Let's see your first gen - photo thread
Discussion in '1st Gen Tundras (2000-2006)' started by Rkcruza, Jan 6, 2014.
  1. Oct 25, 2019 at 3:40 PM
    #1201
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Ohh baby she looks clean!! Is your Speedo off from your tires being bigger?
  2. Oct 25, 2019 at 3:50 PM
    #1202
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Aren’t ours all!?!? Hahah
    MS22 and because_wumbo-truck like this.
  3. Oct 25, 2019 at 4:41 PM
    #1203
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Thanks! I'm sure it's off. I think the pros here calculated it to be off 8%. That's what I've been using to calculate MPG.
    Filthyphil[QUOTED] likes this.
  4. Oct 25, 2019 at 7:36 PM
    #1204
    Filthyphil
    Phil
    Yeah I’ve been having to add 3% to mine, love how your canopy opens from the side windows jealous on that..
  5. Oct 27, 2019 at 5:04 PM
    #1205
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    2006 Tundra 4X4 Limited Dbl Cab
    This has been a great story to watch unfold. Congrats to you sir, good looking ride!!
  6. Oct 28, 2019 at 9:04 AM
    #1206
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    285/70/17 right? I think its closer to 6.5%
    You can go here to check.
  7. Oct 28, 2019 at 9:37 AM
    #1207
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    For mine is just set my cruise and used a GPS. Whatever the difference was is how I got my 11% if I recall. So at 65 on my speedo I'm going about 71-72. I think it's right between 10.5 and 11%. Obviously the faster you go the closer you can get the percentage when checking on gps.
  8. Oct 28, 2019 at 11:30 AM
    #1208
    SC T100
    SC T100 New Member
    2005 Toyota Tundra Double Cab 4WD
    Rancho Quicklift/RS9000XLs, Rancho rear 1.5" blocks with RS9000XL shocks in rear, SuspensionMAXX extended sway bar links.
    I'm on 275/70R17 KO2s (basically 32s), and on a recent long trip I went 108 miles by mile markers (almost exactly) and my odo said 100. So I bump my mileage by 8% before calculating mpgs. 33s should be a little more.
  9. Oct 28, 2019 at 11:54 AM
    #1209
    Orange devil
    Orange devil New Member
    Here is my old boy 2001 tundra sr5 2wheel drive with vis carbon fiber hood and glass works fenders Screenshot_20191027-213117~2.jpg
    Levy, Trailscape, Brown Bear and 7 others like this.
  10. Oct 28, 2019 at 3:38 PM
    #1210
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    00-04 speedo can be corrected. 05-06 are out of luck.
  11. Oct 28, 2019 at 5:30 PM
    #1211
    Colemank6187
    Colemank6187 New Member
    Kevin
    2006 DC Tundra SR5
  12. Oct 28, 2019 at 6:22 PM
    #1212
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    I thought gears could help correct Speedos, among the other reason to buy em lol
  13. Oct 28, 2019 at 6:30 PM
    #1213
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Not a viable option. If you have 3.91 stock and move to a 33" tire you can swap to 4.10 gears to get almost accurate. If you run 35s a 4.56 will get you almost accurate. Not enough to make the math easier for MPG calculations.
  14. Oct 28, 2019 at 7:05 PM
    #1214
    because_wumbo-truck
    Jon
    Houston, Texas
    I see. Mine came stock with 4.10s according to some website someone posted and the code on my door. I know when I'm going 30 that I'm really going closer to 35 cuz of.the machines.around town that flash your speed at you
    KarmaKannon likes this.
  15. Oct 28, 2019 at 9:29 PM
    #1215
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    a yellowbox speedo calibrator wont work with 05-06?
  16. Oct 28, 2019 at 10:56 PM
    #1216
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I don't think it will. I recall reading that there is a difference in how the speed sensor work with the wheel speed sensors, having conflicting speeds causes trouble. I've seen bad reports on a truspeed for the same reason with the 5 speed.
  17. Oct 28, 2019 at 11:18 PM
    #1217
    empty_lord
    05 rollover special
    Hmm. We do it to the lifted second gen tacos at work. It’s a similar setup. Maybe it’s a tundra only thing.
    because_wumbo-truck likes this.
  18. Oct 29, 2019 at 12:41 PM
    #1218
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    Just got back from a week-long camping / fishing trip.2019-10-28 20.51.23.jpg 20191026_142816.jpg 20191026_142918.jpg 20191027_122043.jpg 5589.jpg 5573.jpg 20191026_081938.jpg 5606.jpg
  19. Oct 29, 2019 at 1:12 PM
    #1219
    marbleville
    marbleville Agent Provocateur
    Yep, last name too.
    State of Confusion
    2002 Thunder Gray Metallic TRD.
    Air freshener died, washer fluid empty, wipers streak.
    @Brown Bear NICE rainbows! Even nicer Boondock Trekker of a Tundra. I realize you mentioned a 4" lift in your rig and how it dwarfs the white Tundra (which is a 2wd?). Oh, and thanks for sharing the idea/construct of your boat rack, a low cost DIY rack, if I have viewed it correctly, that offers more than many commercial racks I have seen.:thumbsup: Now to go back and view it closer...:spy:
  20. Oct 29, 2019 at 2:05 PM
    #1220
    Brown Bear
    Nor cal
    03 TRD offroad
    Thanks. That white Tundra is stock 4 wheel drive with an iron bull bumper. The fish are actually Lahontan Cutthroat and the last picture is a Brown Trout. I will do a write-up on the bed rack once I get time to finish re-bed lining it and installing the gas Pistons.
    marbleville[QUOTED] likes this.
  21. Oct 29, 2019 at 2:48 PM
    #1221
    marbleville
    Yep, last name too.
    State of Confusion
    Now that you have pointed out my error, I can see the third frame's cut marking, but the others could easily pass for rainbows with their differing markings, spots and otherwise. The last one, the brown, is not common around my locale except for one lake I do not fish because of it being so crowded. We have several alkaline lakes on the east side of the Cascade mountains that are stocked with Lahontans but none that I have fished. In my neck of the woods it's rainbows in lakes, with sea-run cuts, steelhead, and salmon in the rivers, though the steelhead numbers, and salmon, have been seriously depressed for a number of years with little to encourage us steelheaders. Oh, and I almost forgot the Dolly Varden or bull trout in the rivers.
    The white Tundra sure looks small compared to yours, kind of like it is squatting - the bumper and bed load giving it that appearance? Or is your Tundra so high as to give the white one, and mine, a diminutive look? Looks can definitely be deceiving.
    Sorry to hear of your experience with the Dupli-Color bed lining, but the knowledge is beneficial to me as it was one of my finalists for painting my bed, along with Upol Raptor, which now seems to stand alone as my choice.
    I await your write-up, sir. Thanks.
  22. Oct 29, 2019 at 3:15 PM
    #1222
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    Keep them coming, never get old
  23. Oct 29, 2019 at 3:20 PM
    #1223
    marbleville
    Yep, last name too.
    State of Confusion
    Looks like a rough day at the office.:mudding:
  24. Oct 29, 2019 at 4:41 PM
    #1224
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I always thought brown trout was a euphemism for dropping a deuce in the water. :poking:
  25. Oct 29, 2019 at 5:26 PM
    #1225
    marbleville
    Yep, last name too.
    State of Confusion
    The German Brown trout, not indigenous to the US, was brought over in 1883, imported as eggs. Unlike the American species, the brown trout can handle warmer water, and water of a less pristine quality. Some hold it to be a trophy class fish because of their cagey nature and size attainment, while others consider it a predatory nuisance, and detrimental to other trout species.
    MDobb79 and Filthyphil like this.
  26. Nov 3, 2019 at 8:09 AM
    #1226
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Peak leaf change is here in East TN.
  27. Nov 3, 2019 at 9:02 AM
    #1227
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    That surveyors camper is sweet!
    marbleville and Filthyphil like this.
  28. Nov 3, 2019 at 11:59 AM
    #1228
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Never heard that term before. It's an ARE V series off a 2006 DC. What makes it a surveyors camper? The side access windows?
  29. Nov 3, 2019 at 12:05 PM
    #1229
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    I'm taking the family up to TN in two weeks. Can't wait!
    FirstGenVol[QUOTED] likes this.
  30. Nov 3, 2019 at 2:44 PM
    #1230
    FrenchToasty
    Mo
    Bone stock
    I had one similar on a 85 F150, and the guy I bought it from said he used it for his surveying company. I don’t know if that’s really what they are called but it makes it way easier to get stuff out of the front of the bed
