Let's see them Boats!!!!
Discussion in 'Off-Topic Discussion' started by Bravohook, May 9, 2021.
  1. Dec 27, 2021 at 8:30 AM
    #121
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
  2. Dec 27, 2021 at 9:20 AM
    #122
    Nomoredomestics
    Nomoredomestics New Member
    GA
    2023 TRD Sport 4x4
  3. Dec 27, 2021 at 9:42 AM
    #123
    junebug70
    junebug70 New Member
    June
    2021 Metallic Gray 1794 Tundra
    Bed Step, Pro Hood Scoop, Riveted Fender Flares, UnderCover ArmorFlex Bed Cover
    Prostar 190, Bobbyd, BTBAKER and 3 others like this.
  4. Jan 16, 2022 at 11:29 AM
    #124
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    10 foot tracker topper 10 with 55lb thrust minn kota, and a lowrance 9 ti2. 20210221_094950.jpg 20210306_135558.jpg
    12 foot 1989 sea nymph with a 2021 suzuki 20hp. With 55 lb thrust minn kota and lowrance 9 ti2. The Suzuki pushes this little 12 footer up to 30mph.IMG_3215.jpg 20211212_103205.jpg
    2022 Alumacraft voyageur 175 cs. With a 115 Yamaha V-Max SHO. Just got it a week ago. Still have to get all my electronics. I'm leaning towards a full garmin setup. 20220108_134213.jpg 20220108_134309.jpg 20220108_163226.jpg
  5. Jan 16, 2022 at 11:35 AM
    #125
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Any way you can get the info off those trailer guides?
  6. Jan 16, 2022 at 12:34 PM
    #126
    Chucko2340
    Chucko2340 New Member
    2019 platinum
    3 inch lift, hdx running boards, under cover flex cover, nitto terra grapplers 285/65/20,trd exhaust, trd cold air intake
  7. Jan 16, 2022 at 2:00 PM
    #127
    havasuTRD
    havasuTRD New Member
    Brett
    2017 Tundra crewmax TRD 4X4
    I’ve got 85 mph on GPS. Want to swap some props this summer and hope for 2-3 more mph!!! It’s never enough is it?
  8. Jan 16, 2022 at 2:07 PM
    #128
    Brown Bear
    Nor cal
    03 TRD offroad
    Here is the only info I can find on them. They came with the boat from the factory.
    Bobbyd likes this.
  9. Jan 16, 2022 at 2:19 PM
    #129
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Thank you, Sir.
  10. Jan 16, 2022 at 2:30 PM
    #130
    cran2
    cran2 New Member
    Folly Beach, SC
    07 Crewmax 4x4 and 03 Sequoia 4x4
  11. Jan 16, 2022 at 2:59 PM
    #131
    Nomoredomestics
    GA
    2023 TRD Sport 4x4
    Beautiful key west!
    Ranger2005 likes this.
  12. Jan 16, 2022 at 3:45 PM
    #132
    Chucko2340
    2019 platinum
    Thank you picked up a few months back. One of the lucky ones to not pay up and motor showed up the day after I put a deposit on it.
    BTBAKER likes this.
  13. Jan 16, 2022 at 3:56 PM
    #133
    AircareTundra
    AircareTundra New Member
    JT
    Ranger 188VX and my three pups and oldest son on ponds in DE.20210612_090205.jpg 20210612_085124.jpg 20210612_093551.jpg
  14. Jan 16, 2022 at 5:51 PM
    #134
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Cool looking boat! Your Tundra grill looks like it has the safety sense on it but the truck year looks well before that stuff. Am I seeing things?
  15. Jan 16, 2022 at 6:18 PM
    #135
    wakeboarder
    wakeboarder New Member
    13 Tundra
    My baby. ‘99 MasterCraft 205v/Xstar. W/ 2500lbs of ballast, she puts out a damn good wake. Powered by a Chevy 350, still pulls strong after 1300hrs.
  16. Jan 16, 2022 at 7:25 PM
    #136
    Great shot.
  17. Jan 16, 2022 at 7:55 PM
    #137
    BCTRD
    BCTRD New Member
    B.C.
    2021 MGM Tundra TRD Sport
    18"BBS Forged wheels, factory running boards, VLED's, Rigid Pro Led mod (D2 SAE), diff breather mod, Husky mats, DIY Cquartz UK 3.0, Husky liners, OCD organizers,
    Like my 115 V-Max SHO Yam. You may already be aware the factory cleaver style aluminum prop is a piece of crap paperweight. For a few bucks more Yamaha makes an alum Talon which has speed and slip numbers that a lot of S.S. props can't beat. I have test data on 4 props that may be helpful. Boat is 2300lbs wet, fg deep V. Top speed is just shy of 45 mph.
  18. Jan 16, 2022 at 8:21 PM
    #138
    BCTRD
    BCTRD New Member
    B.C.
    Since these photos I've installed SeaStar Hydraulic and an autopilot for trolling.
    Cpl_Punishment and Prostar 190 like this.
  19. Jan 16, 2022 at 8:50 PM
    #139
    fatbastard79
    fatbastard79 New Member
    Huntsville, Alabama
    2017 Tundra Limited 4x4
    Soon...
    Got it last summer. 2005 Tahoe Q4 4.3L MerCruiser. Got a bimini for it sitting in the bed of the Tundra waiting for install.
  20. Jan 16, 2022 at 9:39 PM
    #140
    azs406
    azs406 New Member
  21. Jan 16, 2022 at 10:14 PM
    #141
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    Sweet! Do you use a section surf gate at all? Been thinking about buying one for mine in the spring time.
  22. Jan 16, 2022 at 10:47 PM
    #142
    19 Cement Lmtd
    19 Cement Lmtd New Member
    2019 Cement Tundra Limited TRD Off-Road
    Leveling kit w/2 in. lift, aftermarket wheels, and tires
  23. Jan 17, 2022 at 7:29 AM
    #143
    wakeboarder
    13 Tundra
    I do. I made my own. Bought a suction cup handle from Amazon, and used a cutting board along with some PVC trim I had. Here’s a pic of the port side wake. Starboard side is a little better. Probably due to prop rotation.
  24. Jan 17, 2022 at 8:07 AM
    #144
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Picked this up for $5K this weekend. Motor is almost brand new, 21 hours.
  25. Jan 17, 2022 at 8:21 AM
    #145
    20GR8 Super
    Corey
    PNW Outskirts
    That’s a nice wake and thanks for the info! I’ve got about the same amount of ballast but think I need the gate to clean it up and get some more push. Summer can’t get here fast enough!
  26. Jan 17, 2022 at 8:38 AM
    #146
    Ranger2005
    Ranger2005 New Member
    Dean
    TX
    2021 1794 Crewmax
    Running boards, ceramic coating, sound system
    Hullofa deal! I would have picked it up in a heartbeat too!
    Terndrerrr likes this.
  27. Jan 17, 2022 at 8:45 AM
    #147
    Bannerman
    Johnson
    Yeah I’m excited. We live at the lake full time so we already had a pontoon but it’s really too big for fishing. This should serve we well for a couple years until my kid is big enough to join, then I’ll get something nicer.
    Ranger2005[QUOTED] likes this.
  28. Jan 17, 2022 at 9:21 AM
    #148
    HamHands
    HamHands Honey-Glazed Member
    2018 Tundra DC MGM SR5 5.7 TRD 4x4
    Already posted, but here’s some from scalloping season this past summer. And some with my dog, which I can’t resist sharing.
    3B20E5DB-772E-4D1C-A4DD-275794B521E6.jpg 6528DB36-6FAB-4B60-AB02-D29464075FFC.jpg 27BDE080-9B90-4C35-AE3C-4AC0BB6B3EC2.jpg C2C6DC05-A8F8-4FD8-8FD3-3775F5E09C81.jpg 89DCF062-7F4E-4EE7-B29B-F7DC1B9457B1.jpg
    Outbound, Prostar 190, Bobbyd and 5 others like this.
  29. Jan 17, 2022 at 10:02 AM
    #149
    BayRunner
    2017 Tundra Platinum
    Thats a nice find. Those are great boats.
    Bobbyd and Bannerman[QUOTED] like this.
  30. Jan 17, 2022 at 10:07 AM
    #150
    BayRunner
    Love my Brig.
