Level Kit vs Bilstein Front Shocks?
Discussion in 'Suspension' started by jay131866, Feb 1, 2017.
  1. Nov 8, 2018 at 7:19 AM
    #91
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    I have a 3/1 readylift kit and i take my truck on dirt roads in the mountains and it does just fine. People always bad mouth spacer kits but if used in the situations it was made for, it works great. It's not meant for rock crawling. The situations where people show busted coilovers and say "this is why you don't get spacer level kits" is just cases where people use their spacer kits in scenarios they shouldn't. My two cents.
    Zoren Tundra likes this.
  2. Nov 8, 2018 at 5:47 PM
    #92
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    Hi everyone..I read this from beginning to end and I'm still confused. I have a 2017 Sr dc 2wd. I have Firestone air springs to correct sagging during towing. I need to keep 5lbs of air and that raises the truck and I'm fine with it. I want to go 305/50/20 rims and tires. I don't off road maybe a dirt path at a camp ground. I like comfortable ride. what is the minimum I need to do to get those tires in? I'm new to truck lifts.
    Dgjman likes this.
  3. Nov 10, 2018 at 8:35 AM
    #93
    Zoren Tundra
    Zoren Tundra New Member
    Eric
    2012 TRD off road 4x4
    Guys I have a ready lift 3/2 on my truck running OeM Bilstein off road shocks.
    Off course the ride is firm but it’s something I can tolerate, had it for 2 years so far it served me well.
    My question if I remove my lift kit and just go for a 6112 at front at highest setting and OME shocks at the rear with 3+ shackles. To give me the ride height I wanted would the change all worth the money and give me a more comfortable ride?
    I guess Im contemplating of spending about 1.5K for the suspension change with a doubt of not havng a significant night and day change in the comfort level.
    Has anyone here have done a lift kit and removed it then did a straight up adjustable struts like the 6112 set up with shackles at the rear?
    Thank you for your opinions.
  4. Nov 26, 2018 at 8:27 AM
    #94
    tomwithatundra
    tomwithatundra .
    2018 Tundra SR5 Cement
    5100’s middle setting, +18 offset, BFG At2’s 275/65/18
    This site helped me a ton when trying to decide what to add to my truck, so I thought I'd post a few pics for others to reference..
    before -
    After -
    Hunter Ultra 18x9, 18mm offset. BFG KO2's
    Bilstein 5100s all around, front on middle setting. Ride is way smoother than my worn out factory struts/shocks. Really want to tint the front windows, I guess the cops are pretty strict in NY about it though.. image3.jpg
  5. Nov 27, 2018 at 7:38 AM
    #95
    Texbirdhunter
    Texbirdhunter New Member
    2018 Double Cab 4x4
    Thanks for all the post on leveling with the Bilstein 5100. I just ordered the set from 4 wheel parts $338 delivered. My local shop quoted me $258 For install and balance.
    Dgjman and jeffw6236 like this.
  6. Nov 27, 2018 at 7:14 PM
    #96
    Pigglet222
    Pigglet222 New Member
    So you will use your factory front coil springs?
  7. Nov 27, 2018 at 9:10 PM
    #97
    bmcdds
    bmcdds New Member
    CA
    2019 Barcelona Platinum
    Yes, the 5100s use your existing coils. If you step up to the 6112s, they come with their own coil over springs.
  8. Dec 22, 2018 at 11:11 AM
    #98
    Conman1968
    Conman1968 New Member
    2016 Crewmax 4WD Limited
    Billys 5100, 1 inch rear spacer, Cooper AT3 XLT 275/65/R20
    The thing I discovered is the uniqueness of each truck. Just went 5100s all around with new Cooper AT3 XLTs 275/65/20 on my 2016 Crewmax. Although everyone posts the middle setting gets you level, I wound up 2.5 inches nose high. Dropping to lower setting put me 1.5 inches high. Will add 1 inch rear spaces next weekend and be near or at level with any settling. Ride quality was improved over OEM.
  9. Jul 1, 2025 at 10:16 AM
    #99
    CodyCat
    CodyCat New Member
    Ive been going rounds on what to do to get my truck level. I've got a 2010 Rock Warrior. Its got 190,000 miles. I bought it with 73,000 miles 12 years ago and have never replaced the shocks or struts. Im currently running 285/70/17 Toyo M55's. I want to level my truck and put 315/70/17 on it. Based on this thread, either the 5100's on all four wheels or the 6112 up front and the 5100's in the rear. I dont necessarily off road. But, I do drive on lots of two-track trails in the sagebrush and mountain roads in Wyoming. Which combo of bilsteins should I go with?
