Let's see those Cement Tundras
Discussion in 'General Tundra Discussion' started by Max Power, May 8, 2018.
  1. Apr 24, 2019 at 7:22 AM
    #271
    Cement
    Cement ...
    2019 Cement Trundra TRD
    Phase 2 complete
    GODZILLA, TX87hauler, 2chains and 3 others like this.
  2. Apr 24, 2019 at 7:59 AM
    #272
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Heavy, unnecessary offroad stuff.
    Which winch did you go with? Lookin' good, BTW.
    Cement[QUOTED] likes this.
  3. Apr 24, 2019 at 7:59 AM
    #273
    Cement
    Cement ...
    Thanks! I settled on the Warn VR10S.
    sdde4n[QUOTED] likes this.
  4. Apr 25, 2019 at 6:14 AM
    #274
    sdde4n
    sdde4n New Member
    Since we're sharing...
  5. Apr 26, 2019 at 8:37 AM
    #275
    Celt
    Celt New Member
    NY
    2019 Crewmax TRD/OR Cement
    Do you have a side profile pic? Id like to see how the rubber improves the look of the stock wheels.
  6. Apr 26, 2019 at 8:34 PM
    #276
    Cemented
    Cemented Function over Form
    Manuel
    2017 Cement TRD Pro
  7. May 1, 2019 at 5:02 AM
    #277
    sdde4n
    sdde4n New Member
    Here’s a few shots taken at T2S. Turns out Cement looks pretty good surrounded by AZ colors.
    Photo credit to @Bannock452 — dude knows his stuff with photography too!
    EE653010-E532-4BD6-A6CF-AAD6A0D8C17C.jpg DF540A93-669C-4025-8F8D-CDA1FCDBF48F.jpg C730490D-96BD-49CE-8344-6B5036A4FC6C.jpg 0B4C1F18-4FC9-4CCF-AFFE-264CAAD00690.jpg
  8. May 1, 2019 at 5:05 AM
    #278
    Pmoore849
    Pmoore849 New Member
    Patrick
    2012 silver sr5 4x2
    What rack is that?
  9. May 2, 2019 at 7:28 PM
    #279
    2chains
    2chains New Member
    Southern Ablerta
    Here's mine bone stock at the moment
  10. May 2, 2019 at 7:46 PM
    #280
    Blueknights75
    Ron
    Clayton, NC
  11. May 2, 2019 at 10:17 PM
    #281
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    New wheels and tires. Came from vtx 18" on 35s, now 17s and 37s
  12. May 3, 2019 at 9:24 AM
    #282
    sdde4n
    sdde4n New Member
    Dara, sweet looking wheels. Hey, I'm noticing most guys with 37s have glass fenders. How difficult was it to fit those big dogs under there on stock fenders (you're still on stock fenders, right)?
  13. May 3, 2019 at 9:28 AM
    #283
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    I need to know this also.
    joonbug likes this.
  14. May 3, 2019 at 11:09 AM
    #284
    Kurdt
    Kurdt New Member
    Austin TX
    2019 Cement CrewMax TRD OR
    Thought I'd post an update of my truck since I bought it 2 months ago. Added 6112's up front at 1.9" and got rid of all the chrome, including powder coating the wheels and front/rear bumper caps.
  15. May 3, 2019 at 3:07 PM
    #285
    sdde4n
    sdde4n New Member
    If anyone ever has a chance to get a picture of a cement '17 Pro next to a cement '18 or '19 (non-pro, er, amateur?), could you post it here, please? Word on the street is that there is a very subtle difference in the cement colors between pros and nons. I'd like to see it for myself. Thank you in advance.
    GodlessPro likes this.
  16. May 3, 2019 at 3:25 PM
    #286
    GodlessPro
    Matthew
    NorCal
    If you look at a pro grill on an '18 or '19 you can see that there might be a difference.
    I have a picture somewhere of both of my trucks.
  17. May 3, 2019 at 3:32 PM
    #287
    GodlessPro
    Matthew
    NorCal
    Not a great comparison because of the lighting and dirt. If there is a color difference it is greatly exaggerated in this picture.
  18. May 3, 2019 at 3:37 PM
    #288
    booyaa
    booyaa New Member
    Pro:
    Screen Shot 2019-05-03 at 5.26.19 PM.jpg Screen Shot 2019-05-03 at 5.26.01 PM.jpg Screen Shot 2019-05-03 at 5.26.31 PM.jpg
    TX87hauler and Watt maker like this.
  19. May 3, 2019 at 3:41 PM
    #289
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Looks BA man!!! Have any more pics of those chain wheels???
    booyaa[QUOTED] likes this.
  20. May 3, 2019 at 3:45 PM
    #290
    booyaa
    booyaa New Member
  21. May 3, 2019 at 3:57 PM
    #291
    seniramsu
    Nate
    VA
    Those are some good looking rims!!!
  22. May 3, 2019 at 4:00 PM
    #292
    booyaa
    booyaa New Member
    not cement but....
  23. May 4, 2019 at 8:25 AM
    #293
    5.7TRDProm
    Dara
    Thanks @sdde4n ! There are a few guys that are running 37s without glass fenders, most of them are probably with glass fenders because of going with the LT setup. I took a lot of reading and visualization on the wheel well and clearance after @KevinK posted his thread a long time ago in regards to fitting 37s without going glass. Only difference that made his and some others a bit easier are the offset of the wheels, I took a dice gamble and went a bit on the negative side of the offset from the brand of the wheels. Supposedly an offset between +25 and +10 is where you would want to be.
    I did a really extreme BMC where the flange of the bolt for the body mount got shaved, caster is the trick and what KevinK and Oside also mentioned is heims UCA to get a bit more caster and also correct the camber from excessive caster. That's pretty much it honestly... Oh wait, I did put slits on the inner wheel well pinch welds and hammered them in, spot welded and applied body rubber silicone, and then sprayed over with some rubberized liner. My tires do make contact with the liners when I come into full compression/tuck after some newborn airborn, but the rear's I have the hydrobumps set to where it wont take my bedsides out haha. No rubbing on full locks and no rubbing while full lock into reverse or in drive (well there's a slight rub, but its the liners I need to trim off a bit more.)
    So far it's been doing pretty good when I am out testing the clearance. Only thing that got bashed was the skid plate and radiator from an ugly airborn I did during Easter weekend haha.
  24. May 4, 2019 at 8:33 AM
    #294
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    Saw your truck on South and Panorama a couple of weeks ago. Great job on the mods.
    5.7TRDProm[QUOTED] likes this.
  25. May 4, 2019 at 8:38 AM
    #295
    5.7TRDProm
    Dara
    South and Panorama? Doesn't sound like an intersection I've been on. There's no streets name Panorama where I live at. How long ago was this? My truck has been sitting down in my driveway since April 22nd for a suspension refresh up front.
  26. May 4, 2019 at 9:51 AM
    #296
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    My bad, South and Paramount. It was the evening of April 20
  27. May 4, 2019 at 9:55 AM
    #297
    5.7TRDProm
    Dara
    Ahh okay. A close friend of mines lives near there so Im usually driving that area often on the weekends.
  28. May 4, 2019 at 10:17 AM
    #298
    GodlessPro
    Matthew
    NorCal
    I've read Kevin's thread and even looked at his truck at T2S, the best I could come up with was that he must have sacrificed a goat.
    GODZILLA, KevinK and porkitt like this.
  29. May 4, 2019 at 6:11 PM
    #299
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    Hahahah!!!!
    Two actually. One for each side.
    GODZILLA and GodlessPro[QUOTED] like this.
  30. May 4, 2019 at 6:16 PM
    #300
    KevinK
    Tundras to Sedona
    Reminds me I need to update the build thread with the zero offset beadlocks and all the kooky shit we had to do to make them work on MT.
    But @5.7TRDProm is right about offset being the key to fit 37s on stock fenders.
    5.7TRDProm and GodlessPro like this.
