Let's See Your Caps
Discussion in 'Tonneau Covers, Caps and Shells' started by 650h1, Sep 1, 2017.
  1. May 19, 2023 at 10:22 AM
    #1681
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    That's similar to how the back window was on my last truck, i had that style door but only one handle in the middle. It had a piece of weatherstrip along the bottom that extended over each side an inch or so to cover that gap.
    mista_g likes this.
  2. May 19, 2023 at 11:48 AM
    #1682
    mista_g
    mista_g New Member
    2016 Quicksand TRD Pro
    Yea.I am going to trim some of the stripping that was installed and put a larger one that goes horizontally across the door. just need to take some measurements later.
    _none_[QUOTED] likes this.
  3. May 20, 2023 at 2:16 PM
    #1683
    Fierceblues
    Fierceblues New Member
    Jeff
    2007 Silver Tundra DC 4X4 5.7 six passenger
    ARES Overland Topper, JBL system, sonar, tow package, Tow mirrors, transmission cooler and factory bedliner w/rails.
    My 2nd Gen Tundra DC sporting an ARES Overland topper with two tone color, headliner, dome lights, opening side windows (windoors) & roof rails.0406231303a.jpg0406231303_Burst01.jpg 0406231331.jpg
  4. May 20, 2023 at 2:31 PM
    #1684
    Fierceblues
    Jeff
    My 2nd Gen with the ARE Overland....but windoors on the sides and a slider in between the topper and front cab (with its own slider) so I have a pass through for stuff.
    Tundra805, WVI and fuzzamungus like this.
  5. May 21, 2023 at 10:45 AM
    #1685
    frozentundra22
    frozentundra22 New Member
    Bill
    2003 Red Tundra Limited
    My 1st Gen Tundra Stepside with a Century camper shell. I had to travel over eight hours to rescue this rare shell. I had it painted at Maaco, and a total investment of $1200. I’m pretty happy with it.
    I’m looking to add roof rack to it. Any suggestions? Thanks.DFC14D04-F354-4E64-8734-E4DD02DBF7AC.jpg
  6. May 23, 2023 at 5:51 PM
    #1686
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    I've been tweaking the cap a bit since it was installed. Adjusted the latches on the back window to get it to sit and close better (still a bit of a gap on the bottom seal, against the tailgate in the middle of the window) and adjusting the side windoors to latch more tightly.
    Ran wiring for the little LED light in the cap to work as the OEM cargo lamp. I have some LED strips to install inside as well for camping, they will hot all the time.
    Interesting, it seems on the 18+ trucks, the in cab cargo lamp switch turns off the lights but pulling the ground. The lights get 12v hot all time, just the ground "times out". Makes it nice to only have to run 1 hot wire back.
    Put down a bedrug (the cut your own option, so no cutouts for wheel wells) for the pups and have enough left over to put on the tailgate. All coming together slowly.
    Had a similar setup in my last truck that worked fantastic. Even more room for activities in the Tundra!
  7. May 24, 2023 at 9:43 AM
    #1687
    mista_g
    mista_g New Member
    What's that fan you have propped in the rear slider?
  8. May 24, 2023 at 5:43 PM
    #1688
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Radiator fan used to pull air in the front window to get some airflow for the dogs. Worked well when going slow/stop and go.
  9. May 24, 2023 at 8:57 PM
    #1689
    mista_g
    mista_g New Member
    Nice. How does it mount? Have the brand?
  10. May 25, 2023 at 10:21 AM
    #1690
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    It's just a 14" radiator no-name fan from Amazon. Cheap and worked well, but it pulls a good bit of power. It comes with mounts (to mount to a radiator), i ended up just attaching it to the metal framing around the window. The window could still slide closed behind the fan when it wasn't being used.
    Wallygator, WVI and Fierceblues like this.
  11. Jun 4, 2023 at 5:34 AM
    #1691
    WaterWolfHunter
    WaterWolfHunter New Member
    Yes, mine looks the same on my 21 crew I had installed last week. Honestly, I expected a much better fit on all the windows/doors. I’d pay double for the cap if I didn’t have to now think of ways to engineer the Windoors to properly close all the way so the weather strips fully make contact.
    I'm interested in seeing what you come up with for the tailgate window.
    I posted my cap and build in 2.5 gen forum but here she is:
  12. Jun 4, 2023 at 7:44 AM
    #1692
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    I had to mess with that too. I removed the plastic spacers that are on the windows themselves that sit against the seal. Next you can adjust the latch so as you turn the handle it will pull the windoor in a bit to get a more tight seal. both of mine also had bowed frames at the bottom, so the bottom part of the frame came up in hte middle a bit. Drivers side i just pushed down really hard on to flatten it. Passenger side was up so much it was contacting the windoor. i took out the bottom frame screws and pushed down to get it to lay flat, then put the screws back in, all better.
    All the adjustments take 30 min or so, just annoying to have to do them at all on something that costs so much money.
    I did drive in the rain and wash the truck, no leaks in the cap at least, even with the piss poor tailgate seal. Small victories.
    wolo and mista_g like this.
  13. Jun 4, 2023 at 10:24 AM
    #1693
    HoodRiverTundra
    HoodRiverTundra New Member
    Riley
    Hood River, OR
    2011 TRD Crewmax
    ICON Stage 2, Roadmaster Active Suspension, 46 Gal TransferFlow Tank, 295/70/18 WildPeaks
    2011 ARE Z series with dome and strip lighting. Came with the truck when I bought last year. Great for keeping my gear dry-ish in the rainy PNW
  14. Jun 11, 2023 at 6:06 PM
    #1694
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Finished installing the LED strip lights recently. the small LED light that came with the topper is mounted to the OEM cargo lamp circuit(cargo lamp on the cab bulbs have been removed). These are wired to 12v hot, so they can be on any time. Great for camping, they draw a minute amount of power, so no worries about a dead battery.
    Installed 3 strips. Two on the roof, one on the back door to light the tailgate area. Really pleased with the way it turned out.
  15. Jun 11, 2023 at 6:39 PM
    #1695
    TimS458
    TimS458 New Member
    2012 Barcelona Red TRD Off-road
    I drove 720 miles to pick up a Ranch Camper Shell for $700 today. Needless to say, I'm very happy for what I got! Paint match will come later, I'm just enjoying having a hard shell
  16. Jun 12, 2023 at 6:19 AM
    #1696
    mista_g
    mista_g New Member
    my shell vendor ordered me two new windoors on arrival after I inspected them and said the craftsmanship was doodoo. We will see what shows up haha.
    for that rear gap it’s like dudes, why didn’t you just make the plastic lip wider haha. Easy solution will be get some thicker weatherstripping and attach it to the door with an overhang. Then cut to fit another piece to attach so the exposed isn’t sitting sticky side out.
    or maybe find some dense foam and attach to the corner of the bed there…
  17. Jul 3, 2023 at 11:31 AM
    #1697
    mrmahi
    mrmahi New Member
    2014 Tundra
    Finally got mine done....or about 80%. Gotta replace front clamshell bearing and will resume project.20230522_191157x.jpg
  18. Jul 13, 2023 at 5:44 AM
    #1698
    zoomspeed05
    zoomspeed05 New Member
    marc
    2006 tundra double cab sr5 4WD
    ARE MX Cap with the Vented Windoors
  19. Jul 24, 2023 at 12:27 PM
    #1699
    2scars
    2scars New Member
    RVA
    2013 CM Limited 4x4
    How did you attach the hi lift? Are those just drop down brackets from the bed rail channel?
    Thanks.
  20. Jul 24, 2023 at 12:35 PM
    #1700
    2scars
    2scars New Member
    RVA
    2013 CM Limited 4x4
    Can't find a CM cap anywhere local, so driving 5 hours to pick one up and drive back tomorrow. Doesn't even match, but the price is right. Being limited by my tonneau has been a pain with family camping trips.
  21. Aug 8, 2023 at 9:36 AM
    #1701
    PickupMan2008
    PickupMan2008 Gladys Knight Industries Two Thousand
    Quentin
    Orange City, FL
    2008 Black Double Cab 4x4 5.7
    Cover King seat covers, weathertech rain guards and floor mats NFab Light Bar w/ KC Lights 2010 Limited Grill mod topper bedrug Amazon tailgate handle with rear backup camera still working on mods
    The dealer has this leer cap, paint was peeling so they had it at their house, along with a bed rug. Picked it up after I got the truck and they had 4-5 other caps there, said guys these days don't want caps on their truck and once they remove them, the truck then sells fast. Anyways, free topper and bedrug!
  22. Aug 14, 2023 at 9:26 AM
    #1702
    Tundra1986
    Tundra1986 New Member
    2003 Tundra SR5 4x4
    That color …… really dig it
    zoomspeed05[QUOTED] and _none_ like this.
  23. Oct 11, 2023 at 7:56 PM
    #1703
    bradj1
    bradj1 Ol' Blue
    Salt Lake City
    2018 CM TRD Limited Calvary Blue
    Just added an ARE CX Evolve. Keyless lock, carpet, LED rope lights and roof tracks. Love the look.
  24. Oct 18, 2023 at 1:33 PM
    #1704
    Front Runner - Jolo
    Front Runner - Jolo New Member
    Jolo
    Agoura Hills, CA
    2013 Super White Limited Crewmax
    Fuel Wheels, BF Goodrich KO2, spacer lift, shackle flip, air bags, Cab Rack, TRD Pro Grill, Alpharex Headlights
    SmartCap-like steel shell with my Front Runner Slimline II tray. The shell has the main window in the rear but also has 2 gullwings on the sides. All doors have 2 latches but you can't really open the latches from the inside, which isn't the best since I sleep in my truck bed when I go camping. Still working on a solution for this, but I believe RSI is coming out with a latching system for their shells that can be opened from the inside. I might be able to make that latching system compatible with my off-brand shell.
  25. Nov 13, 2023 at 6:32 AM
    #1705
    AndrewMT34
    AndrewMT34 New Member
    Andrew
    ID
    2017 TRD Pro
    Stage 8 Icon Decked Durobumps U-bolt Flip Kit
    ARE MX on 2017 Crewmax.
  26. Nov 13, 2023 at 6:38 AM
    #1706
    This looks awesome. Good looking setup. #Goals.
    AndrewMT34[QUOTED] likes this.
  27. Nov 17, 2023 at 11:26 AM
    #1707
    packheavy
    packheavy New Member
    Black Rhino Rapids?
    I have been looking at those wheels.
    You have any pics?
    junior[QUOTED] likes this.
  28. Nov 18, 2023 at 3:25 PM
    #1708
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    Yep! 17" with +10 offset on 35s. They've been great and I love the look. They're fairly light and fit great. Here's a pic from today and a few from when I put them on a couple years ago
  29. Nov 18, 2023 at 6:42 PM
    #1709
    packheavy
    Thank you. Looks solid! I'm thinking matte black for my celestial silver truck. I'm surprised there are not more trucks with this wheel.
  30. Jan 4, 2024 at 7:43 AM
    #1710
    drmini
    drmini New Member
    South Carolina
    2000 Tundra AC V8 4WD and 2012 Tundra DC 4WD
    2000 Tundra Mint Condition w/ Glasstite Camper Topper Owned 20 Years
    I'm Looking for a Cap for my 2012 Tundra Double Cab 6.5 Bed I'm in SC near Myrtle Beach anyone have one for sale near me? Thanks
