Let's talk pressure washers
Discussion in 'Detailing' started by HBdirtbag, Dec 4, 2017.
  1. May 2, 2018 at 8:19 PM
    #121
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    I had a pin hole leak and pressure wasnt that good. So yes leaks cause their to be no pressure
    Nike21 likes this.
  2. May 2, 2018 at 8:24 PM
    #122
    Nike21
    Nike21 New Member
    2018 SR5 CrewMax TSS 4X4 Black Beast
    Was doing my fence tonight to see how the SunJoe worked, and it would do real good, then all of a sudden barely working, then it would do real good again, then barely working. Over and over and over. Thoughts?
  3. May 3, 2018 at 4:40 AM
    #123
    Riskyguy
    Riskyguy New Member
    Stewart
    2018 Tundra SR5 Crewcab
    Not enough water getting to the unit. Do the directions specify what size hose to hook up to the washer? You may need a 3/4" hose.
    Nike21[QUOTED] likes this.
  4. May 3, 2018 at 6:22 AM
    #124
    Nike21
    Nike21 New Member
    The hose is fine. It worked flawlessly when I washed my truck, but that was when the hose was hooked directly to the spigot. I'm thinking it's cause of all the leaks at the different connections when I hooked it to the hose roll up thing. When I get home, I'm gonna hook it up directly to the house again and see what happens.
  5. May 3, 2018 at 6:32 AM
    #125
    fisherman951
    Tony
    2017 crewmax 4x4
    Mine did this but again my hose has a pin hole leak. Make sure no leaks at all so pressure gets to where it needs to be
  6. May 3, 2018 at 7:15 AM
    #126
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Used the 25 degree tip and ran the washer almost continuous for 9 hours with a pause here and there to spray TSP on the roof with my pump up sprayer. A little over 2000sf worth of roof.
    I was pretty impressed with it's performance seeing how it just an electric.
    Roof all done:
    Watt maker and Nike21[QUOTED] like this.
  7. May 3, 2018 at 9:45 AM
    #127
    fisherman951
    Tony
    2017 crewmax 4x4
  8. May 3, 2018 at 12:10 PM
    #128
    G10dra
    G10dra Not a New Member
  9. May 4, 2018 at 9:11 AM
    #129
    Nike21
    Nike21 New Member
    UPDATE: Hooked my pressure washer up with the hose directly attached to the house spigot (bypassing the stupid little leaks), and it worked like a champion pressure washing my fence!! :woot:
    Watt maker and fisherman951 like this.
  10. May 23, 2018 at 1:57 PM
    #130
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Well finally pulled the trigger lol
  11. May 23, 2018 at 11:09 PM
    #131
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Lol thanks. Really like it. Now I don’t have to spend millions in a wash bay when my truck is muddy. Already did my drive way with it, awesome!
    Watt maker likes this.
  12. May 24, 2018 at 5:19 AM
    #132
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Was that from Costco?
    I keep waiting for Costco to bring back in a Honda washer they had about half a year ago .
    Y0TA PR0[QUOTED] likes this.
  13. May 24, 2018 at 5:22 AM
    #133
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    is that a landing zone for the jolly green giant?
  14. May 24, 2018 at 5:29 AM
    #134
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    Pressure Washer newbie here. been thinking about getting one for a while and wondering what is the min PSI needed? I will be washing my Tundra, the other 2 cars in the family , cleaning the driveway, and maybe my fence. based on my usage I think electric will be sufficient (kills me to say that) but not sure on what is the lowest PSI I should consider? Also what accessories are a must, foam cannon?
  15. May 24, 2018 at 8:00 AM
    #135
    Taco-Blender
    AZ
    2010 DC 4x4
    Lol... Not quite but you're close.
    My son is AF CSAR so I painted those up there to give them something to look at when they happen to wander over to our side of town.
    jpod, Patriot and smslavin[QUOTED] like this.
  16. May 24, 2018 at 8:28 AM
    #136
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Yes from Costco. Honda?! Really never seen it at Costco. Probably never made it to Costco Canada.
  17. May 24, 2018 at 9:52 AM
    #137
    Atl626
    Atl626 New Member
    2018 black Crewmax SR5
  18. May 24, 2018 at 10:02 AM
    #138
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    I got this one too a few weeks ago. Local Costco had it with $50 off. Best part is it’s electric start too!!
  19. May 24, 2018 at 10:29 AM
    #139
    Atl626
    Atl626 New Member
    This is my setup, im a contractor so my pressure washer is more than your typical weekend warrior needs , but if you want a heavy duty pressure washer that lasts for years make sure it has a CAT pump and a honda motor
    Woodguy65 and Watt maker like this.
  20. May 24, 2018 at 11:29 AM
    #140
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Ya love that electric start!
  21. May 27, 2018 at 11:35 PM
    #141
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Looks like a great setup, but same time not too bulky. What are details on it pls. Tia
  22. May 28, 2018 at 7:51 AM
    #142
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Looking good Ron!!
  23. May 28, 2018 at 8:09 AM
    #143
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Evil sprinkler system? Lol
  24. May 28, 2018 at 9:05 AM
    #144
    Atl626
    Atl626 New Member
    Its a Simpson ALH 3228-2 , its 3,200 psi, i bought the simpson pressure regulator 82235 dial-n-wash, that way you can control the pressure on the foam canon or the tip when u rinse, my foam canon is the Amazon $17 basic unit its cheap and works just fine, my pressure washes is on sale for the next 2 days, check ebay if you'd like
    https://www.ebay.com/itm/Simpson-Pr...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
    mgm16trdpro[QUOTED] likes this.
  25. May 28, 2018 at 10:50 AM
    #145
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    I've had the G2700 for a little while now. Picked it up at my local Wally world. It's been a great PW so far. Far better than the previous electric ones I've owned. I just used it yesterday to clean the concrete on my side yard.
    That's how I feel about lawn mowers.
  26. May 28, 2018 at 1:03 PM
    #146
    mgm16trdpro
    Northern NJ
    Thank u sir, appreciate the info
  27. May 28, 2018 at 4:09 PM
    #147
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
  28. May 28, 2018 at 5:51 PM
    #148
    Atl626
    Atl626 New Member
    depends what u will use it for, fine to wash the car and rinse down patio/deck, thats about it, anything more than that and u need something with more power
  29. May 28, 2018 at 6:07 PM
    #149
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Just need it for car washes.
  30. May 28, 2018 at 10:58 PM
    #150
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Ah ok! Ya I’d be pissed too.
