Let's See Your Caps
Discussion in 'Tonneau Covers, Caps and Shells' started by 650h1, Sep 1, 2017.
  1. May 27, 2021 at 6:54 PM
    #1201
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    I've been wanting to do something similar. I was thinking about a stretch type net, but I'm a little hesitant to unscrew the plastic nuts on the roof where you put your D-rings.
    Did you just use paracord? Where did you find the rings and the net?
  2. May 27, 2021 at 8:00 PM
    #1202
    PNW_Husky
    PNW_Husky New Member
    Great Pacific Northwest
    2018 MGM CM Platinum
    Yep, just shock cord and D rings. Bought them both on Amazon. Unscrew one at a time when you install the d rings and reinstall before you move on to the next.
    PARACORD PLANET Bungee Nylon Shock Cord 2.5mm 1/32", 1/16", 3/16", 5/16", 1/8”, 3/8", 5/8", 1/4", 1/2 inch Crafting Stretch String 10 25 50 & 100 Foot Lengths Made in USA https://www.amazon.com/dp/B06WGLMSNZ/ref=cm_sw_r_cp_api_glt_fabc_ZT7K378TFZ1K1G6B8725?_encoding=UTF8
    MOEBULB Cargo V-Ring Tie-Down Anchors Black Steel Bolton Trailer V-Ring Tie Down for Trailers Trucks and Warehouses Replacement for D-Ring Plastic Flush Mount Pan Fitting Tiedown 8-Pack https://www.amazon.com/dp/B07GZFFZCG/ref=cm_sw_r_cp_api_glt_fabc_CHHWE0AH9VAN8R4FZV32?_encoding=UTF8
  3. May 28, 2021 at 3:56 PM
    #1203
    Tundra Fan
    Toby
    :thumbsup:Thank you sir.
    It looks like it comes in 50ft rolls as well. Should work out perfect.
    Two more questions; What diameter did you go with? I'm leaning towards 3/16. Also, how did you get the ends on yours?
  4. May 28, 2021 at 4:24 PM
    #1204
    PNW_Husky
    I used 1/4 cord so I could use these hooks.
    10 Pcs Bungee Shock Cord Hook for 1/4 inch and 3/16 inch Rope Terminal Ends Tabbed S Open Hooks for Kayaks https://www.amazon.com/dp/B07281THQT/ref=cm_sw_r_cp_api_glt_fabc_ZBD54D074AMG2RTTABRW?_encoding=UTF8
  5. May 28, 2021 at 9:11 PM
    #1205
    Tundra Fan
    Toby
  6. Jun 2, 2021 at 5:50 PM
    #1206
    pyrite808
    pyrite808 Real TRD Pros are built not bought
    Anthony
    Mid Tennessee
    08 DBL Cab Pyrite
    Will definitely be copying this, great idea!
    Here's my progress on the rear bed system, still got lots of work to do. Soktok 100AH Lithium battery showed up
    again here's the original concept for reference
  7. Jun 2, 2021 at 9:12 PM
    #1207
    NomadicFrog
    NomadicFrog Took 5 yrs, finally got rid of "New Member" here
    Mark
    Flagstaff, Arizona
    2003 Tundra SR5 4x4 TRD Off-Road Access Cab
    First mod: Gaffer tape over door lock/unlock beeper
    How are you attaching those panels (like the counter top) to the aluminum extrusion?
    Edit: I'll add some pics of my current extrusion project to make the post / thread a tiny bit more interesting:
    This is version 2.0 of a sort of center console that goes in the middle of the access cab area (seats have long since been removed). Version 1.0 is a couple of plastic storage totes bolted together, with zip ties for hinges at the back. Not ideal.
    There is a large bottom section for tall things like windshield washer fluid, spare oil, etc, then an open tray on top to throw stuff in as needed.
    The sides will be made of 1/4 plywood in the t-slots, held fast with retainers like these orange test pieces I 3D printed. (I could just put the plywood in the slots as I assemble the framework, but I assume that will rattle and drive me bonkers, hence the retainers.)
    Wallygator and pyrite808[QUOTED] like this.
  8. Jun 2, 2021 at 9:48 PM
    #1208
    pyrite808
    Anthony
    Mid Tennessee
    08 DBL Cab Pyrite
    Picked some of these up from Home Depot
  9. Jun 11, 2021 at 11:44 AM
    #1209
    The_Geologist
    The_Geologist I reject your reality and substitute my own!
    Flathead Valley, MT
    2019 Tundra Limited CM Cavalry Blue TRD OR
    Line-X bedliner Century Ultra Topper Thule Rack
    Still waiting on the Thule Tracker rack for my topper (ordered back in February). :frusty:
    Got a call the other day from the dealer saying the parts were in, so dropped off the truck this morning for install.
    When the dealer went to put on the rack this morning, found that the factory failed to send the rails on which the rack attaches to the topper. :mad: Needless to say, I am not pleased.
    Dealer has been great throughout all of this. He's communicated with me frequently and kept me in the loop.
    It's the factory that keeps sending the wrong parts or forgetting parts entirely when they do send stuff. I don't think its so much due to supply chain issues, but feel it is more due to incompetence at the factory. I'm about ready to say the hell with it and go without the rack completely, but then that would be letting the factory off the hook. Dealer said he had no issue refunding that part of what I paid, if I chose that route.
    Dealer said one option would be to take the topper off, send it back to the factory, make them fix it, then send it back here and have it reinstalled. I'm not real excited about that option, especially when it could be months before I'd get the topper back, if at all.
    Now just thinking of what to do...maybe a beer or two will help. :cheers:
    I'm done venting now...:)
    Wallygator likes this.
  10. Jun 12, 2021 at 4:54 AM
    #1210
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I'm beginning to think that ARE had trainees build my cap...
    1. The roof leaked on day one - sealed with Line-X under warranty.
    2. One of the many screws holding the passenger window in place was installed incorrectly.
    I opened the window for the first time about a week ago, and this happened when I shut it.
    I am waiting for a replacement window to arrive.
  11. Jun 12, 2021 at 6:04 AM
    #1211
    ezdog
    ezdog New Member
    Gateway To The West
    If I remember correctly didnt they place a seam right on top of your roof too?
    I have never understood that one at all,no big mystery that it would leak and almost like they just wanted to use extra material to make it instead of one clean new part.
    When I bought my Swiss Top for my 2001 I wanted Windors instead of Sliders and I called the factory and they said I could switch them easily enough if I wanted to drive to the factory.
    So I did and it was closed of course that day bt the foreman was there and said that we could still do it as long as I helped him so I jumped in the bed and away we went.
    After this experience I have no trouble at all imagining the screw that broke your glass,not even for a second.
    I imagined that they used templates to drill and mount the windows properly insuring a plumb and true installation but instead I learned that someone just gets in there and starts self drilling as many screws at random as they see fit as they move around in the bed. If they dont hit a solid place where the screw is drilled they just place a million or so more right next to it until they get a good spot and then just keep ripping through it till they decide it is done.
    Not too inspiring at all.
  12. Jun 12, 2021 at 6:14 AM
    #1212
    Rex Kramer
    Georgia
    Yep, that was the leak they sealed up with Line-X under warranty.
    You can see the roof seam left of center.
    Wallygator and ezdog[QUOTED] like this.
  13. Jun 12, 2021 at 6:25 AM
    #1213
    ezdog
    ezdog New Member
    Gateway To The West
    I never forget someone getting screwed over by the Man!
    Hope they replace the window of course and as you can see it is not a tricky installation or at least shouldn't be?
  14. Jun 15, 2021 at 2:29 PM
    #1214
    Fyshhead
    Fyshhead New Member
    Mark
    Folsom
    2021 Tundra Limited MGM TRD Off Road DC
    Vehicle Modifications:
    What model leer is that and windoors?
    woofhauler[QUOTED] likes this.
  15. Jun 15, 2021 at 2:54 PM
    #1215
    drobb
    drobb The Feral Snail
    2013 Tundra CrewMax 4x4
    64A47466-D30D-49DC-AE94-388E12D92C41.jpg The things you can fit in a CrewMax with the slide down window and a drop down shell window: 14 ft prone paddle board….. and the shell rear hatch closes for the win!!!
  16. Jun 19, 2021 at 12:29 PM
    #1216
    woofhauler
    woofhauler New Member
    Pacifica, CA
    It's the 100XR and their only option for windoors (that I'm aware of)
  17. Jun 19, 2021 at 1:08 PM
    #1217
    jsteph89
    jsteph89 The wish list continues to grow
    Joseph
    South Texas
    2019 Limited 4x4
    Blacked out emblems, Leer 100XL camper shell, Magnaflow exhaust, ProComp 3/1 level kit, 285/55R20 Falken Wildpeaks AT3, WeatherTech mats, full led interior swap,
    I wanted the Windoors on mine but it was another $800. I just couldn’t get myself to spend even more. These things are expensive as it is. Out the door it was already $3,200 if I remember correctly
    Cpl_Punishment and Wallygator like this.
  18. Jun 19, 2021 at 1:54 PM
    #1218
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    That sucks. I would be pissed. This doesn't give me a warm fuzzy as I they are about to ship my A.R.E topper to the dealer.
  19. Jun 19, 2021 at 2:09 PM
    #1219
    Rex Kramer
    Georgia
    At least you know of a few issues to look out for, inspect your new cap before it's installed.
    Booney[QUOTED] and Wallygator like this.
  20. Jun 19, 2021 at 4:29 PM
    #1220
    Booney
    Booney New Member
    Yeah, The dealer said he was going to inspect it before he installed it but I think I am going to hit a high pressure wand type car wash right after I leave the dealer when they install it.
    Rex Kramer[QUOTED] likes this.
  21. Jun 19, 2021 at 11:47 PM
    #1221
    Fyshhead
    Fyshhead New Member
    Mark
    Folsom
    I
    I had issues with my ARE evolve, back wrapped glass door system leaked like a sieve and the latch system got stuck all the time. As for the other windows, they leaked to. I think it was made on a Monday or Friday or maybe by a trainee as well. I fought hard to get my money back after a year in a half of trying to fix it. It went all the way back to their plant and came back with absolutely nothing done to it! The battle was won, dumped the cap and Ford, now stepped into the Tundra world.
  22. Jun 20, 2021 at 2:21 AM
    #1222
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    I 'should' give you some crap being a 65 YO grandpa but I'm one of those who don't give a rats ass.
  23. Jun 20, 2021 at 4:00 AM
    #1223
    Booney
    Booney New Member
    It wouldn't surprise me. I just bought this truck and have already had a big fight just over the title. I hope the topper arrives, gets installed and everyone is happy but it doesn't always happen that way.
  24. Jul 7, 2021 at 12:02 PM
    #1224
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    Just put this on. I still need to wire up the lighting.
  25. Jul 7, 2021 at 12:49 PM
    #1225
    Orracle
    Orracle New Member
    Canton, GA
    Looks great
    Wahayes likes this.
  26. Jul 8, 2021 at 2:42 PM
    #1226
    Orracle
    Orracle New Member
    Canton, GA
  27. Jul 8, 2021 at 2:50 PM
    #1227
    Booney
    Booney New Member
    Looks real nice. Makes me that much more anxious for mine to come in.
    November Sun[QUOTED] likes this.
  28. Jul 8, 2021 at 2:52 PM
    #1228
    Booney
    Booney New Member
    Looks real good.
    November Sun likes this.
  29. Jul 8, 2021 at 3:09 PM
    #1229
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    Looks great! Thanks for the pics. I’m on week 13 waiting for mine.
    Fyshhead likes this.
  30. Jul 8, 2021 at 4:35 PM
    #1230
    jsteph89
    Joseph
    South Texas
    2019 Limited 4x4
    I’m glad I got mine just before all this. Mine took 3 weeks to come in
    Cpl_Punishment and Fyshhead like this.
