Let's see your first gen - photo thread
Discussion in '1st Gen Tundras (2000-2006)' started by Rkcruza, Jan 6, 2014.
  1. May 9, 2024 at 12:16 PM
    #3811
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Looks great
    beemerphile[QUOTED] likes this.
  2. May 9, 2024 at 12:19 PM
    #3812
    beemerphile
    beemerphile New Member
    Lee
    2006 SR5 Access Cab
    box stock
    Yes, 2WD. So how does one accomplish the -1/-2 setup?
    This is the only one I have scoured up so far...
    https://www.suspensionlifts.com/sho...ring-kit-for-2001-2006-toyota-tundra-2wd-4wd/
    I am sure I could save you the repaint expense. I don't like the look of camper caps vs. tonneaus, but they are extremely useful. I had one on my Tacoma and found it useful.
  3. May 9, 2024 at 12:31 PM
    #3813
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Lowering the front 1" might be a little tricky, but it could be done with the SOS 2/3.5 drop kit and some Bilstein 5100's.
    So the kit is meant to lower the front 2", but if you use the B5100 shocks instead of the B4600 shocks, you have the ability to adjust the front up some. Now don't quote me on this, but I would think whatever setting would normally give you 1" of lift would be the setting you would want to go with, paired with the SOS 2" lowering parts.
    Now the rear I can certainly speak to from experience. If you want to lower the rear 2" you can either try one of those lowering shackles available on eBay and Amazon, or what I did was:
    Install the SOS kit, which is an axle flip kit, but also install an add-a-leaf set for your leaf springs and rear B5100's. That should put you closer to the 2" mark and give you plenty of load capacity.
    bmf4069 and beemerphile[QUOTED] like this.
  4. May 9, 2024 at 12:35 PM
    #3814
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    I assure you, I am a professional.
  5. May 9, 2024 at 12:57 PM
    #3815
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Like the kind that once stayed at a Holiday Inn?
    bmf4069 and BroHon like this.
  6. May 9, 2024 at 1:00 PM
    #3816
    shifty` Goons of Hazzard
    See above comments from assdog on that 1st line.
    On your 2nd line, careful with SuspensionLifts (formerly BilsteinLifts), they really put me thru the ringer, and have screwed over one or two others here.
    RE: Tonneaus/Caps/etc. if you prefer tonneaus, I also have a Bakflip Fibermax (pics), see the 2nd/3rd pic there, I got it cheap, so I'd let it go for half as much as I'd sell my cap.
    RE: Clear bra removal (pics), should be ample info there to do the job. If you need a heat gun and plastic flat blades, I can hook you up. Don't mind helping either.
  7. May 9, 2024 at 1:53 PM
    #3817
    beemerphile
    Lee
    2006 SR5 Access Cab
    box stock
    Thx for all that. I already have a tonneau for it. Too bad I didn't wait, but I didn't.
  8. May 9, 2024 at 3:01 PM
    #3818
    I will say, of those three pics, that 1st one of the tonneau, it kept rain out but it sucked for anything except that and obscuring what was in the bed.
    The 2nd and 3rd pic, of the Bakflip specifically (which I dunno if it's actually a "tonneau" because it's rigid vs. stretched), which is what I have in storage right now, that thing was great. You basically could reclaim all but about 3" of your bed when needed, without removing it. Upside is, it can hold a couple hundo pounds, which made it lay-on-able. Downside is, it covers the back window when folded all the way up to open the bed.
    I've found a few times recently when I regretted having the cap, knowing I have no easy way to take it off, given our housing situation. Like when I went to go get a chest freezer recently, you're not supposed to lay cooler-type things with compressors/oil on their side, or if you do, upright them for 12-24 hours afterward so the oil settles in the system. I needed to help a friend move a washer/dryer and we had to lift up the cap, put them both in, then drop the cap. Getting mulch and soil for the yard/garden is basically impossible with it on now.
    I wish I had a hoist system for the cap. Would make life easier. With the Bakflip, at least I could still do everything I needed/wanted to haul stuff.
  9. May 9, 2024 at 3:13 PM
    #3819
    snoope
    snoope The Old Man
    Here is the Tundra just quietly holding its place...Too Dam hot for anything else...
    95 degrees at 6 pm...
    Voss, Tlar25, The Black Mamba and 3 others like this.
  10. May 9, 2024 at 4:21 PM
    #3820
    beemerphile
    Lee
    2006 SR5 Access Cab
    box stock
    The best arrangement I've had was a high-top cover on my Tacoma. It would have gotten the W/D pair but not the frig. My Ridgeline had the 3-pice hard cover like the Bak-flip. I didn't like that it robbed height in the bed (and it was heavy). The tonneau I have now on the Tundra is a roll-up velcro thing that I"m not real crazy about except that it doesn't rob from the bed height and it gives the full opening when rolled. I may have been the first person here to get a Tundra. I bought a new 2000 Tundra when the first came out. Before that I bought a new T100 when it first came out in 1994. My 2000 Tundra had an Extang Trifecta style cover which seemed often in the way.
  11. May 9, 2024 at 4:33 PM
    #3821
    You may want to throw a "watch" up on this thread. I keep a pretty close eye on camper shells within ~100 miles of ATL and post in there. Here's a shortcut link to watch that thread.
  12. May 9, 2024 at 4:36 PM
    #3822
    You can also do what I did, like here's a truck with the almight windoors on the side camper: You may toss 'em an offer. I threw out a range, "I'll give you anywhere between $300-700 for the cap alone depending on whether it's got cracks, all glass is intact, locks and shocks work, electronics work, if you'll separate", although you may want to toss out $400-$1,000 on that specific one.
  13. May 10, 2024 at 2:52 PM
    #3823
    1stgenRCLB
    1stgenRCLB New Member
    2001 Tundra RCLB v8 4x4
    Attitude Black Raptor lined Bilstein 5100 Leer 100r Enkei Cyclone 16x8
    Beach day with the doggos.
  14. May 11, 2024 at 11:35 AM
    #3824
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Seems like you’ll fit in just fine. Welcome
  15. May 11, 2024 at 11:36 AM
    #3825
    Voss
    2003 AC TRD 4x4
    Nice
  16. May 11, 2024 at 5:28 PM
    #3826
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    265/75r17 M/T Baja Boss AT 17x8.5 -10mm SCS Ray 10’s Bilstein 5100’s 2nd notch
  17. May 11, 2024 at 6:09 PM
    #3827
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Went for a little drive to see if we can get a better view of Aurora Borealis tonight.
  18. May 11, 2024 at 6:29 PM
    #3828
    Might be tougher tonight
    BroHon likes this.
  19. May 11, 2024 at 6:36 PM
    #3829
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Keep us posted. I'm stuck at work and yalls pics of it makes me happy
  20. May 11, 2024 at 6:39 PM
    #3830
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I don't think we were within the ring last night and still saw them. It was surprising. People as far south as Florida saw them.
    455h0le_dachshund likes this.
  21. May 11, 2024 at 6:56 PM
    #3831
  22. May 11, 2024 at 7:32 PM
    #3832
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    I'm in the green zone, nothing yet :notsure:
    Low res but this is what my neighbor saw lastnight.
    Tlar25, Voss, Cpl_Punishment and 2 others like this.
  23. May 11, 2024 at 7:42 PM
    #3833
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    The 2nd most powerful flare of cycle 25 happened last night, those magnetics should be here in a couple days.
    Voss, w666, 455h0le_dachshund and 3 others like this.
  24. May 16, 2024 at 12:11 PM
    #3834
    TøphNDen2
    TøphNDen2 New Member
    2002 Toyota Tundra SR5 Access Cab V8 2UZ-FE 2wd Stellar Blue Pearl
  25. May 16, 2024 at 12:56 PM
    #3835
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Now, paint the starfish gold :D
    BroHon likes this.
  26. May 16, 2024 at 12:57 PM
    #3836
    TøphNDen2
    I have 0 clue what that is
  27. May 16, 2024 at 12:59 PM
    #3837
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Chimi1, Voss, bmf4069 and 2 others like this.
  28. May 16, 2024 at 1:00 PM
    #3838
    TøphNDen2
    Sold. Take all my money
  29. May 16, 2024 at 1:01 PM
    #3839
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Weejub likes this.
  30. May 16, 2024 at 1:14 PM
    #3840
    TøphNDen2
