Let's See Your Caps
Discussion in 'Tonneau Covers, Caps and Shells' started by 650h1, Sep 1, 2017.
  1. Apr 6, 2021 at 5:41 PM
    #1141
    ezdog
    ezdog New Member
    Gateway To The West
    You can not just blame this one on the Cap though?
    This truck is full on pappy either way to me.
    AggiePhil likes this.
  2. Apr 6, 2021 at 8:37 PM
    #1142
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    This is awesome on So Many Levels !
    Totally made My Day !
    Thank you Sir !!!!
  3. Apr 6, 2021 at 9:16 PM
    #1143
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    Kinda reminds me of a trucker's cap
  4. Apr 7, 2021 at 6:30 PM
    #1144
    The_Geologist
    The_Geologist I reject your reality and substitute my own!
    Flathead Valley, MT
    2019 Tundra Limited CM Cavalry Blue TRD OR
    Line-X bedliner Century Ultra Topper Thule Rack
    That squarebody is badass on so many levels, though.
    Similar to a Cheyenne that my dad had when I was a kid.
    Wallygator and Cpl_Punishment like this.
  5. Apr 14, 2021 at 10:45 PM
    #1145
    woofhauler
    woofhauler New Member
    Pacifica, CA
  6. Apr 15, 2021 at 7:01 AM
    #1146
    ErikTRDTUNDRA
    ErikTRDTUNDRA New Member
    Erik
    2018 Tundra crewmax 1794
    Do you have any photos of how you mounted the rack to your cap? I have been thinking about picking up a rack but my cap doesn’t have mounting rails.
  7. Apr 15, 2021 at 8:16 AM
    #1147
    dkrou
    dkrou New Member
    dan
    2019 tundra
    That will create some challenges since I believe most rails are factory installed....I for one wouldn't attempt that myself. You might check with the brand /local cap dealer and see if they can retro install rails for you. That is a much bigger deal than putting the rack on the rails...I have an ATC cap and had Rino rails factory installed and later put a UPtopOverland rack on that. Most rails can marry up with almost any brand of rack but screwing through that cap and doing it straight and preventing leaks is not for the faint of heart. Like I said I wouldn't attempt it myself....
  8. Apr 15, 2021 at 8:36 AM
    #1148
    woofhauler
    Pacifica, CA
    The rack is meant to be installed on rails. like @dkrou said I wouldn't attempt drilling. Getting rails added to a topper should be easy and cheap for any topper dealer.
    Here's some photos as requested.
  9. Apr 15, 2021 at 9:22 AM
    #1149
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I just talked to my topper guys they do it all the time...its about two hours of labor plus the cost of the rails.
  10. Apr 15, 2021 at 11:10 AM
    #1150
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Super easy to do. just take your time. Get a roll of blue masking tape to mock-up where you wanna mount them. Take a 6 foot ladder and get up on it from a ways away to make sure you got it straight. Do this from the front and back. Measure, measure, and re-measure . . . then triple check it with your eyes from on top of the ladder. I did it on a new Snug Top years ago on a truck that had an 8 foot bed.
    Just tape the mounting hardware down when you mark the holes. (keep them separate and mark them passengers/drivers side front/back . . . sometimes they aren't exactly the same) . . . . depending on the hole size, you can drill a pilot hole 1st if you like.
    Another thing you can do is get a tube of 3M 5200 or 4200 marine sealant and put some in the hole, around the hole, and on the bolt before installing, this will prevent leaks. (Don't use silicone, the stuff is crap for this and won't stick).
    If you wanna make life Super Simple, dry fit it first with a couple bolts, then mask-off the entire area, that 5200/4200 is a snotty mess. Have a can of acetone and a roll of paper towels handy to aid in clean-up.
    Oh yeah . . . that 5200/4200 will likely leak, spill down into the bed through the bolt holes, so either put a drop cloth in there, are have someone with a rag down there catching/wiping the goop. Don't be stingy with the sealant, you'll be 100% waterproof.
    Lastly, mine came with some cool red rubber screw covers for the inside to prevent you from gashing your skull if you ever knock your head inside the shell . . . . trust me from experience, they are worth their weight in gold.
    It's super easy to do, and you can place it exactly where you want it . . . save yourself some dough, and it's kind of a fun project.
    RNDABOUT and woofhauler like this.
  11. Apr 15, 2021 at 12:59 PM
    #1151
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    I just bought a Prinsu and I'm waiting to get my extra crossbar before I put it on. I might be wrong, but are your sides upside down? Isn't that hole in the first photo supposed to face up so you can mount crossbars vertically on each end?
    It probably doesn't matter either way if you're not using a vertical crossbar.
  12. Apr 15, 2021 at 2:38 PM
    #1152
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    HB Tundra is right on track. Take your time and DIY and I bet you'll do a much better job than any of the "Tech's" at the dealers shop.
    Also, if you decide to go the 3M 5200 route, you could stick those tracks on without using bolts, if you really wanted to (caveat: Depending on what you're going haul up there, I might use one bolt at each end of the track, just in case). I use 5200 on my boat where I don't want to drill holes to mount stuff and those items are going NOWHERE. That stuff is freaking awesome.
    Here's a couple of examples.
    Used it to glue this solar cable gland to the roof of the boat because I didn't want to drill thru the top. Ain't going nowhere.
    Also used it to glue mahogany strips to the inside of the cabin (at the top) to mount things to. Again, ain't going nowhere.
  13. Apr 15, 2021 at 2:52 PM
    #1153
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    I installed my Yakima myself. Not too hard, measure twice and cut once. Using painter's tape is a good idea, I used a dry erase marker. If you have an ARE, pay attention to the thickness change inside to avoid landing on a slope. I used the sealant that came with the rails, but 5200 would be awesome. It is strong and permanent. Like @Taco-Bender said, you could probably use it to affix your rails, but as good as it is I've never trusted just an adhesive for something I don't want to come loose, like my rack with a cargo box and awning on it. But you could reduce the holes to two per rail and use the 5200 under the rest of the rail.
    woofhauler likes this.
  14. Apr 15, 2021 at 2:57 PM
    #1154
    dkrou
    dkrou New Member
    dan
    2019 tundra
    After reading all of this and getting the HD roof that is rated for 900 lbs...see photo for interior drawer set up I'm sure glad I got rails installed at the factory.
    GAknight and waj30 like this.
  15. Apr 15, 2021 at 3:39 PM
    #1155
    woofhauler
    Pacifica, CA
    I put it together per the instructions which show the flat side facing up (bump side down)
    https://prinsudesignstudio.com/wp-c...-Rack-Installation-Instructions-9-27-19-4.pdf
    holes might be for an awning? not sure exactly what they're for.
  16. Apr 16, 2021 at 8:41 AM
    #1156
    sbxx312
    sbxx312 New Member
    You're right. Thanks. I watched a youtube video where the dude said it was for a vertical crossbar. Seemed logical because you could box off either end, which is what I was planning on doing.
    I called Prinsu and the extra holes are for an o-ring mount, not a crossbar.
  17. Apr 26, 2021 at 7:26 AM
    #1157
    RepeatPete
    RepeatPete New Member
    Pete
    2008 Tundra SR5
    Anyone have any advice for traveling with the shell door open? I use a tailgate pad for bikes and drive with the door open, but can see it bouncing in the sideview mirror. The gas strut mounts are bending every time the window bounces, and I think in the long run they will break from fatigue. I used to bungee it down, but the new gas struts are too strong for that.
  18. Apr 26, 2021 at 8:32 AM
    #1158
    wvtriple
    wvtriple New Member
    2010 Super White RW CM
    After searching for about 4 months I found this ARE V series for a steal at $450. I was surprised he wanted so little considering it did have a few options, the full tilt down front window, roof tracks, and heavy duty dog screen.
  19. Apr 26, 2021 at 8:46 AM
    #1159
    irishpride114
    irishpride114 New Member
    Travis
    2015 SR5 TRD Double Cab
    I would be afraid of hitting a bump and eventually shattering the glass. You might look into a hitch mounted carrier
    ja36260, TheBeast and AggiePhil like this.
  20. Apr 26, 2021 at 9:04 PM
    #1160
    ErikTRDTUNDRA
    Erik
    Great advice everyone, it’s much appreciated. I will update if I pull the trigger on some rails and a rack . Y’all convinced me to DIY it
  21. May 6, 2021 at 8:24 PM
    #1161
    Forkhunter
    Forkhunter New Member
    2018 DC Limited
    4 months later my ARE got installed today. I am function over form these days. I am really excited about the extra room inside from the mid rise canopy.
  22. May 6, 2021 at 10:02 PM
    #1162
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    welcome to the MX club.
  23. May 7, 2021 at 7:55 AM
    #1163
    RNDABOUT
    RNDABOUT New Member
    17 Quicksand TRD Off-road
    i looked! I cudn't find the club! please point me to it!
    TomC843[QUOTED] likes this.
  24. May 7, 2021 at 8:28 AM
    #1164
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    ACAE60A6-5B7E-4C71-A5B9-E085C8D4DB8B.jpg Here’s mine
  25. May 7, 2021 at 8:33 AM
    #1165
    RNDABOUT
    RNDABOUT New Member
    more pics please.
    howz the fitment?
  26. May 7, 2021 at 8:39 AM
    #1166
    ScenicRoute
    Fits good. A lot better in person than it looked on pictures I saw before I got it. But it was gonna be more about function than form. I was also going to have it color matched but decided to keep with the black and remove the stickers.
  27. May 7, 2021 at 8:44 AM
    #1167
    hotchops777
    hotchops777 New Member
    Matthew
    EAST TEXAS
    2011 5.7 Silver Sky DC
    6" Procomp Stage 2 lift Black Rhino Sierra 20x10 0 offset on 325x65x20 Nitto Ridge Grapplers Smitty Built M1 front grill
    Can we please see inside pictures or video of functionality? Looks amazing friend!
  28. May 7, 2021 at 9:05 AM
    #1168
    ScenicRoute
    Sure I’ll take some this afternoon. I think the fit is pretty good to the shape of the rear of the cab.
    Wallygator and jhardy1979 like this.
  29. May 7, 2021 at 9:42 AM
    #1169
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    Did you look at the contractor version of their cap? Not sure how different it is but its white and a few dollars less than the one you have.
  30. May 8, 2021 at 8:59 AM
    #1170
    ScenicRoute
