Let's See Your T-100!!
Discussion in 'Other Toyota Vehicles' started by because_wumbo-truck, Oct 30, 2019.
  1. Oct 30, 2019 at 11:08 AM
    because_wumbo-truck
    because_wumbo-truck [OP] TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    I'm fascinated with the Toyota T-100. These truck were meant to compete with American full size.truck, bit never really stood a chance as they were smaller and had.no v8 option. Toyota stepped up their game with the introduction of the extended cabs, the 5vzfe and once.again with the TRD supercharger. But the T-100 just.couldnt compete, despite being a.solid truck. Turns out it wouldn't be a complete failure, as it was truely ahead of it's time and created the midsize truck market. Plus it lead to the true full-size Tundra as well as the Tacoma's jump from mini truck to midsize truck. If I can find a 97 or 98 T-100 with a v6 and 5 speed I'd be all over it for my next project
    So let's honor these rare trucks and post your pics! :worthless:
  2. Oct 30, 2019 at 11:18 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    Here is my old T100, that I only had for a while. I bought it cheap and fixed a minor issue then flipped it for more than double what I payed for it.
  3. Oct 30, 2019 at 11:33 AM
    kenomouth64
    Tetrus
    Wow, the wheels are atrocious though, lol.
    Mr Badwrench likes this.
  4. Oct 30, 2019 at 11:35 AM
    '97
    353+ miles speedometer cable broke, if calculated right, should be at 356+
    Just did valve cover gaskets, but I forgot the wire loom on driver's side and alternator belt snagged wire for camshaft position sensor :mad:
    Needs CV axles, a/c compressor, and camshaft position sensor
    Replaced drive line since old one was done by mechanic who screwed up the double cardan joint, needs new u joints for 4wd shaft
    Got new brakes pads n shoes, need rotors n drums, need time to put on
    Cable for spare tire winch broke, bought new used one off eBay, I need to take bed off to put on, 4 bolts, only two can be accessed from bottom other 2 bed has to be removed, so my spare is in the bed
    Oil changes every 3000 miles on time, Mobil 1 oil filter, Valvoline high mileage 10w-40
    Front rear diff changed couple years ago, due again
    Tranny fluid never been changed :eek2:
    Fuel filter changed out few months back, Fram fuel filter
  5. Oct 30, 2019 at 11:39 AM
    BeachyTundra
    BeachyTundra New Member
    Brandon
    Spokane
    2017 MGM 5.7L DC, Bilstein 5100s
    The T100 was the predecessor to the Tundra, not the Tacoma?
    ToyotaTundraMike and Rex Kramer like this.
  6. Oct 30, 2019 at 12:04 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    My '96 4x4 SR5 V6 T100 was an awesome truck...
    I sold it about a year after buying my 2002 4x4 SR5 V8 Tundra.
  7. Oct 30, 2019 at 1:31 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    The T100 preceded both technically, it's run was 93-98, Tacomas came out in 95.5 as the 95 model. Tundras came out in 99 as the 2000 model.
    But the T-100 was a failed fullsize experiment. So yes it lead to the Tundra.
    However it was dimensionally what we now call a midsize (midsize trucks weren't even a thing back then but compact aka mini and fullsize were). So it basically became the prototype for the midsize Tacomas as far as size and power to weight ratios etc.
    Rica25 and Trooper2 like this.
  8. Oct 30, 2019 at 1:42 PM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    The T-100 was designed and built by Hino, the heavy truck division of Toyota. As was the FJ Cruiser.
  9. Oct 30, 2019 at 1:57 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Here's mine just before I sold it. Kind of regret selling it, but I "needed" the V-8
    Even though the extended cab T-100 and 1st gen access cab tundra are the same size, there's less room in the back of the tundra because the rear seats are thicker. I didn't know that before I stuffed my kids back there for a 6 hour drive :(
  10. Oct 30, 2019 at 2:06 PM
    BeachyTundra
    Brandon
    Spokane
    Well I suppose time-frame wise, that could be true.
    I personally would consider the "Toyota Pickup" the predecessor to the Tacoma, as that was kind of the natural progression of the vehicle in terms of size/capacities. You are correct that the T100 was an experiment that ultimately led to the Tundra, but I think it's a stretch to say the T100 led to 3rd gen Tacoma. The T100 filled the midsize role until the introduction of the 1st gen Tundra. The Tacoma was the compact and the Tundra was midsize until Toyota made the jump to midsize for the Tacoma in 05 and full size for the Tundra in 07.
    Regardless, the history of the trucks is neat, and I sure wish I could get my hands on an old Toyota Pickup with factory turbo. Those things were awesome.
  11. Oct 30, 2019 at 2:08 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    The pickup absolutely is the predecessor of the first gen Tacoma.
    I'm saying the 2nd and 3rd gen Tacomas are the spiritual successors of.the T100 and only have the Tacoma name.plate because of.its success and recognition vs the T100 name plate
    The first gen Tundra was not a midsize.
    I'll post the stats. Hold on.
    Edit: some additional info for comparison.
    Width
    1st Gen Tacoma : 70.3″
    1st Gen T100 : 75.2"
    2nd Gen Tacoma : 74.7"
    3rd Gen Tacoma : 75.2"
    1st Gen Tundra : 79.3"
    Length
    1st Gen Tacoma AC/DC : 202.9″
    1st Gen T100 RCLB/AC : 209.1"
    2nd Gen Tacoma AC/DCSB : 208.1"
    3rd Gen Tacoma AC/DCSB : 212.3"
    1st Gen Tundra : 218.3 to 230.1″
    Curb Weight
    1st Gen Tacoma : 2,750 to 3,705 lbs
    1st Gen T100 : 3,320 to 4,040 lbs
    2nd Gen Tacoma : 3,550 to 4,220 lbs
    3rd Gen Tacoma : 3,980 to 4,480 lbs
    1st Gen Tundra : 3,935 to 5,020 lbs
    BeachyTundra[QUOTED] likes this.
  12. Nov 2, 2019 at 5:03 PM
    because_wumbo-truck
    Jon
    Houston, Texas
  13. Nov 2, 2019 at 5:09 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
  14. Nov 2, 2019 at 5:34 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I bought a 1997 four wheel drive, 5 speed manual, 3.4 liter new from the dealer. It's still in the driveway and is my daily driver. 263,000 miles and just keeps going.
  15. Nov 2, 2019 at 5:55 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    :worthless:
  16. Nov 4, 2019 at 7:43 AM
    kenomouth64
    Tetrus
  17. Nov 4, 2019 at 8:25 AM
    BeachyTundra
    Brandon
    Spokane
    But....but.....but..... Early Toyota's are made of gold, didn't you know? :rolleyes:
  18. Nov 4, 2019 at 10:29 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    Region also plays a role in price. where are you located?
  19. Nov 5, 2019 at 11:21 AM
    kenomouth64
    Tetrus
    Good point, I expect a non-rusty truck in the North or on the West coast would fetch much more than in Dallas.
  20. Nov 5, 2019 at 11:28 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Any particular reason why? I'm OCD about fluids so this would drive me nuts.
  21. Nov 5, 2019 at 11:32 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  22. Nov 5, 2019 at 11:34 AM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    Guy lives in my town. Parked next to mine E21A1C62-9B3C-4F04-9F0D-CF46927BC41A.jpg
  23. Nov 5, 2019 at 11:37 AM
    Just never got around to do, :anonymous: yes I know it should have been done long ago, but I hear now leave it be or if I do change, tranny won't act right
    JimboSlice413 likes this.
  24. Nov 5, 2019 at 11:39 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    That's kind of an old myth and it was mainly from people that did an actual "flush" after never doing it. I would do a series of drain+fills where you slowly introduce fresh ATF into the system. That's just me though.
  25. Nov 5, 2019 at 11:41 AM
    Yeah I heard of that too, I have maybe added about half a bottle since I've had it
  26. Nov 5, 2019 at 3:14 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    I'd hate to insult the guy with such a low ball offer, since he's asking $7200. But this is the 2nd time I've seen him list the truck in 3 months and his price has come down only $600. So I figured $5k. is fair considering the mileage. But yeah at $3500 I'd be much happier with it either way, I'm gunna wait til 2020. May e.somethi g else will come along. I don't need 4wd on my 2nd vehicle since I'll be keeping my tundra. I just want a 5 speed manual and 5vzfe to supercharge and have fun in around town and commute to work in my tundra will become my back up vehicle for hauling/towing/off roading etc.
    kenomouth64 likes this.
  27. Nov 5, 2019 at 3:16 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    That's not a T100 bit it is a nice little pickup
  28. Nov 5, 2019 at 3:17 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    If it's a manual you should be fine doing it. Of it's auto just do a drain n fill.
  29. Nov 5, 2019 at 3:32 PM
    It's an automatic
  30. Nov 5, 2019 at 6:23 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Yeah then do what @FirstGenVol said and drain n fill it like every oil change until it comes out clean looking. Then you can wait and do it every 30k-60k miles depending on how anal you are lol
