Let's Talk Knives
Discussion in 'Off-Topic Discussion' started by nk1794, Jan 28, 2018.
  1. Dec 1, 2021 at 6:35 PM
    #1321
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    So nice!
    Dig the anvil.
    The handle looks like a forest.
    The blade pattern is ghost-like.
    Very cool.
    jewsNbrews and gosolo[QUOTED] like this.
  2. Dec 1, 2021 at 6:40 PM
    #1322
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Thank you, my friend! I keep looking for ways to “up the game”. Just like your spectacular hardscape designs
    jewsNbrews and Hightide[QUOTED] like this.
  3. Dec 2, 2021 at 9:53 AM
    #1323
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    OK - now you're just showing off!
  4. Dec 2, 2021 at 10:01 AM
    #1324
    War Machine
    War Machine SSEM # 5 3MW
  5. Dec 2, 2021 at 10:02 AM
    #1325
    War Machine
    You’re gonna end up getting some of my money at some point. (Pun intended)
  6. Dec 2, 2021 at 10:15 AM
    #1326
    War Machine
    That stapler is pretty solid. That might do the trick on its own.
  7. Dec 2, 2021 at 10:30 AM
    #1327
    gosolo
    Ray (or maybe Dale)
    NW Oregon
  8. Dec 2, 2021 at 11:44 AM
    #1328
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Hightide, Prostar 190 and jewsNbrews like this.
  9. Dec 2, 2021 at 11:50 AM
    #1329
    Outbound
    Aaron
    Northern Alberta
    My wallet just ran and hid.
    Does a bear shit in the woods?
  10. Dec 2, 2021 at 11:58 AM
    #1330
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Nope.
  11. Dec 2, 2021 at 11:59 AM
    #1331
    Outbound
    Aaron
    Northern Alberta
    There you have it. Urbanization is the root of all evil, it's fundamentally altered the bear's behavior. :(
    gosolo, RainMan_PNW, Hightide and 3 others like this.
  12. Dec 2, 2021 at 12:22 PM
    #1332
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Found this mosaic pin material for next time I do a knife for a Canuck
  13. Dec 2, 2021 at 12:25 PM
    #1333
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    I blame it on Charmin.
    gosolo, Hightide, Barrett50 and 4 others like this.
  14. Dec 2, 2021 at 12:49 PM
    #1334
    Outbound
    Aaron
    Northern Alberta
    Fire.
    gosolo[QUOTED] and Hightide like this.
  15. Dec 2, 2021 at 1:11 PM
    #1335
    Blue Thunder
    Washington
    I’ll take the #3 spot on that reservation list!
  16. Dec 2, 2021 at 1:15 PM
    #1336
  17. Dec 2, 2021 at 1:18 PM
    #1337
    Outbound
    Aaron
    Northern Alberta
    I think you're #2 after @War Machine . My wallet is filing a restraining order against me right now for so many knife, gun and fishing purchases recently.
    RainMan_PNW, gosolo, Hightide and 3 others like this.
  18. Dec 2, 2021 at 1:25 PM
    #1338
    Mine thinks I bought stock in Milwaukee.
    gosolo, Hightide, jewsNbrews and 2 others like this.
  19. Dec 2, 2021 at 1:26 PM
    #1339
    Can't wait to see what he creates for you all.
    gosolo, Hightide and jewsNbrews like this.
  20. Dec 2, 2021 at 1:29 PM
    #1340
    Outbound
    Aaron
    Northern Alberta
    My debit card has that belief. :D
  21. Dec 2, 2021 at 1:32 PM
    #1341
    Good thing I buy all my guns knife's and Milwaukee tools from side work or my wife would probably make me single.
    RainMan_PNW, gosolo, Hightide and 2 others like this.
  22. Dec 2, 2021 at 6:43 PM
    #1342
    RainMan_PNW
    Casey
    Clark County, WA
  23. Dec 2, 2021 at 6:43 PM
    #1343
    RainMan_PNW
    Casey
    Clark County, WA
    Words I live by as well
  24. Dec 2, 2021 at 7:10 PM
    #1344
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    This poses some problems.
    These guys are using some technology system (probably a water jet) and cutting these out of a piece of plate steel. Then they drill some holes, heat treat the whole thing and laminate the handles on each side.
    I can not make a piece of Damascus that big and if I could, wasting that much under the handles would be like throwing away material for 4 or 5 good knives.
    I probably could make a Damascus piece for the head and weld it to another piece for the handle. This could be done in a manner that would be very strong; picture that weld joint being like a couple short pronged forks that fit together like a jigsaw puzzle)
    Still, it would not be as strong as what they are making.
    Give me your thoughts
  25. Dec 2, 2021 at 7:21 PM
    #1345
    RainMan_PNW
    Casey
    Clark County, WA
    Compared to something like this, what you are describing is much more robust - the use of any sort of full-length tang through the handle, even if welded to the head, would beat having just a wood handle. Perhaps if the portion of the tang leading up to the weld were long enough to at least have one of the handle rivets through it to add some more strength, but the reality is that a properly done weld is just as strong or stronger than the base metal.
    https://www.thevintagegentlemen.com...-tomahawk?variant=14183721074754&currency=USD
    Now, the way you describe what they are doing leads to the question “why the fuck are they so expensive?!” Seriously, a piece of water jet cut steel, treated, and two handles epoxied and riveted to it just doesn’t seem to garner the sort of premium like a hand-forged Damascus Ray Taber blade…
  26. Dec 2, 2021 at 7:25 PM
    #1346
    Blue Thunder
    Washington
    Hmm. If I understand what your are saying, it sounds like a compromise. I’d never ask you to compromise on your art or the finished product. So maybe I/we just need to keep dreaming…
  27. Dec 2, 2021 at 7:31 PM
    #1347
    RainMan_PNW
    Casey
    Clark County, WA
    I should add that we weld pipe together all day long that can hold pressures over 1200 psi and when proving the weld coupons it is the base metal that fails. One thing you may consider is heat treating the entire a assembly after welding, and that might exceed the side of your equipment…but you might be able to outsource that one step of doing a “batch”
    Hightide, jewsNbrews and gosolo like this.
  28. Dec 2, 2021 at 7:32 PM
    #1348
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    The piece of plate that they use is a single continuous piece all the way from the blade to the bottom of the handle. This steel is also one of the best knife steels available. It’s assembly is similar to a full tang knife. There’s virtually no hand crafting involved unless you pick the ‘tribal’ option with real wood. I am willing to bet that even the handle pieces are cut via a program fed into a machine.
    Thank you for your support! I agree that they are ridiculously over priced, but they are targeting a ‘niche’ market…
    Tacticool!
  29. Dec 2, 2021 at 7:36 PM
    #1349
    RainMan_PNW
    Casey
    Clark County, WA
    For sure. They surely pay a premium for good knife steel, but it’s a sheet of certified material. And good CNC nesting will cut a LOT of them without too much waste.
    Nothing like what goes into your creations
  30. Dec 2, 2021 at 7:42 PM
    #1350
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I will look into this a bit more.
    should I try this, I think I would source the same steel they used for the handle portion and increase the carbon in the Damascus head by going to 1095, which I have used in quite a few knives. I might try hammering out a piece big enough for the head just to see what happens, lol
