Let's talk Leaf packs
Discussion in 'Suspension' started by dcsleeper408, Feb 23, 2018.
  1. Apr 10, 2018 at 5:18 AM
    #271
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Its super easy to get a pack to ride nice off road as well as on road. Just don't change the weight of your truck
    The hard part is dealing with various loads. Multi leaf packs only ride nice within a narrow weight range.
    I've seen a few fords and chevys that add an air shock with a quick release pin in addition to the regular shock. Then when they tow, they just connect the air shock to support the additional weight. Not cheap, but solves the problem
  2. Apr 10, 2018 at 5:56 AM
    #272
    Broncobroke
    Broncobroke Super White Power
    Charlie
    Piedmont, NC
    2017 White Tundra 1794
    Now you tell me!!!:rofl::facepalm::D
  3. Apr 10, 2018 at 7:15 AM
    #273
    dcsleeper408
    dcsleeper408 [OP] BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    how did the 3" wide packs do this last weekend?
    831Tun likes this.
  4. Apr 10, 2018 at 7:21 AM
    #274
    osidepunker
    Alex
    2013 Tundra DC 4x4
    OMG they were amazing! I finally have decent up travel to match the front. they are super soft and plush and I am able to adjust my ride zone in the bypasses to be super soft. I can feel when the transition and bumps zones kick in so I was able to adjust those for a nice progressive ramp up in compression. Since they hold the weight up better, I have MUCH less roll in hard turns yet they still give me excellent articulation.
    I finally have leafs built correctly. The Truck is finally balanced front and rear. I increased the front coilovers from 700# coils to 800# and everything matches beautifully. The suspension changes plus the new 37s means I basically have a completely different truck.
  5. Apr 10, 2018 at 7:28 AM
    #275
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Very nice!
    Did you do any adjustments to the front after putting the 800# springs on.
    831Tun likes this.
  6. Apr 10, 2018 at 7:35 AM
    #276
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Oh yeah for sure. On the first afternoon of the trip, I spent 2 hours going back and forth over the same section of trail and making adjustments. I still need to re-adjust the preload and add some super bumps and then I'll play with them again.
  7. Apr 10, 2018 at 8:06 AM
    #277
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    The icon multirate rxt pack held up decent in DV. With my estimate weight load out of 800lbs
    The pack was designed to hold up to 750lbs at the 3rd option and retaining a 1” height over stock. I would say in this area it did well. However by the second day the leaf packs looked fairly flat.
    I was told I wouldn’t reap the benefits of the leaf packs bc I am on the stock pro shocks. For the most part they flexed well and ride decent through washboards.
  8. Apr 10, 2018 at 8:10 AM
    #278
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    2 days? ouch. did you unload that 800lbs when you got home or is that a constant weight for you?
  9. Apr 10, 2018 at 8:23 AM
    #279
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Tent,rack,spare is still on.So about 450 constant weight. Everything else gets unloaded and packed away.
    Juddrussell, 831Tun and joonbug like this.
  10. Apr 10, 2018 at 8:24 AM
    #280
    Steve6
    Steve6 New Member
    Tucson
  11. Jun 14, 2018 at 4:49 AM
    #281
    Juddrussell
    Juddrussell New Member
    Jacob
    Bentonville, AR
    2016 MGM Tundra TRD Pro
    BAMF Bedrack, 295/70/r18 General Grabbers, Bedslide, Weathertech floor mats, and Tepui Autana Sky RTT.
    Update on the RXT pack? I still plan on doing CB shackles and shims first but I’ve been debating the RXT vs the route @JTP went with, custom pack through Champion Leaf & Spring down in Ft. Worth, TX.
  12. Jun 14, 2018 at 7:02 AM
    #282
    n2deep
    n2deep Pavement Princess
    What CB shackles you looking to get? Have a set sitting in my garage that I won't be using. +3 I believe. Whatever are the longest
  13. Jun 14, 2018 at 7:37 AM
    #283
    Juddrussell
    Jacob
    Bentonville, AR
    PM Sent!
    dcsleeper408[OP] likes this.
  14. Jun 14, 2018 at 8:11 AM
    #284
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Sorry I should've done a better review on the RXT packs. From my experience I think do fairly well - at least for what I need.
    ALL THESE ARE BASED OF MY STATIC WEIGHT WITH FULL SPARE/FULL SIZE BED RACK & I AM RUNNING STOCK PRO REAR SHOCKS/FRONT PRO COILS CB SHIMS
    -Option 1: great ride and height upon install (close to OEM with +3 shackles), added the Tepui Ruggedized tent, and they went flat.
    -Option 3 : perfect height with the tent/full size spare/rack on. Supports this static weight really well. Added my gear + 9g of fuel, about 9g of water, and they were pretty close to flat at death valley. Rides great with this load out.
    FYI:Icon site say to replace 3rd spring-it will be the 3rd spring from the main
    -My leaf packs look really beat up now. A lot of surface rust all over, but I think that's normal?
    So based off this, they really did the job. With all the weight I was at a decent height for the stock pro shocks, I didn't reap the benefits of the extra travel the rxt gives ya, but overall ride was great with the stock pro shocks. With OEM +3 shackles I was flat out the whole time and nose high.
    @Juddrussell if you plan to wheel it with the added weight I would advise a leaf pack for sure. I had no experience with any other leaf packs on the tundra. Only custom alcans on my tacoma(without weight they ride like shit-or maybe my 5100 shocks couldn't keep up) The RXT pack is a great setup, gives you options to play with, and the new ones come with a cool sticker. SDHQ had the best price when I was looking, shipped to my loading dock as well to cut some cost. Came within 4 days from AZ to Bay Area CA.
    If you get a custom pack based on only weight you will most likely compromise the ride and performance, and lead time would probably 2-3 weeks? I don't know much about champion leaf springs so I cant say. Budget wise +3 shackles on oem packs worked great. @KevinK is still running his to the ground I think.
    joonbug likes this.
  15. Jun 18, 2018 at 8:33 AM
    #285
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    Yup, went back to the stock leafs with a 3/4” shackle and a 1” block after trying a borrowed Deaver expedition pack with additional 500lbd preload. Those deavers weren’t setup for our weight, so they could have been great, just not for us. We don’t weigh enough to make them move.
    With the bypasses and the hydro bumps, the stock pack is keeping up great, but at some point we’ll be going to the full RXT solution. Have taken enough rides in other trucks with them to be sold on the kit.
  16. Jul 2, 2019 at 5:21 PM
    #286
    m4sh33n
    m4sh33n New Member
    East Texas
    2019 Tundra TRD Sport
    BDS 7" Coilover Supsension Lift LEER 100XL Topper 20" Methods 37" Nitto Ridge Grapplers Amp Steps LED swapped every bulb in/on the truck
    Any updates on this? With only a hard topper and overhead drawer I already have 2" of rear sag. I haven't even begun to add weight yet. I was set on a Deaver custom pack, but now I'm curious about the RXT long term.
  17. Jan 13, 2020 at 12:25 PM
    #287
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
  18. Jan 13, 2020 at 1:20 PM
    #288
    Stig
    Stig New Member
    I have a constant minimum load of 300 lbs (cap, fridge, random supplies) but is more like 340 lbs daily.
    And another 50 to 100 lbs occasionally.
    On stock suspension now. Rear is sagging some. Will eventually upgrade my shocks bit don't plan to lift the front more than 2" and want to keep some rake.
    Offroad is just fire roads and that's less than 1%
    I was thinking to go with new leafs for my constant added weight but reading some posts here makes me think just a shackle is better. Sounds like messing with leaf packs is a rabbit hole I don't have time for.
    Thoughts?
    For maybe I'll start a new thread
    grave and gabex35 like this.
