Let's see 1st gen with Toyota Rims
Discussion in '1st Gen Tundras (2000-2006)' started by Lupe, Feb 19, 2019.
  1. Dec 11, 2023 at 7:45 PM
    #871
    albru2
    albru2 Keep it simple stupid
    2002 Tundra Limited 4.7l 4WD AC
    Well I figured the least I could do was post the carnage in case I could save some other knucklehead out there from the same fate. :bananadance:
    JakeJake and shifty`[QUOTED] like this.
  2. Dec 11, 2023 at 8:35 PM
    #872
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    It'll eventually stop rubbing.
  3. Dec 11, 2023 at 8:59 PM
    #873
    AmericanKing06
    AmericanKing06 New Member
    New Mexico
    04 Toyota Sequoia aka Dadwagon
    I believe those are the earlier 93-94 FZJ80 wheels with the steel inserts for conical lug nuts. The other version of the FZJ 80 95-97 wheels using the washer lug nut with no steel inserts. I've read that the newer version don't rub on the WL caliper. Correct me if I'm wrong. I read that on the Ih8mud under the GXOR threads.
    shifty` likes this.
  4. Dec 11, 2023 at 9:05 PM
    #874
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    As funny as that is, it's works...at least it worked great for me. I had a set of spare 14" Honda CRX "phone dials" with studded snow tires mounted on them. I wanted to mount them on my 2005 scion xB (it came stock with 15"). I bolted them on and then let the vehicle back down on the ground and immediately backed up the xB. All i heard was a terrible grinding sound. I jacked the front end up the xB back up and removed the wheels...ahhh, so the calipers are rubbing against the aluminum wheels. 90% of the damage was done already, so i simply kept the wheels spinning while the front end was up in the air. It only took a few more seconds to wear them down to zero clearance. I then ground down the calipers a bit with a flapper disc to get about a 1/4" space. It sounds ghetto, was ghetto, but worked the treat. That was about 12 years ago. I still have the same rims.
    shifty` and Mr.bee[QUOTED] like this.
  5. Dec 11, 2023 at 9:13 PM
    #875
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    If its stupid and it works. Its not stupid. Internet law.
    whodatschrome likes this.
  6. Dec 11, 2023 at 9:41 PM
    #876
    albru2
    yep these are conical and I can confirm they rub on the WL caliper!
  7. Dec 11, 2023 at 9:54 PM
    #877
    albru2
    dang so you took a 1/4" of material off your calipers? that's the kind of ballsy, can-do attitude I admire but rarely achieve. Inspiring
  8. Dec 11, 2023 at 9:58 PM
    #878
    whodatschrome
    lots of dents
    It all depends upon how thick the casting is in a particular area. You have to use your judgement when it comes to that. I’ve also had to sand down the oversized calipers in one of my Jeep CJ7’s as well.
    shifty` likes this.
  9. Dec 11, 2023 at 10:22 PM
    #879
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    I'd do slightly longer studs and 5mm slip on spacers.
    Not the chincy cheap ones which are worse than swiss cheese but some solid machined ones.
    shifty` likes this.
  10. Dec 12, 2023 at 5:30 AM
    #880
    shifty` Inside his chest they found ten thousand pencils
    Ah yes. All my vehicles double as a lathe also. :rofl:
    I'd definitely dress the calipers before the wheels, but I'd also hit the wheels with a flapper also to smooth them out (hopefully the alloy doesn't load up the flap discs too quickly), then re-powder or refinish those spots. Just so you don't have jagged edges where it's clear what happened.
    It's only stupid if it creates a safety risk.
    Excellent idea ^^ :thumbsup:
    I don't recall if it's the front or the rear wheel studs that are 5-10mm longer on the 1GT, but the variation is undoubtedly due to disc front vs. caliper rear. I have to go back and reference it.
    Edit: Here it is, the reference post I typically dig up for front/rear stud differences.
    Looks like the rear is longer, but the added height is actually coming from the serrated/knurled shoulder being taller for the rear, I presume because the axle flange is thicker in the rear. Anyway, may or may not work, if nothing else, get something intended for disc with same diameter and thread but slightly longer (+4-6mm if going with a +5mm shim as assassin reco'd)
    albru2 and whodatschrome[QUOTED] like this.
  11. Dec 12, 2023 at 5:35 AM
    #881
    As tucked as those wheels are, a real spacer would be fine. 1-1/12” would work. Those wheels have relief between the lugs, so it’s ok if the spacer leaves the factory lugs protruding slightly.
    edit: just noticed the rear wheel is not the new ones. Appears the new front wheel is close to the fender edge. I retract my previous suggestion above. May end up looking silly with a thicker spacer.
  12. Dec 12, 2023 at 8:18 AM
    #882
    albru2
    Yeah that seems like the best compromise between safety, cost and poke. I was checking out these because I had seen people recommending Bora but I imagine there's probably something just as good for less money out there.
  13. Dec 12, 2023 at 9:56 AM
    #883
    albru2
    I was just checking with a straight edge and I think you're right - even with the new wheel and tire I have a good 1.25" still to go before the sidewall is even with the flare. That tire is a 245 though.
  14. Dec 12, 2023 at 1:06 PM
    #884
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Yeah, motorsport-tech is who makes bora.
    They're a great option for correct pattern, no excess holes and proper sized bore i.d.
  15. Dec 22, 2023 at 1:14 PM
    #885
    albru2
    I ended up doing the caliper lathe/caliper grind technique and it seems to have worked out fine. Thanks for the tip! Here's a pic of the land cruiser wheels new 265/75 R16 tires, Bilstein 5100 + OME 2884 springs. I got the full 2" of lift up front that firstgen offroad says I would so now I've got about a 1/2" squat. I think the ATS HD springs are next. It's coming along..
  16. Dec 22, 2023 at 10:42 PM
    #886
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    It ain’t a 1st gen if the rotors aint any color but silver.
  17. Dec 23, 2023 at 2:18 AM
    #887
    But but …. What about the TRD BBK?
  18. Jan 13, 2024 at 9:50 AM
    #888
    mthoodbill
    mthoodbill New Member
    Mt Hood, Oregon
    2000 Tundra SR5 Access Cab 4x4, 2012 Mini cooper clubman S
    Bilstein 6112, .5" front lift. 5100 rear. 17" FJ steel wheels Gofast topper
    17" steelies from a FJ Cruiser along with the center caps. Tires are 245/70/17 Yokohama G015. Seems to go pretty well in the snow. half in lift in the front from the billiesC1EE14A4-ACF4-4F17-BBC0-74089EFEB33C.jpg
  19. Mar 4, 2024 at 3:57 PM
    #889
    j4ycub
    j4ycub New Member
    2001 stellar blue AC
    I have the same tire size , did these wheels require spacers?
  20. Mar 4, 2024 at 4:00 PM
    #890
    j4ycub[QUOTED] likes this.
  21. Mar 5, 2024 at 7:57 AM
    #891
    j4ycub
    j4ycub New Member
    Do you happen to know if these will fit on FGT’s? Would I need wheel spacers for 265/70/r16 to not rub calipers/rotors and anything else? Just haven’t saw a picture in this thread of anyone running these!
  22. Mar 5, 2024 at 10:02 AM
    #892
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    If you have a TRD truck with fender flares the spacers help get them to look right. You may have a slight bit of rub on one side frame rail when turning fully without the spacer.
  23. Mar 7, 2024 at 12:13 PM
    #893
    Hummer
    Hummer New Member
    2023 Tundra CrewMax Limited 10K miles
    Studs Baby, Studs!
    My trusty '03 has 250K miles more on it than when I took these photos. The original split 5-spoke rims are in need of refinishing and they're currently dismounted. So, I've been thinking of having the OEM's powder coated in a bronze, black bronze or chrome bronze. I've perused every page of this thread and haven't seen a truck in desert sand paint with bronze wheels. What do you think about the combination?
    Btw, FJ Cruiser wheels stand out as a popular alternative on best gens throughout this thread. My truck's now wearing some FJ wheels with winter tires (page 27).
    Weagle and The Black Mamba like this.
  24. Mar 7, 2024 at 4:59 PM
    #894
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Now I understand your inquiry in the other thread. This is what I used. It’s called warm gold.
    Hummer[QUOTED] likes this.
  25. Mar 8, 2024 at 8:02 AM
    #895
    j4ycub
    j4ycub New Member
    Don’t know if anyone is running these? If so, could you drop a picture? Would they clear the calipers and rotors? Also, would there be any rubbing or cutting required with 265/70/R17?
  26. Mar 8, 2024 at 8:10 AM
    #896
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  27. Mar 8, 2024 at 5:33 PM
    #897
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    I have the 20" limited Nightshade wheels on my truckIMG_1270.jpg IMG_0052.jpg
  28. Mar 9, 2024 at 9:59 AM
    #898
    Hummer
    Hummer New Member
    Studs Baby, Studs!
    Thanks! I was looking at these yesterday. I can't find the color labeled on the can or cap, but the HD tags note the colors as Gold Rush and Champagne Bronze. Who knows which is closest to your Warm Gold, freaking marketers changing names to fit various regions. There's also a metallic brown that might look good on the desert sand truck. I'm going to prep the wheels and try both, or all three colors, and see which coordinates better.
    I'm seeing both gold and bronze on more custom car wheels lately. When I drive around and look at wheel-paint combinations, silver and aluminum almost always looks good. The black stealth look is everywhere, too. But I'd like to try a distinctive color without being gaudy.
  29. Mar 11, 2024 at 7:23 AM
    #899
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    265/75r17 M/T Baja Boss AT 17x8.5 -10mm SCS Ray 10’s Bilstein 5100’s 2nd notch
    If anyone is interested, I’m putting these wheels and tires on marketplace today. I got new scs wheels so these gotta go. I’m near St Louis.
    Hummer likes this.
  30. Mar 11, 2024 at 8:08 AM
    #900
    Hummer
    Hummer New Member
    Studs Baby, Studs!
    Nice wheels, and what's the replacement?
