Let's Talk About The Longest Lasting Travel Trailers
Discussion in 'Towing & Hauling' started by onesojourner, Apr 21, 2021.
  1. Feb 22, 2022 at 6:42 AM
    #151
    YankeeRon
    YankeeRon New Member
    Ron
    East Windsor, CT
    2021 SR Long Bed
    Cat Security shield, rear headliner molding, BlackVue dash cam, DS grab handle, rear under seat storage, door edge molding, cal trend seat covers, sway bars, hard bed cover, rubber bed mat, intermittent wipers
    Just picked up our Casita 17' Liberty down in Rice Tx on the 2nd of February. This is our second one - sold the first when we needed a larger one as the kids got bigger. Now it's just my wife, me, and the two dogs, so I wouldn't buy any other trailer. If you take care of these, they'll last well over 20 years and look as good as when they were new. I've seen 15 year old Casita's selling for more than their purchase price. Easy to pull - all the modern conveniences you'd expect, just in a smaller package that doesn't give you any "pants wetting" experiences when towing. Tracks like a little puppy dog behind you, even in full brake lock-up. If you live in New England and want to see one, PM me and we'll gladly show you ours...
    Ron
    twotrack, Warreng, ArcticEd and 3 others like this.
  2. Feb 22, 2022 at 7:00 AM
    #152
    Retired...finally
    Stickers it is. I just found mine. Our Gulfstream is different than the one in the video as his was welded to the bottom of the main frame. Mine is on the same level an intercepts the frame on the inside vertical surface instead of the lower horizontal surface. No reason I can see that makes one design better or worse than the other.
    Mattedfred[QUOTED] likes this.
  3. Feb 22, 2022 at 7:49 AM
    #153
    rideandfly
    rideandfly New Member
    Smelled an acrid smell in Ollie one day with 110V hot water heater on when the hot water heater stopped working, too.
    Found fried wiring in the junction box for the 6 gallon Suburban hot water heater. Tested heating element and tested OK. Ended up cutting out damaged wiring, visual inspection of hot water heater wiring. The circuit breaker never tripped. Did the "smoke" test next, it's been working great since. Believe the original wiring connections were loose eventually causing failed wiring. Probably should replace the circuit breaker, too.
    Mattedfred likes this.
  4. Feb 26, 2022 at 6:25 PM
    #154
    Half track
    Half track New Member
    Rob
    Western Nevada
    2020 Silver Tundra SR5 TRD, 38 gal tank
    Tow Mirrors
    I have had both a 26' Nash & 22' Arctic Fox.
    I thank Northwood trailers makes some of the best travel trailers. I have been through the factory 3 times and seen them made, but 24ft Nash trailer goes for about $30,000. I bought my 2015 24' Jayco for $19,500. Not the greatest trailer. But it works.
    The 24' Nash/Artic Fox has a 20% heavier frame then my 24' Jayco, but even though my Jayco frame is lighter, the way it is made is important, check out this web site on how Jayco frames are made.
    https://jayco.com/blog/rv-frames-review/
  5. Mar 11, 2022 at 10:05 AM
    #155
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Even if the 2011 lasts you a quarter as long, you still come out ahead!
  6. Apr 1, 2022 at 8:01 PM
    #156
    ATHiker
    ATHiker New Member
    Tom
    2015 DC SR5TRD 5.7L 4X4
    I love the Bigfoots. My favorite floor plan is the Bigfoot 21RB. The Bigfoot 25's are heavy trailers and can have a very heavy tongue weight, particularly if they have the front storage box. Most that I know that have them are using 3/4 tons.........
  7. Apr 2, 2022 at 8:07 PM
    #157
    ATHiker
    ATHiker New Member
    Tom
    I suggest that you check out the forum on Fiberglassrv.com. Lots of good information about Bigfoot and other fiberglass campers.
  8. Apr 3, 2022 at 6:56 AM
    #158
    Retired...finally
    I've been known to mention I wouldn't buy an Airstream due to the lack of a slide. Well I saw one with a slide. Now the real reason comes out. I can't afford one.:ohsnap:
