah I have a 1794 with avs and air on a Rc leveling kit I even have the afe air bag levers.
    gnc1017[QUOTED] likes this.
  12. Oct 17, 2022 at 6:23 PM
    #252
    gnc1017
    gnc1017 New Member
    Right now they are going through the TSS calibration. Other than that they mentioned disabling the systems if I want to keep the leveling kit. Of course not an option to disable and shocked the service writer even mentioned that. Sure hoping the tech isn't thinking that or might need to engage a new dealer...
  13. Oct 17, 2022 at 6:24 PM
    #253
    gnc1017
    gnc1017 New Member
    Thanks!!!
  14. Oct 17, 2022 at 6:47 PM
    #254
    Jkwolfe09
    Jerren
    I’d go to a different shop. They don’t seem very capable lol
  15. Oct 17, 2022 at 7:00 PM
    #255
    bigblue14
    Craig
    Weird feedback @gnc1017 hopefully it's not a crazy fix. Not having the avs was one of my two big worries with putting on the trd lift but so far so good.
    gnc1017 likes this.
  16. Oct 17, 2022 at 7:03 PM
    #256
    gnc1017
    gnc1017 New Member
    Reserving judgement until it's fixed of course. I'll post back the solution, whether from this shop or another.
    Appreciate all the help and information! These trucks are complicated and of course new too so we all benefit from sharing data as we work through the initial pains.
    From all the data from this forum, thought the leveling kit install would be a simple upgrade by now but with my luck, not so much for me...
  17. Oct 18, 2022 at 6:26 PM
    #257
    gnc1017
    gnc1017 New Member
    Got the truck back from the dealer today. They said they had 3 TSS sensors that had to be recalibrated to get the alerts and lights to go away. They still blamed it on the leveling kit. I questioned it as the only factor that caused the issue as I've never heard of a single other Tundra that needed sensor recalibration after a leveling or lift kit was installed. While admittedly new, there are tons out there that have been raised and not a single mention that I'm aware of, especially with mine being such a recent build and one of the very last labeled as a '22.
    I'd also be curious to know if the Toyota 3" lift instructions make any mention of possible recalibration being needed.
    Can't help but wonder if my factory calibration was on the edge of specs and the leveling kit tripped it over. Will never know but will be curious if anyone else runs into this also. Hopefully just mine.
    In the end, they only charged me $170 for the recalibration so it could have been worse. And more glad than anything that they got it fixed.
    eddiefromcali likes this.
  18. Oct 18, 2022 at 7:36 PM
    #258
    ziznack
    ziznack New Member
    Texas Y'all
    2024 Lunar Rock Platinum
    Cool thanks. That is exactly the set up I want to do on my 1794. I was hoping to still have about an inch of rake just so it doesn't look squatty at all. When you did yours, you didn't have any issue with the sensors? Did you install the RC yourself or take it somewhere?
  19. Oct 19, 2022 at 4:30 AM
    #259
    gnc1017
    gnc1017 New Member
    I was the one who had the issue with the sensors that needed recalibrated. Still no idea why and looks to have been an isolated situation.
    I did the install myself. Pretty easy for me as I have a 2 post lift and have done these before.
  20. Oct 19, 2022 at 5:08 AM
    #260
    bigblue14
    Craig
    Yeah I think you're theory about being on the edge is plausible. Glad to hear it's fixed.
  21. Oct 19, 2022 at 11:58 AM
    #261
    Chris083
    Chris083 New Member
    2022 Gray Tundra SR5
  22. Oct 19, 2022 at 1:23 PM
    #262
    bigblue14
    Craig
  23. Oct 19, 2022 at 2:11 PM
    #263
    JALBA
    JALBA New Member
    with the fabricated lever, can you still raise the back when you use the Hi switch? How did you reset the new ride height?
  24. Oct 19, 2022 at 2:41 PM
    #264
    gnc1017
    gnc1017 New Member
    Yes. The adjustment of the arms sets the N height and Hi and Lo still work off of that new N reference point/driving height (which all of these go to above 18mph). So my new H level is ~2-3" taller than it was before I put the extension brackets on (and so is the new L level - taller than before).
  25. Oct 19, 2022 at 2:54 PM
    #265
    Tundranewcomer
    Tundranewcomer New Member
    ‘22 MBM Platinum w/ power running board and advanced package
    Sorry this is off topic, but what is the point of the H setting. I get that the L setting makes it easier to load the bed of the truck with stuff but what is H good for?
  26. Oct 19, 2022 at 3:14 PM
    #266
    JALBA
    JALBA New Member
    H is good for if you need higher clearance. (not going over 18 MPH).
  27. Oct 19, 2022 at 3:37 PM
    #267
    Tundranewcomer
    It seems like 18 is a little low for setting back to N. Wish that was more like 25.
  28. Oct 19, 2022 at 6:10 PM
    #268
    bigblue14
    Craig
    @gnc1017 do you have measurements on the arms you made? The TRD life looks like 3-4+ on my truck (yes I forgot stock measurements). I want a backup plan for the AFE arms.
  29. Oct 19, 2022 at 7:21 PM
    #269
    JALBA
    JALBA New Member
    You could sell your fabricated arm since AFE arms are all on back order for 4 weeks minimum
  30. Oct 19, 2022 at 10:21 PM
    #270
    HeyMcFly
    HeyMcFly New Member
    2022 Tundra Platinum
    How much did this end up costing you? How does it ride?
