Let's See Your Caps
Discussion in 'Tonneau Covers, Caps and Shells' started by 650h1, Sep 1, 2017.
  1. Mar 25, 2021 at 5:16 PM
    #1081
    Wahayes
    Wahayes Older I get the wiser I realize my dad was
    Will
    2017 tundra limited
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    Not exactly like it but similar to this
  2. Mar 25, 2021 at 6:15 PM
    #1082
    The_Geologist
    The_Geologist I reject your reality and substitute my own!
    Flathead Valley, MT
    2019 Tundra Limited CM Cavalry Blue TRD OR
    Line-X bedliner Century Ultra Topper Thule Rack
    I heard a rumor today that my Century topper might have come in earlier than predicted :monocle:. Will find out for sure when I go to the dealer tomorrow. The anticipation is building! :yay:
    junior likes this.
  3. Mar 25, 2021 at 8:54 PM
    #1083
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    I'm going to need to rig something to my garage ceiling. My cap is very heavy; it takes 4 people to lift it with enough control not to tweak it or scratch the truck. I'm also just now realizing that weight cuts into my payload/tongue weight for summer adventures :monocle:. I wouldn't mind pulling it for the summer just to run something different until winter roles around.
    I also have the overhangs down both sides that are not meant to support the cap's weight so it will need to rest on a frame built specifically for the purpose.
  4. Mar 25, 2021 at 9:00 PM
    #1084
    Wahayes
    Will
    2017 tundra limited
    I wish I had a picture of my old setup, it's hard to explain but worked great. The key was I had two boards that were over length with eye bolts bolted on the 4 corners. I attached cables to both ends of eye bolts on either side and then put the cables in the hook of the hoist. Once I got it lifted all the way up I then secured it with two additional ratchet strap to the ceiling supporting the top where I had mounted additional eye bolts. That way if one system failed the other would support it.
  5. Mar 26, 2021 at 7:45 AM
    #1085
    Retroboy1989
    Northern Utah
    Thinking of using the original shipping boards to protect the overhang, then setting it on something like the guy in this video.
    https://youtu.be/9dCg5hZCtAI
  6. Mar 26, 2021 at 8:41 AM
    #1086
    Wahayes
    Will
    2017 tundra limited
    Yep that's exactly what I'm talking about :thumbsup: and yea with the overhang you'd have to have something additional to protect it. I just would not go with the junky strap set up he's got going on there . Definitely use a hoist either manual or electric and support with straps once up
    AggiePhil likes this.
  7. Mar 26, 2021 at 8:56 AM
    #1087
    Wahayes
    Will
    2017 tundra limited
    Also just to be on the safe side don't use those little pull straps like this dude. I use legit ratchets and it may be overkill but mine are 1000lbs rated CAT straps. Better safe than sorry when dealing with a 2500-4000 dollar cap
  8. Mar 26, 2021 at 10:44 AM
    #1088
    The_Geologist
    Flathead Valley, MT
    Well, the rumor was true! My topper did come in. So the Tundra is at the shop getting the topper installed. Can't wait to see what it looks like!
    And yes, I was quoting myself!
  9. Mar 26, 2021 at 10:50 AM
    #1089
    Wahayes
    Will
    2017 tundra limited
    Makes sense as century is made by leer, and my leer just came in 3 weeks early too
  10. Mar 26, 2021 at 3:08 PM
    #1090
    Wahayes
    Will
    2017 tundra limited
    Only picture I have so far , I'm still at work...... looks great though
  11. Mar 26, 2021 at 6:00 PM
    #1091
    Retroboy1989
    Northern Utah
    Recommendations on a hoist setup? Manual is fine as this will not be a regular activity.
    Ratchet straps aren't really designed for lots of travel. I'm looking at needing 5+ feet of uptake. I could see ratchet straps a a viable options for extra security once in place :thumbsup:
  12. Mar 26, 2021 at 6:09 PM
    #1092
    Wahayes
    Will
    2017 tundra limited
  13. Mar 26, 2021 at 6:21 PM
    #1093
    ezdog
    ezdog New Member
    Gateway To The West
    I use a chain hoist and nylon slings just like I do when hanging giant TVs in Sports Bars so I already had all the stuff.
    https://www.liftingequipmentstore.u...nQkuM6FN_JEyguKVujthyFtxlUO8zTjcaAk-YEALw_wcB
    https://www.liftingequipmentstore.us/product/green-round-sling-5300lbs
    You can get a hoist in any fall distance that you need and they make easy work of the heaviest lift really.
    Round slings are great for wrapping the cap for lifting or lifting 2. lumber for the lift depending on your setup.
  14. Mar 26, 2021 at 6:40 PM
    #1094
    Wahayes
    Will
    2017 tundra limited
    If you're going to be lifting more than just your cap and need the weight capacity, the chain hoist is the economical way to go.
  15. Mar 26, 2021 at 10:01 PM
    #1095
    Wahayes
    Will
    2017 tundra limited
    Just got her home
  16. Mar 27, 2021 at 5:16 AM
    #1096
    ezdog
    ezdog New Member
    Gateway To The West
    If you already have one and all else needed to use it the chain hoist is the way to go too!
    It is not just the economics of it all but chain hoists are pretty useful in a lot of ways once you have one and do not require power outside of your arm too.
  17. Mar 27, 2021 at 5:36 AM
    #1097
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
  18. Mar 27, 2021 at 5:42 AM
    #1098
    ezdog
    ezdog New Member
    Gateway To The West
    Great Minds for sure!
  19. Mar 27, 2021 at 8:05 AM
    #1099
    parkerbows
    Jack
    nice
  20. Mar 27, 2021 at 8:16 AM
    #1100
    ezdog
    ezdog New Member
    Gateway To The West
    $100 nice!
  21. Mar 27, 2021 at 8:24 AM
    #1101
    Mickale
    Mickale New Member
    2008 Silver Tundra Limited
    A fucking lot.
  22. Mar 27, 2021 at 10:39 AM
    #1102
    Wahayes
    Will
    2017 tundra limited
    You get it done yet? Let's see pics!
  23. Mar 28, 2021 at 10:51 AM
    #1103
    tbou
    tbou New Member
    Taylor
    21 Cement DCLB
    Ahh, sorry, just saw this. Yep! I have the full rear door going on this next week. Some parts were backordered with an unknown ship date, so they shipped it with the half(regular) door, but the tailgate's coming off shortly!
  24. Mar 28, 2021 at 11:10 AM
    #1104
    ezdog
    ezdog New Member
    Gateway To The West
    Thanks for answering I just couldnt imagine what you were saying otherwise?
    Is it a single door that opens upward or French Doors like mine?
    WVI likes this.
  25. Mar 28, 2021 at 12:56 PM
    #1105
    tbou
    tbou New Member
    Taylor
    21 Cement DCLB
    The single door, or ARE calls it their "walk in door" (https://www.4are.com/product/walkin/). I'll be sure to take pics once it's on. I mostly use my truck as a hunting/fishing camp, and with a dog, walk in door gives a little easier access in and out than the tailgate. I'm also keeping the door that's on now, so I can switch back to the tailgate/half door if I need it.
    ezdog[QUOTED] likes this.
  26. Mar 29, 2021 at 11:14 AM
    #1106
    The_Geologist
    Flathead Valley, MT
    It did get installed Friday, but I didn't get on the computer over the weekend. :anonymous: I will post some pics this evening after I get home from work.
    Unfortunately, the factory screwed up and forgot the Thule racks I ordered for the top. :frusty:
    The dealer was going to check in with them today and see what happened (it was too late on Friday afternoon to do so then). I'll eventually have to go back a second time for that install.
    EDIT: Here's a photo.
  27. Mar 29, 2021 at 6:12 PM
    #1107
    tundra121
    tundra121 New Member
    Truck looks good!!!
    I was planning on Racks by Thule but they are on back order so I switched to Yakima rack instead. Installed them on the weekend cost was only $40 more than Thule IMG_3707.jpg
  28. Mar 29, 2021 at 6:34 PM
    #1108
    biebs96
    PA
    what state are you in? I saw an MGM zone for sale by me. And you have my color... hmmm
  29. Mar 29, 2021 at 8:14 PM
    #1109
    ErikTRDTUNDRA
    ErikTRDTUNDRA New Member
    Erik
    2018 Tundra crewmax 1794
    Anyone have any input, advise, pictures, cost for racks for caps ?
  30. Mar 29, 2021 at 8:38 PM
    #1110
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    Do you mean adding a rack to a camper shell/ Truck cap?
