Let's See Your Caps
Discussion in 'Tonneau Covers, Caps and Shells' started by 650h1, Sep 1, 2017.
  1. Feb 27, 2022 at 7:13 AM
    #1471
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    Have any of you done anything to your rear suspension to reclaim some spring arc and ride height sapped by the weigh of your cap? There is a universal opinion on here that factory leafs are on the flimsy side to begin with.
    A fiberglass cap, snugtop, on my 6.5ft bed weighs what? 200#? 250#? I do have sumo springs, but those don't do anything for an unloaded truck (mine lightly touch the frame)
    I've evaluated blocks, shackles and RAS, none of those resonate with me.
    Given that the cap weight is permanent, I'm wondering if a progressive add-a-leaf isn't the way to go.
    I tow a rented travel trailer a few times a year.
  2. Feb 27, 2022 at 7:26 AM
    #1472
    starfish.pat
    starfish.pat New Member
    Patrick
    2008 Grey SR5 TRD Double Cab Short Bed
    So when I decided to upgrade my rear suspension, I had 9 years on the current one with the cap. I did Icon AAL pack and bought the Torch AAL. Those added about 4 inches of lift with the cap on top, so maybe 5 or 6 inches of lift based on how low mine was sitting over the years. I put the sumo springs in as well when I did the leafs. The Sumo Springs were basically useless because of the 4 inches of spring lift. Eventually I bought a 4 inch spacer meant for airbags and rigged it up to sit between the frame and the sump springs, so now it works out pretty well. If you just want an inch of lift and don't want to waste your sumo spring, you can just put a one inch block in under the springs. If you would prefer some better springs action, you could try just one AAL for 1 to 2 inches of lift and then buy an airbag spacer like I did to mount between the sumo springs and frame. They make different width air bag spacers for different size lifts. There's a million options, for better or worse, and the only way to find out what works best is to try some of them!
  3. Feb 28, 2022 at 4:35 AM
    #1473
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    Only thing I did was add the rear sway bar, plan on doing the front when it warms up.
  4. Feb 28, 2022 at 4:56 AM
    #1474
    starfish.pat
    Patrick
    I have the TRD version, so I never had to experiment without it, but my mechanic brother told me it should help a lot with stability. Not gonna help with squatting of the suspension, unfortunately.
    I did, however, drive without it for a day after I put my new lifted springs in, and I couldn't believe how much more body roll there was in just normal driving. Definitely a good investment if you don't already have one.
  5. Feb 28, 2022 at 4:57 AM
    #1475
    ezdog
    ezdog New Member
    Gateway To The West
    Adding the cap on mine really only made the ride better overall!
    I will likely add rear sway bar for a little better handling but not considering any lift or other mod.
    When I tow, again this just adds to the smoothness usually too.
    Wallygator and Cpl_Punishment like this.
  6. Feb 28, 2022 at 5:20 AM
    #1476
    starfish.pat
    Patrick
    You bring up a good point. When I wasn't towing a fully loaded 10,000 pound trailer. I loved the feeling of the truck overall with stock suspension and a cap. But I had one last trip from Pennsylvania to Florida to move my sister and they loaded my trailer so heavy up front. My truck was frame on leaf spring for most of the ride and every bump felt like I was literally bouncing on the ground. That made me realize I needed to do something with my old suspension if I every wanted a comfortable towing ride.
    In hindsight, I would tell anybody that doesn't want to lift their truck to just get airbags. That way you can tune it to whatever application you need, whenever you want!
  7. Feb 28, 2022 at 5:32 AM
    #1477
    ezdog
    ezdog New Member
    Gateway To The West
    Maybe also make sure that the load is centered over the Axle on the trailer too.
    Everything about heavy or even light towing is improved by properly balancing the load in the trailer in my experience and it also has taken a few bad rides to convince me well enough that I dont forget too!
  8. Feb 28, 2022 at 5:52 AM
    #1478
    starfish.pat
    Patrick
    I'm generally pretty good at loading my truck/trailer. Unfortunately, I did not load it that time. The tongue wait was definitely too high for the trip, but it could have been way better if I just had a better bump stop or airbags, or maybe even fresh leaf springs. Mine were pretty beat from 13 years of abuse, so I didn't mind replacing and upgrading them.
  9. Feb 28, 2022 at 5:55 AM
    #1479
    Retroboy1989
    Northern Utah
    I guess I should have mentioned, I added a TRD sway bar this winter. I like the way it rides/handles. I just don't like that the frame contacts the sumos with no load.
  10. Feb 28, 2022 at 4:14 PM
    #1480
    Wallygator
    Agreed, mine rides better now. I purchased a lift on a sale during Christmas, got the top, and now I don't see the immediate need for it.
  11. Feb 28, 2022 at 4:56 PM
    #1481
    TL TRDPro LR
    TL TRDPro LR New Member
    Troy
    SoCal/Idaho
    2021 TRD Pro Lunar Rock CM
    My son’s latest purchase (smart kid!!)FE61E11C-FD48-46FA-ADDD-2EAF0D44744C.jpg
  12. Mar 1, 2022 at 12:19 PM
    #1482
    bjp
    bjp Hello, kitty……
    Ben
    White ‘21 Double-cab Tundra SR5 w/TRD off-road
    GoFast Camper, TRD skid plate, Valhalla cat plates, LT265/70r18 Nokian Rotiivas, buncha shit under the seat, you know how it is
    These shells weigh just enough to drop the rear an inch or so.
    I also started with Sumo Springs and the TRD sway bar. Didn’t really like the Sumo Springs almost touching when I was in my version of unloaded (come on there is some crap that always stays back there, right?). Wasn’t interested in going full suspension makeover, and I’ve seen several people post about their 2 yr old aftermarket leaf springs going ~flat, nevermind the somewhat harsher ride the heavier leaf springs give.
    I wasn’t sure about the RAS at first, but all I could find ANYWHERE was positive comments, so I gave it a shot. Was a little disappointed I had to pay to have a shop install them; I had anticipated installing them myself. But, when jacked up and supported per the install instructions, there was still a little load on the shackle, and I was afraid I wouldn’t be able to reassemble it after taking it apart.
    RAS gave me almost an inch of recovered ride height. Ride is smooth unloaded, no added harshness at all. I have been very pleased so far. I haven’t had reason to put a bunch of weight back there since adding SS and RAS, but I am expecting a real lack of squat when I have the first opportunity to go get 1500+ lbs of dog food for shelter.
    As for the sway bar, I took it off after I got the Sumo Springs and had decided on RAS. Don’t feel like I miss it at all with my current setup.
    fuzzamungus and KNABORES like this.
  13. Mar 6, 2022 at 2:30 AM
    #1483
    MT Madman
    Hawk Point MO
    I was carrying some stuff for my daughter and her family from their old house to the one they just moved into and noticed the seal from the topper lift gate is damaging the paint on the truck tailgate.
    Does anyone know what I can use to stop it?
  14. Mar 6, 2022 at 5:29 AM
    #1484
    Bradleybb
    Bradleybb New Member
    Georgia
    2021 CM TRD OR
    Transmission cooler TRD REAR SWAY RCI front skid
    Use PPF on my gate 2”
    AggiePhil, TheBeast and Jbehredt like this.
  15. Mar 6, 2022 at 5:35 AM
    #1485
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    I’ve got a strip of ppf there.
    TheBeast likes this.
  16. Mar 6, 2022 at 7:21 AM
    #1486
    Bradleybb
    Georgia
    2021 CM TRD OR
    Thats what I had on my old tundra with ARE Z SERIES ,did the job,
    My current tundra I bought a used AREz , the previous owner cut the seal where it just
    Touching top edge of gate cap, doesn’t touch paint
  17. Mar 6, 2022 at 7:32 AM
    #1487
    Mine is rubbing the paint also
  18. Mar 6, 2022 at 7:39 AM
    #1488
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    I had a strip of linex put there.
  19. Mar 7, 2022 at 2:41 AM
    #1489
    MT Madman
    Hawk Point MO
    Thanks guys, I'll be looking for some PPF.
  20. Mar 13, 2022 at 3:42 PM
    #1490
    TundraRV
    TundraRV New Member
    2021 SR5 SX Double Cab
    Anyone interested in a ARE CX HD topper? (500lbs roof rack weigh limit).
    White
    built in 500lbs. roof rack system
    also includes Yakima track system mounted IN BETWEEN the built in roof rack system (runs north to south on topper)
    6.5' bed
    Carpeted interior
    Slider windows
    locking rear window
    Zero flaws, the truck literally sits in the driveway.
    Send PM if serious.
    Located in New Jersey.
    Flyinryank likes this.
  21. Mar 14, 2022 at 2:41 PM
    #1491
    Retroboy1989
    Northern Utah
    3m paint protection film
  22. Mar 18, 2022 at 11:29 PM
    #1492
    Notlimitedbutclose
    Notlimitedbutclose New Member
    Sam
    Black Toyota Tundra
    Tires, Rims, Lift, color swap, bull bar, camper shell, storage rack.
  23. Apr 7, 2022 at 6:56 AM
    #1493
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    IMG-1680.jpg Finally a member of the MID-RISE club, and love it.
    Henry1jg, Wallygator, WVI and 3 others like this.
  24. Apr 7, 2022 at 6:58 AM
    #1494
    joe_from_iowa
    joe_from_iowa New Member
    Iowa
    2021 Tundra Double Cab SX
    Peeled off the SX stickers from the bed sides. Tyger running boards. A.R.E. DCU topper
    That looks great!! I ended up going with a Softopper due to price and availability of hard shells.
  25. Apr 7, 2022 at 7:30 AM
    #1495
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Went round and round for about 2 yrs and finally decided for new prices of soft topper at 1100.plus tax, found Ranch at 1999. with free x-tras,plus tax . Couldn't pass up the security camping , and traveling of a hard top, for only 1200 more.
    TomC843 likes this.
  26. Apr 7, 2022 at 8:03 AM
    #1496
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    Welcome to the DC Mid-Rise club. Club is just an excuse to post pic.
  27. Apr 7, 2022 at 8:11 AM
    #1497
    Tom,
    What are the specs on that cap and roughly what does that cost?
  28. Apr 7, 2022 at 8:48 AM
    #1498
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    What specs are you asking for? It's a RANCH MID-RISE, sets about 4" above the cab, cap base price was 1999.00,came with choice of 2 free options between, fully carpeted ,6' led light w/auto switch, cargo net, drop down front window w/slider, I took free 6'LED w/auto on when door lifted, and carpeted, pd 100.00 for front window and 100 for cargo net, so total 2199.00 plus tax,
    Henry1jg likes this.
  29. Apr 7, 2022 at 10:12 AM
    #1499
    TomC843
    Tom
    Charleston, SC
    Mine is an ARE MX. Sliding side windows, fully carpeted, fold-down / removable front window, single center rear window latch, and top rails. I paid right at $2200. I got a quote thru ARE website from a local big ARE dealer and took to another small dealer and showed the quote and beat it by a couple hundred.
  30. Apr 7, 2022 at 11:36 AM
    #1500
    Thanks Tom. Thinking about getting that cap. Do the side windows also lift up?
