Let's talk about Payload. How many of you exceed it?
Discussion in '3rd Gen Tundras (2022+)' started by Max713, Jul 2, 2023.
  1. Jul 4, 2023 at 12:18 PM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    With my Tundra (sorry, 2nd gen):
    I've towed the same trailer around 6800# with both D rated tires and now with P rated tires. My experience was that properly setting the WDH had far more impact on stability than tire selection. I honestly didn't even notice the difference in tires.
    I do have 20" wheels if that factors into sidewall stability.
  2. Jul 4, 2023 at 2:12 PM
    The load index for the tires on your Tremor is crazy high (129). Ford must just keep the same drivetrain for the 250 and 350 Tremors to reduce overall cost. Pretty much buying payload if you go with the 350 tremor (which some have to). I'm sure the non-Tremor 250/350 vary a lot in setup (maybe you know the differences and can chat about that). I do know GM and Ram get overload springs and wider springs on the 1 ton.
    The overloads are very easy to see on GM with the extra two springs and the overload pads mounted to the frame.
    Tundrastruck91 likes this.
  3. Jul 4, 2023 at 3:43 PM
    ArmygreenTRD
    ArmygreenTRD New Member
    2022 Army Green TRD, SR5 DC
    Answer: As much as I can put in the bed and TT,right?
  4. Jul 4, 2023 at 4:10 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    1/2 ton is good for tow or haul, just not tow and haul at the same time
  5. Jul 4, 2023 at 4:19 PM
    Retroboy1989
    Northern Utah
    This. I'm a huge advocate of using a CAT scale to get the front axle weight back up. I'm within 100lbs.
    Mattedfred and RostamD[QUOTED] like this.
  6. Jul 4, 2023 at 4:45 PM
    Retroboy1989
    Northern Utah
    Follow up thought:
    I see trucks all the time with the front suspension obviously underloaded when towing, even with a wdh. I think there are many that slap it on and call it done. Might as well not use one if you aren't going to adjust it.
    ColoradoTJ, Mattedfred and digitalwiz like this.
  7. Jul 4, 2023 at 6:50 PM
    xc_tc
    xc_tc New Member
    100% this.
    Need to get front axle as close as possible to unloaded front axle weight. For my Platinum that’s ~3500 lbs.
    Mattedfred likes this.
  8. Jul 4, 2023 at 6:59 PM
    Retroboy1989
    Northern Utah
    My truck is also 3500lbs with me sitting in the driver's seat and 3/4 tank of gas.
    I got it to 3400 lbs with the trailer on. WDH bars are a chore to install at that tension.
  9. Jul 4, 2023 at 7:20 PM
    Max713
    Max713 [OP] New Member
    7700-4100= 3600 front axle weight :D
  10. Jul 4, 2023 at 9:21 PM
    Hella Krusty
    Hella Krusty New Member
    I towed a 10,000 LBS travel trailer around British Columbia for 8 years with 2012 Tundra and I honesty thought it towed it better than my 2010 F350 Cabela Version. The prior Dodge V10 Kicked the other 2's ass
  11. Jul 4, 2023 at 9:27 PM
    Oh man. No thanks...I honestly believe you and the same thing my three buddies that have Tremors agreed to as well. It makes sense why they would do that. The Tremor is a very specialized trim package and to make several different axle/spring packages would be asinine.
    Lake.Life24 likes this.
  12. Jul 5, 2023 at 8:20 AM
    xc_tc
    xc_tc New Member
    What I like to do is keep the tongue jack down and that makes installing the load bars easier.
    Your truck is TRD Pro? Hybrid is heavier so you could probably install a heavier duty load bar or set your load bar to the next setting.
  13. Jul 5, 2023 at 8:21 AM
    Max713
    Correct. I’ve got a new WDH for the new trailer that’s much more adjustable.
  14. Jul 5, 2023 at 8:24 AM
    Retroboy1989
    Northern Utah
    I find i have to reverse the jack once the ball is locked in the coupler and bring the back end of the truck up an inch or two.
    I would say that means I am too tight, but the CAT scale doesn't lie.
  15. Jul 5, 2023 at 8:35 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    That doesn't seem to far out of the asinine stuff Ford has done in the past.
  16. Jul 5, 2023 at 8:59 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Now that i have experience going from P tires, to E, back to P. I now firmly believe E rated tires are far more enjoyable to have on the truck.
    P rated stock tires can physically handle the loads a tundra should haul, however they are much closer to their max capacity than an E rated is, so the driving experience is spongy and uncomfortable. E rated tires feel solid in turns, and solid when loaded down
    WhiteTundra0013 likes this.
  17. Jul 5, 2023 at 9:12 AM
    Retroboy1989
    Northern Utah
    Are you on 18s or 20s ?
    I also air the rears up to max pressure according to the sidewall when I tow. (50 psi on my Yokohama G015s)
    I'm going to try 40 psi in the rear this weekend and see how it does.
    I'm not a fan of LT rated tires on my tundra after the vibration issues I was having with LR D BFGs. The problem went away with P rated tires and new steering rack bushings. (I tried some new, load E Michelin AT2s and the vibration got even worse, really bad shake in the wheel at 60mph+)
  18. Jul 5, 2023 at 9:23 AM
    xc_tc
    xc_tc New Member
    Yeah this is exactly what I do. Lift the rear up by lowering the jack foot. I find this is only needed for the heavier trailers. I think it would be easier if I had some 1200 or 1400 lb bars.
  19. Jul 5, 2023 at 9:26 AM
    #49
    Retroboy1989
    Northern Utah
    I don't really have to do it when I hook up my trailer at home because my truck is nose down in the gutter anyway, but I definitely need the extra height when hitching on level ground. Not even sure I could get the bars on if I were in a dip - i'd probably have to move it first.
    I use the hook/pry tool that came with my hitch to pop them in. Husky Centerline has retaining bosses you have to get up an over on the L brackets. Nice feature, but it adds another 1/2 inch to the muscle required to pop them in.
  20. Jul 5, 2023 at 9:44 AM
    #50
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    im on 18s. I air them up when towing. 50 seems too high, i do 45psi now
    Ive never had any kind of vibrations with e rated tires, however i was on stiffer lift springs though too, now im back to stock.
    The e rated tires hold tighter in corners, i dont know if this is good or bad from a traction standpoint, but the p rated feel wallowy in corners
  21. Jul 5, 2023 at 9:53 AM
    #51
    Retroboy1989
    Northern Utah
    According to my weight, 50psi is too high. I'm backing that off now. I'm also on 20s with a TRD sway bar. No spongy feeling.
    Hbjeff[QUOTED] likes this.
  22. Jul 5, 2023 at 12:06 PM
    #52
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    ive got the front and rear trd rear sway too, something isnt right though my handling feels jerky and wallowy. Alignment is good too
  23. Jul 23, 2023 at 10:37 PM
    #53
    NATE4SURF
    NATE4SURF New Member
    Laguna Hills, CA
    '23 TUNDRA TRD CREW 4X4, was ‘05 TUNDRA TRD CREW 4x4
    I need air bags. What did you go with? Cost? Who installed? Thanks.
  24. Jul 25, 2023 at 11:02 AM
    #54
    Retroboy1989
    Northern Utah
    Take a look at sumo springs. They are support for the rear springs with no fuss. I'm happy with the ride quality unloaded all the way up to max payload.
  25. Jul 25, 2023 at 11:25 AM
    #55
    CTundraForMe
    CTundraForMe New Member
    This doesn't seem any different than 2nd gen discussion?
    Make sure the trailer brakes are calibrated.
    And to add to what someone else said ... sure, it can tow a lot, as long as you don't need any tongue weight! Toyota marketing is almost a blatant lie...
  26. Jul 28, 2023 at 10:03 AM
    #56
    Ray D
    Ray D New Member
    Ray
    Winnipeg, MB
    2023 Tundra Hybrid Limited L TRD OR 4X4
    What’s the size of your trailer? Did you go with the blue or black SumoSprings?
  27. Jul 28, 2023 at 10:17 AM
    #57
    Retroboy1989
    Northern Utah
    7000#
    Black
  28. Jul 28, 2023 at 10:34 AM
    #58
    Ray D
    Ray D New Member
    Ray
    Winnipeg, MB
    How does the truck ride with the black sumos when not pulling your trailer? I’m trying to figure out whether blue or black would be best as I tow a 28’ travel trailer that’s 7000 lbs loaded. SSI suggested blue may be best as I don’t pull the trailer all the time but I appreciate the real world experience of other folks.
  29. Jul 28, 2023 at 11:17 AM
    #59
    TundraMoe
    TundraMoe New Member
    2023 GMC Sierra Denali 3.0 Duramax
    I’d love to hear that evaluation too.
  30. Jul 28, 2023 at 3:09 PM
    #60
    Retroboy1989
    Northern Utah
    My truck had a fiberglass cap on it when I installed my sumo springs. So +250lbs on the rear axle. I did not notice any change in ride quality after I put them on. At rest, the sumo springs lightly contacted the frame.
    I sold the cap and I've noticed my ride is a little rougher without it. I do not know if it is the sumo springs or just leaf springs being leaf springs. There is a little gap between my sumo springs and the frame now. There is absolutely no way you will feel the springs contact the frame. They are progressive rate so there is little difference between no contact and slight compression.
    Overall, I am happy with the ride. It feels like a truck.
    Edit: Arent third gens coil sprung? Does this even matter to you fellas?
