Leveling 22 Platinum with AVS/Air
Discussion in '3rd Gen Tundras (2022+)' started by 2bak, Dec 22, 2021.
  1. Oct 20, 2022 at 3:55 AM
    #271
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    I haven't seen the final bill yet. I'll let you know. My price probably won't be a good barometer because this dealership is my wife's business.
  2. Oct 20, 2022 at 5:04 AM
    #272
    gnc1017
    gnc1017 New Member
    22 Tundra Platinum Hybrid 6.5 Blueprint
    1.75 leveling kit Nitto Ridge Grappler tires (305/55/20) Black Rhino Arches Gunmetal wheels Truxedo Deuce cover w/ TonneauMate box
    Sorry, I don't. Hopefully you can get an idea from my pic. Note that I put a small slot in the new bracket too, which could have been made larger. And because the two bolts that fasten it to the factory arm (2 used to prevent it from rotating) are in the factory slot, if you use small enough hardware, you can get a little adjustment from that too if needed.PXL_20221015_005549344.jpg PXL_20221015_005554985.jpg
    bigblue14[QUOTED] likes this.
  3. Oct 20, 2022 at 5:08 AM
    #273
    gnc1017
    gnc1017 New Member
    It crossed my mind. This is such a simple little plate. Seems that it could maybe be made with a water jet and powdercoated in volume fairly easily. Not sure why AFE has these on such a backorder. Hopefully they're not outsourcing them from China.
  4. Oct 20, 2022 at 5:48 AM
    #274
    bigblue14
    Craig
    Mine are supposed to show up Monday. They're laser cut 304 which still isn't that hard to do.
    gnc1017[QUOTED] likes this.
  5. Oct 22, 2022 at 1:09 PM
    #275
    Odithtfg747
    Odithtfg747 New Member
    2022 SR5
    Just an update that I had the dealer adjust this. Factor spec per the TSB is 35mm to 45mm and the dealer said mine was just barely at 35mm so they adjusted up for me. Seems like Toyota needs spec to be higher because where I was at, the L setting had the bump stops touching the metal.
    All in all, it rides better now but if I really hit a bump I’m still bottoming out. Not sure I’m super happy with the rear air suspension TBH
  6. Oct 22, 2022 at 1:26 PM
    #276
    bigblue14
    Craig
    Crank the rear neutral height arms up and you'll be happier.
  7. Oct 22, 2022 at 2:33 PM
    #277
    Tundranewcomer
    Tundranewcomer New Member
    ‘22 MBM Platinum w/ power running board and advanced package
    I’ve got mine all the way up and still hit the bump stops coming off speed humps. I’m going at what I would say is a pretty slow speed for hitting the bump stops.
  8. Oct 22, 2022 at 2:54 PM
    #278
    bigblue14
    Craig
    Mine are adjusted all the way up, with bigger tires, and it's much better.
  9. Oct 22, 2022 at 5:44 PM
    #279
    Jcwelch111
    Jcwelch111 New Member
    Jimmy
    Chattanooga, TN
    2022 Platinum 4x4 CrewMax 6.5ft Bed
    Forgive me if this has already been answered (I've searched for few hours and not found a definitive answer). Has anyone had PTCCY-34000 successfully installed on a '22 Platinum with AVS and Rear Height Control Air Suspension? If so, I'd love to hear your experience with it. Thanks in advance.
  10. Oct 22, 2022 at 7:50 PM
    #280
    Odithtfg747
    2022 SR5
    I’ll check how much further I have on the adjustment arms tomorrow once it stops raining, but my general worry is that the rear will get loose at speed. I wouldn’t think they spec the max 45mm height for no reason. I also went a size up in tire so am running 275/70/18. Not a bad ride just weird that a bump in the road can cause me to bottom out
  11. Oct 22, 2022 at 8:01 PM
    #281
    bigblue14
    Craig
    Why would your rear get loose at speed by adjusting this?
    Abraham5G likes this.
  12. Oct 23, 2022 at 1:45 PM
    #282
    bigblue14
    Craig
    I have this combo but you'll need some additional parts. You'll need strut mount washers from a SR5. The AVS mounts slightly differently. Also you'll need different arms to adjust the rear bags. You won't quite get enough height out of the stock arms. I have AFE arms on order. If that doesn't get me where I want I'll make a custom arm.
  13. Oct 23, 2022 at 3:56 PM
    #283
    Jcwelch111
    Jimmy
    Chattanooga, TN
    Frustrating that Toyota doesn’t make compatibility easy to find. Sounds like the kit isn’t complete for AVS + rear air trucks. Head scratcher. Compatibility is like Product Development 101.
  14. Oct 23, 2022 at 4:52 PM
    #284
    bigblue14
    Craig
    I'm pretty sure they say it's not compatible. We learned as we went. I can get you those front mount part numbers this week if you're interested.
  15. Oct 23, 2022 at 5:00 PM
    #285
    Jcwelch111
    Jimmy
    Chattanooga, TN
    Thank you. Yes, appreciate it.
  16. Oct 24, 2022 at 10:03 AM
    #286
    Cheddafry
    Cheddafry New Member
    2022 Tundra Limited Crewmax
    @bigblue14 did the TRD kit come with replacement rear shocks by chance?
    My line of thinking for those of us with rear air bags...is that we have the option to swap out the front end with better components (TRD, Icon, King, Radflow, etc) but the rear focus is only centered on the position of the arms. Why not also upgrade the shock in the rear? Either with something slightly longer to accommodate the lift via the arms (and thus not maxing out the shock travel) and/or to simply just provide stronger/better components. I understand most trucks with air in the rear are not going to run the baja 500 but for those that do the occasional off-roading it could provide beneficial, right?
  17. Oct 24, 2022 at 10:14 AM
    #287
    bigblue14
    Craig
    I have the rear TRD shocks on but also need to get my stock ones back. I think they'll handle the height. I'm going to figure out which one I like the best.
  18. Oct 24, 2022 at 10:37 AM
    #288
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    It will be super interesting to see if the air suspension can even keep up with what a king/icon shock can do
  19. Oct 24, 2022 at 10:45 AM
    #289
    Cheddafry
    ah so it did some with something for the rear, interesting and good to know.
  20. Oct 24, 2022 at 10:45 AM
    #290
    Cheddafry
    i doubt it can but there are still shocks in the rear so replacing those would help, in theory.
  21. Oct 24, 2022 at 2:43 PM
    #291
    bigblue14
    Craig
    Got my aftermarket arms - did some cad'in. I'm doing a print this week to confirm some dimensions. Then once I swap out the stockers, I'll cad them up to confirm my dimension, [arc radius and notch positions]. If I don't like the final height I'm going to make my own. Yes this is a lot of effort but this topic annoys me...
    eddiefromcali likes this.
  22. Oct 24, 2022 at 4:07 PM
    #292
    gnc1017
    gnc1017 New Member
    Keep us posted. Interested to hear your results as well.
  23. Oct 24, 2022 at 5:16 PM
    #293
    JALBA
    JALBA New Member
    Did you receive yours from AFE yet? How was the fit and did it increase your new height? I'm still waiting on mine going on 21 days now.
  24. Oct 24, 2022 at 5:21 PM
    #294
    bigblue14
    Craig
    Post #291 my friend ^^^
  25. Oct 24, 2022 at 11:05 PM
    #295
    DimaA
    DimaA New Member
    Dmitriy
    WA
    2022 toyota tundra platinum
    K&N air filter. Front windows tint, RC front leveling kit.
    I also adjusted arms on my platinum ant it raised back of my truck 2in. Drives much better now then it was before.
    Carolina Peej and gnc1017 like this.
  26. Oct 25, 2022 at 9:14 AM
    #296
    John Reed
    John Reed New Member
    Oregon
    2022 Tundra Platinum
    I would be in for the PN as well. I am going to pull the trigger on the TRD kit for my Platinum with air/AVS. Did you get any warning lights from the AVS shocks being unplugged? And on the rear you just did the TRD shocks and then just modified the position sensor link? I have Westcott links here that I haven't used yet.
  27. Oct 25, 2022 at 3:26 PM
    #297
    bigblue14
    Craig
    No warning lights (so far) from removing AVS.
  28. Oct 26, 2022 at 6:12 AM
    #298
    Jibber82
    Jibber82 New Member
    Ok just picked up my Platinum Hybrid yesterday. Is there a consensus here on the "best" option for lifting the AVS/air trucks? I just want to retain the factory ride quality as much as possible and fit 35" Toyo AT3's on the stock platinum rims. Should I just get the Westcott AVS front and rear kit or is there a better option?
  29. Oct 26, 2022 at 6:22 AM
    #299
    Breathing Borla
    AZ
    its going to be tough to maintain the stock AVS ride (which is supposed to be the best stock set-up for that) when adding a spacer lift and 35 load E tires.
    what do you need that large of tires for, just looks? maybe drive around for a while stock and see if you really want that after you get to have the truck for a while.
    just a thought
  30. Oct 26, 2022 at 6:29 AM
    #300
    Jibber82
    Jibber82 New Member
    I can't stand the tiny stock tires look. Coming from a lifted (OME) 2017 Tacoma with 33" tires. I'd sacrifice some ride quality for larger tires. What about Falken Wildpeak AT3's? They are same size as the Toyo's but load range D, not E. I ran Wildpeaks on my Tacoma and loved them.
