Let's see those Lawnmowers
Discussion in 'Home Improvement' started by Bob, Mar 22, 2017.
  1. Oct 3, 2023 at 8:43 AM
    #211
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    I have a few steep spots where these new tires are still a bit sketchy, especially if the grass is tall and slippery, but honestly I should be doing those areas with the weed Wacker anyway. I can definitely go much steeper than with the stock slicks. Overall the traction has improved by more than double. The only down side is that I leave gouges here and there. Once I get all the mowed areas graded properly I'll likely go back to a less aggressive tire. I only need these to get me through while everything is still rough.
    But yeah, huge improvement in traction.
  2. Aug 28, 2024 at 6:45 AM
    #212
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I wanna do this to my mower so bad...
    Then convince my neighbor to do his like Buford T Justice's car and book it down the neighborhood streets
    Bought2Pull and Ponderosa_Pine like this.
  3. Mar 10, 2025 at 8:24 PM
    #213
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Had a flat while mowing the back yard today. Instead of just plugging it, I decided to use the AT tires pulled off my golf cart since they were the same wheel size. The stock rubber kept peeling out/spinning on wet grass so killed 2 birds with 1 stone.
    Also, turned her into a Big Booty Judy. These balloons raised me up some - my normal blade height was at 3 and now I have to run it at 2 :laugh:
    PXL_20250310_211738561.jpg PXL_20250310_212028552.jpg PXL_20250310_212024787.MP.jpg
  4. Apr 10, 2025 at 5:53 PM
    #214
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 SR5
    its that time of year again...
    Buildn and NewImprovedRon like this.
  5. May 17, 2025 at 8:31 AM
    #215
    Mdnitedrftr
    Mdnitedrftr TAKITEZ
    Rich
    NW, CT
    '21 1794
    I want a set of tires like that for my XT2.
  6. May 17, 2025 at 2:19 PM
    #216
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    A Hustler Raptor XL
    54” Zero-Turn
    23 hp Kawasaki Engine
    NewImprovedRon and oddhours like this.
  7. Jul 25, 2025 at 9:59 AM
    #217
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    Wow! Had no idea there was such a thread!
    I'll have to get the wife to take some pics (I have no functioning camera) but right now we mow with two Toro zero-turns, a 60 inch and a 50 inch cut. We also have a Husqvarna 48 inch cut riding mower with tire chains we use on hills.
    Main mower still a Troy Bilt TB 230 self propelled.
    Pics inbound.
    Leo's first likes this.
  8. Jul 25, 2025 at 12:13 PM
    #218
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    21” Toro Commercial. Basically a Super Recycler on steroids.
  9. Jul 25, 2025 at 1:44 PM
    #219
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Push or self propelled?
    If the latter, front or rear wheel drive?
    We do fine with the TB 230 but I think mine is having some fuel feed issues. She'll miss on a hill if the fuel tank is on the downhill side.
  10. Jul 25, 2025 at 2:19 PM
    #220
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
  11. Jul 25, 2025 at 5:31 PM
    #221
    Danman34
    Danman34 New Member
    Danny
    Self Propelled. Rear wheel drive. 3 speeds. Transmission on it is built like a tank. From a lawnmower standpoint. She’s got some weight to her. 125 lbs. But you don’t even feel the weight with the gears and it also helps preventing the mower from bouncing, so it leaves that carpet like cut. Literally has a diff cover with metal fins to pull heat off. Tires are also a soft rubber compound as to not damage grass.
  12. Jul 25, 2025 at 5:36 PM
    #222
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Nice machines, we use them at work
    Cheaper than Honda's almost as durable
    Edit; Use pure gas no ethanol if possible
    NewImprovedRon and Bought2Pull like this.
  13. Jul 25, 2025 at 5:55 PM
    #223
    Danman34
    Danman34 New Member
    Danny
    Only thing that ever gets used in any of my lawn equipment, 2 stroke or 4, is 93 non ethanol. Haha
    woods and Bought2Pull like this.
  14. Jul 25, 2025 at 6:53 PM
    #224
    M14 EBR
    M14 EBR Oh No, Rex Kramer!
    This 20 year old Stanley is in the shop right now, I think it needs a carburetor.
    I'll keep it as a back up to the Troy Built and use it as a brush cutter.
    This 15 year old Honda powered Troy Built is my current go-to push mower.
    I replaced some carburetor parts, but it still surges a bit.
    It will go to the shop if/when the Stanley is running reliably, or during the winter.
    My 15 year old Husqvarna tractor just returned from the shop last Friday after a full service including new tires, this will keep me from pushing the Troy Built as much as I had been this season.
    In my youth I worked on a golf course using all sorts of grass cutting machines and I also worked for a lawn maintenance company ... I have had my fill of cutting grass, this is why the size of my "lawn" that requires maintenance is continually shrinking.
    oddhours, Leo's first and Bought2Pull like this.
  15. Jul 25, 2025 at 7:04 PM
    #225
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Nice, thank you. A bit heavy for the wife and I to lift into and out of the Tundra's bed in case we were out without the trailer (which we still are sometimes). We still have our ramps though. How much that baby put you back?
    I use 87 non ethanol in all my mowing machines with 93 octane non ethanol for the 2 stroke mix. Seems to be working fine, even without cutting off the fuel flow and running the carb bowl dry at season's end.
  16. Jul 25, 2025 at 7:30 PM
    #226
    Danman34
    Danman34 New Member
    Danny
    $2,000
    Bought2Pull[QUOTED] likes this.
  17. Jul 25, 2025 at 7:34 PM
    #227
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    I figured it'd be something like that.
    Thanks. :)
  18. Jul 26, 2025 at 7:19 AM
    #228
    Petro
    Petro New Member
    2019 Tundra SR5 TRD OR Crewmax
    Bought the Cub Cadet LT 46.
    Got it for a couple hundred less by driving from northern Twin Cities into Rice Lake, WI.20250726_091122.jpg
    oddhours likes this.
