Let's See Your Caps
Discussion in 'Tonneau Covers, Caps and Shells' started by 650h1, Sep 1, 2017.
  1. Sep 29, 2021 at 3:29 AM
    #1321
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    Thanks. That’s good to know.
    I’m going to add a power lock on my tailgate.
  2. Sep 29, 2021 at 4:08 AM
    #1322
    ezdog
    ezdog New Member
    Gateway To The West
    That piece that overlaps the tailgate is usually just plastic and also usually will just fall off without much effort and hardly a security device at all in fact they call it a Sweep and it is just to keep water out which they rarely really do well either?!
    I also needed a new sweep for a shell and trust me you do not want to have to find and pay for a new one if you dont have to.
    Badknees likes this.
  3. Sep 29, 2021 at 5:32 AM
    #1323
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I used to leave my tailgate and cap unlocked but supposedly tailgates are a popular target for thieves right now.
  4. Sep 29, 2021 at 8:37 AM
    #1324
    Guitarman73
    Guitarman73 New Member
    Casey
    2013 Tundra
    New member here!
    Ordered a Leer 100R cap the other day. I don't see very many people with the 100R, so I'll be sure to post pictures once it is installed.
    I am looking to get a little more height out of the rear end to compensate for any bed sag that might occur. A little rake would be nice.
    Any suggestions?
    I posted a thread earlier with more details on my current setup and what I am considering.
    https://www.tundras.com/threads/fox-2-0-icon-1-5-aal-compatible.95826/
  5. Sep 29, 2021 at 9:37 AM
    #1325
    Badknees
    Badknees New Member
    South Carolina
    Welcome from South Carolina and Congrats on your Leer 100R purchase!
    I like the CB shackles better, but installed a cheaper set of 1.5" shackles that work just fine for now. It only took a short time to install and I can swap up for the CB's later or modify the leaf springs. Seems the AAL leaf spring work might be a little more involved and I'm going to try to keep the shackles and see how they do with the added weight of the XR100 Leer top I recently ordered.
    Guitarman73[QUOTED] likes this.
  6. Sep 29, 2021 at 10:21 AM
    #1326
    Guitarman73
    Casey
    2013 Tundra
    I think shackles are the more practical choice for sure. Fox claims the rear shock is compatible with a 1" lift. So if the cap squats the bed about -.25", it would be safe to run the CB +2 (+1.25"), right?
    I've been searching this forum for a while now, and I can't seem to find anyone with this setup - Fox 2.0 & CB+2, or Fox 2.0 & Icon 1.5 AAL
    Has anyone measured how much the bed dropped once the cap was added?
  7. Sep 29, 2021 at 10:22 AM
    #1327
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    Does anyone know how much a snugtop Supersport weighs? 6.5ft bed.
  8. Sep 29, 2021 at 4:57 PM
    #1328
    Badknees
    Badknees New Member
    South Carolina
    I don’t know about your specific application, but adding extended shackles will increase the movement range between the frame and rear axle. Your bed cap weight won’t have any effect on this range when your rear wheel is at full articulation on either side. Your leaf springs need to limit the rear axle travel before the rear shock piston bottoms out. Unless you get into situations where you are close to full articulation, I doubt you would have problems using the CB shackles.
  9. Sep 30, 2021 at 5:06 PM
    #1329
    16MagSR5
    16MagSR5 New Member
    Buffalo
    2016 Magnetic SR5, leveled and capped
    Boost tow Mirrors, TRD rear sway, Rough Country Duals, Bilstein 5100's, diff breather mod, more that I'm forgetting...
    No, buy a pop and lock, or fab your own. If anything the cap door will be the weak point of the two. Both my cap and tailgate lock with passenger door. WELL worth the time and $.
    Badknees[QUOTED] likes this.
  10. Sep 30, 2021 at 5:11 PM
    #1330
    Badknees
    Badknees New Member
    South Carolina
    Thanks for the advice. The price is a little more, but going to install the OEM power lock this weekend.
  11. Oct 8, 2021 at 11:24 AM
    #1331
    unsub1
    unsub1 New Member
    Steven
    2020 MGM Tundra 4x4 SR5 TRD Off-Road Package, Convenience Package,
    Victory 4x4 sliders, RSI SmartCap, ICI Alumilite front bumper, TRD Pro wheels, Nitto RidgeGrapplers, FrontRunner rack, National Luna DC25 dual battery, X2Power AGM main battery, Cascadia 4x4 hood-mount solar panel, NOCO X2 Pro charger
    I've had my SmartCap a year now and love it. I had it off for a month to have a bed repair done and my life was in disarray. HA!
    Booney, Prostar 190, olds350 and 11 others like this.
  12. Oct 8, 2021 at 11:29 AM
    #1332
    Badknees
    Badknees New Member
    South Carolina
    Congrats. That cap looks perfect on your MGM Tundra. I couldn't quite get there on my 040 Super White though. Maybe they will color match one day.
  13. Oct 8, 2021 at 11:36 AM
    #1333
    unsub1
    unsub1 New Member
    Steven
    Thanks. Yeah, I must admit that I believe the matte black cap looks awesome on everything, but white is pushing it. But still pretty cool to me. It's just a different look. Now that I'm used to it, color-matched ones look bizarre to me. There ARE a number of people out there who have had their SmartCaps color matched at body shops and they're happy with them. I kinda think they can end up looking like a contractor's truck though, if you're not careful. It's a fine line.
    AggiePhil and Badknees[QUOTED] like this.
  14. Oct 8, 2021 at 1:51 PM
    #1334
    ezdog
    ezdog New Member
    Gateway To The West
    You mean it might look too much like you get work done with the truck?
    I just wish they made them for a Long Bed so I could be happy that I dont want to spend that kind of money for a Top!:p
    SAH1 likes this.
  15. Oct 8, 2021 at 2:25 PM
    #1335
    unsub1
    unsub1 New Member
    Steven
    Well, the painted smartcaps I’ve seen look more like some kind of pest control national chain vehicle or something like that. Definitely getting work done but not the look I’m personally going for. To each their own though!
    On the long beds, you’re not the only one. That’s the number one complaint to RSI that I’m seeing.
    On the price, I had specced out some overlanding ARE thing with a better roof capacity, rack track, etc. that was coming in just over $3k the way I wanted it. Was going to require a drive up I35 to have installed and I wasn’t too excited about what I was hearing from the owner between him saying it could damage my bed, it would probably leak, and he REFUSED to paint it matte black for fear I’d return it. He told me to sleep on it before putting down my deposit and that night my buddy sent me the link to RSI and I was sold. At the time they were running a preorder promotion that made it cheaper if you could wait 2 months. And for the work I do, 2 or 3 dudes being able to walk around on top and cut limbs out on ranches is kinda badass.
    AggiePhil likes this.
  16. Oct 8, 2021 at 2:44 PM
    #1336
    ezdog
    ezdog New Member
    Gateway To The West
    I have a bad feeling that if they made one for my LB I might have to jump in too.
    And last week some idiot called it a Dog Catcher top!
    Truth hurts I guess.
  17. Oct 8, 2021 at 3:07 PM
    #1337
    unsub1
    unsub1 New Member
    Steven
    Dude, I cannot imagine the amount of space in that thing. Holy crap!
  18. Oct 8, 2021 at 3:15 PM
    #1338
    ezdog
    ezdog New Member
    Gateway To The West
    Its pretty handy for sure
  19. Oct 10, 2021 at 6:09 AM
    #1339
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    What brand cap is this with the tool boxes?
  20. Oct 10, 2021 at 6:54 AM
    #1340
    ezdog
    ezdog New Member
    Gateway To The West
    It is an ARE DCU Shell.
    Wallygator likes this.
  21. Oct 16, 2021 at 9:42 AM
    #1341
    EPecora
    EPecora New Member
    Evan
    Pennsylvania
    2013 MGM CrewMax Rock Warrior
    Got my Leer cap back from paint today, absolutely in love with it! Now time to figure out my setup for the bed. Thinking about a custom set of drawers.
    1B0FE30E-2210-4AD9-8407-8273CB29935C.jpg 0A007A06-28E4-4864-A9A1-6B1D1987161F.jpg 558EB8C9-EB39-4E77-8AF9-593424C29B75.jpg
  22. Oct 16, 2021 at 1:48 PM
    #1342
    ErikTRDTUNDRA
    ErikTRDTUNDRA New Member
    Erik
    2018 Tundra crewmax 1794
    Ordered my racks for the canopy today, estimated delivery is Nov 20th
  23. Oct 16, 2021 at 7:27 PM
    #1343
    tundraatx
    tundraatx 2008 Limited Double Cab, 5.7L
    Austin, TX
    1) Bought with 225k miles on it, a Westin bullnose bumper, and OEM tundra steps 2) Current Mileage 238k Mods: 1) Dirty Deeds BA Mufflers 8 inch with resonator (as of Feb 2021) - Had the 10 inch with resonator - Prefer the 10 inch without resonator - deeper sound hear it more in the cab 2.) Ranch Hand Summit Front Bumper/Guard 3) Ranch Hand Summit Bumper 4) Billstein 5100s all around 5) TRD front and rear sway bars 6.) Rough Country wheel to wheel steps 7) Pioneer 8400 NEX Wireless ApplePlay 8) Backup Camera: e-raptor 9) LED white lights replaced in headlights, fog lights, inside cabin, and exterior lights 10) Linex (unbranded by Central Texas Truck Coatings) 11) OEM Toyota side panels and generic panel on tailgate Maintenance/Repairs: 1) Valve covers, belt tensioner, alternator belt - $415 2) Evaporation fuel canister and filter replacment $1547 *This was a Toyota TSB for 07-08 AFAIK. Toyota covered in first 3 years of ownership. Mine failed after 13 years of daily regular driving use. Not bad at all. 3) Pioneer Unit - had to ship to Pioneer to replace Output IC - $45 (shipping) free under 1 year warranty fix 4) Pioneer Unit - Electrical feed back coming through speakers when accelerating. Fix was to check all wiring/tighten up/ make connections good again $42. 5.) Rear passenger door actuator replaced. Part was $287 with tax on ebay from Toyota dealer free shipping. 6.) Rack and Pinion, tow mirrors, shocks install, lifetime alignment - $1884.36
    Does anyone know how the build quality of Ranch camper shells are compared to Leer and ARE? It's a Ranch Sierra Extra no damage to interior or windows, original keys included, but so far the buyer threw out a number for $1200...Looks like a higher grade model they make, and it's in excellent condition. I will likely paint it black, and do a round trip of 6 hours for it...
    *** Update ***
    I went for it, it’s a Ranch Sierra Extra with carpet inside and some led lights with original keys in excellent condition. New was about $1900 plus tax a couple years ago.
    Offered $800 and we had a deal. Super nice couple. The seller told me an old timer recommended Ranch as being comparable to Leer and is usually more reasonably priced. the build quality looked excellent upon first impressions.
  24. Oct 19, 2021 at 6:36 AM
    #1344
    Parksareforever
    Parksareforever New Member
    2020 TRD DC 4x4
  25. Oct 19, 2021 at 7:15 AM
    #1345
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Old school Leer from the 90s.
  26. Oct 19, 2021 at 7:47 AM
    #1346
    Refusuck
    Refusuck New Member
    Si Tres
    Arch Cape OR
    2021 TRD Pro
    Boy if I wasn't married that would be my setup. Outstanding.
  27. Oct 19, 2021 at 7:50 AM
    #1347
    Badknees
    Badknees New Member
    South Carolina
    Make the wife sleep in the cab...:D
    Isntthatdandy and Cpl_Punishment like this.
  28. Oct 19, 2021 at 7:59 AM
    #1348
    Fish Chris
    Fish Chris New Member
    I've always thought of shells (or caps) as a great way to make a really big stereo system, using the back window as a blow through, and still be able to keep all your cabin space :) Who needs a bed ? Just get a trailer for utility work.
    But, at the same time, I have been saying I will never own another vehicle that is not at least a Hybrid, if not all electric.... and at least for a while, really strong stereo systems, are kind of at a sticking point... with the dinky little inverters that hybrids are using :( Hoping at some point aftermarket manufacturers start making high powered inverter replacements...
  29. Oct 24, 2021 at 10:06 AM
    #1349
    abonko
    abonko New Member
    Finally got my ARE Z-Series installed after waiting 23 weeks.
  30. Oct 24, 2021 at 12:51 PM
    #1350
    Badknees
    Badknees New Member
    South Carolina
    You’re much more patient than me! But very nice cap and looks great. :thumbsup:
