Let's see your first gen - photo thread
Discussion in '1st Gen Tundras (2000-2006)' started by Rkcruza, Jan 6, 2014.
  1. Nov 7, 2021 at 3:01 PM
    #2641
    1stgentundradriver
    1stgentundradriver Each sticker adds at least 5hp
    Josh
    Silverdale Washington
    2006 DC 4x4 Limited
    A few
    I always thought for off road driving the high clearance rear bumper was the best one to start with rather than up front. Unless you need a winch.
  2. Nov 7, 2021 at 5:18 PM
    #2642
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    Either or. One improves approach other does departure. But I'd start with skids and sliders
  3. Nov 7, 2021 at 6:30 PM
    #2643
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    True…this is probably the best idea.
    TBinky and TRDGen[QUOTED] like this.
  4. Nov 13, 2021 at 1:10 PM
    #2644
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
  5. Nov 13, 2021 at 8:11 PM
    #2645
    I suspect you could pop that front passenger side dent with suction. Open a private browsing tab and Google for dildo car dent removal, you may be surprised at how effective it is. Not saying to go to the adult store and get a "dent removal tool", there are other suction items out there that may be cheaper, but the adult store will cost less than a proper "tool" (or so I hear)
  6. Nov 14, 2021 at 6:17 PM
    #2646
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    @Brown Bear I must ask…how did you pass the wiring for your Ditch lights into the cab? I have a lightbar to go into the bumper and the only thing holding up install is I have no idea how to pass the wire through the engine bay into the cab.
  7. Nov 15, 2021 at 4:20 AM
    #2647
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    On the driver's side of the firewall to the right/ beneath your brake booster, there will be a rubber grommet. Both the driver and passenger sides of the firewall have this grommet. You can carefully poke a hole or cut into this grommet and fish wires through. Be careful otherwise you can damage the wiring harness. I have run a few different wires through there successfully. If you're worried about water proofing, stick some liquid tape on that sucker after you're all wired up.
  8. Nov 15, 2021 at 3:20 PM
    #2648
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Took a drive up through northern Wisconsin today to pick up some lawn equipment. Had to stop and take a few pictures...2FC63347-F4EB-4CD8-97AD-38675C3A8BB1.jpg752E385F-604A-4ED5-95A7-1F301B1F9FA6.jpg
    whittkl4, Schcoman, Voss and 8 others like this.
  9. Nov 15, 2021 at 3:33 PM
    #2649
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    I love those Lexus wheels
    TRDGen and N84434[QUOTED] like this.
  10. Nov 15, 2021 at 4:57 PM
    #2650
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Thank you! I appreciate it. I will Definetly try that!
  11. Nov 15, 2021 at 5:50 PM
    #2651
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Tanks a bunch!
    jImmegart[QUOTED] likes this.
  12. Nov 15, 2021 at 6:55 PM
    #2652
    TRDGen
    TRDGen Schnooogins
    Travis
    X2. I'm putting some on my T100 soon.
    N84434 and jImmegart[QUOTED] like this.
  13. Nov 15, 2021 at 9:33 PM
    #2653
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    How big is the hole in this grommet? Is is pretty large?
  14. Nov 15, 2021 at 9:58 PM
    #2654
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I love it when the @Brown Bear makes an appearance in the woods
  15. Nov 16, 2021 at 7:45 AM
    #2655
    des2mtn
    SW
    Tonto cover
    You poke and make the hole yourself. I used a screwdriver. This is my passenger side which I've shoved two things through.
  16. Nov 19, 2021 at 11:16 AM
    #2656
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    That was a Westin. I now have a Brute Force Fab front bumper.
    Filthyphil, Brown Bear, MS22 and 4 others like this.
  17. Nov 19, 2021 at 7:38 PM
    #2657
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
  18. Nov 22, 2021 at 6:12 AM
    #2658
    des2mtn
    SW
    Tonto cover
  19. Nov 23, 2021 at 9:50 PM
    #2659
    vsoliman212
    vsoliman212 New Member
    Clean truck brah! Are you running spacers? and how much offset? Thanks!
  20. Nov 25, 2021 at 9:51 PM
    #2660
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    No spacers. 0 offset 4.75 back spacing.
  21. Nov 27, 2021 at 3:04 AM
    #2661
    Need to know stuff
    Need to know stuff New Member
    2000 black Tundra TRD
    3 front 2 rear leveling
  22. Nov 27, 2021 at 5:00 AM
    #2662
    Openbaffle
    Openbaffle New Member
    2006 Phantom Gray Tundra X-SP DC
    This is close enough to a good point that I'm happy to share. SPC UCAs, OME shocks w/2885s up front. Torch add-a-leaf, axle shims and extended u-bolts. Original stock leaf springs. Snugfit color-matched topper. New OEM LCAs, LBJs and outer tie rods. IRX ceramic tint all around. Spray in bedliner. It's been a process. Baja Designs Squadron SAE fogs. H4 mini projectors (retrofits in the works). Wildpeaks in 265/70r17s with 1.25” Spidertrax spacers. 4Runner trail edition rims. IMG_7339.jpg
  23. Nov 27, 2021 at 5:10 AM
    #2663
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    Sweet ride, I'm a fan!
    Good work sir
  24. Nov 29, 2021 at 11:45 AM
    #2664
    TRDGen
    TRDGen Schnooogins
    Travis
    :eek:whaaaaat?
    That's crazy cool :curls::muscleflexing::militarypress::benchpress:
  25. Nov 29, 2021 at 12:01 PM
    #2665
    Need to know stuff
    Not done yet. In the middle of solid axle swapping it. But I do have spacers to run duallys.
  26. Dec 6, 2021 at 1:29 AM
    #2666
    Aerindel
    Aerindel New Member
    Montana
  27. Dec 8, 2021 at 4:36 PM
    #2667
    Casper421
    In the woods
    06 DC
  28. Dec 8, 2021 at 5:23 PM
    #2668
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Toytec Aluma 2.0, Camburg UCA, 5160s and more.
    Just got this bad boy, can't wait to start working on it
  29. Dec 8, 2021 at 5:42 PM
    #2669
    Openbaffle
    Looks like it's pretty fantastic as it sits now! No chrome. Color matched mirror caps. Camper shell. Nice rims too!
  30. Dec 8, 2021 at 5:52 PM
    #2670
    TRDGen
    TRDGen Schnooogins
    Travis
    What winch you running in that CO bumper?
    dinosaur likes this.
