Let's see 1st gen with Toyota Rims
Discussion in '1st Gen Tundras (2000-2006)' started by Lupe, Feb 19, 2019.
  1. Jun 1, 2023 at 4:34 PM
    #811
    Bmktw2
    Bmktw2 Yard Dog
    Nic
    AC 2001 5spd 4x4 V6
    Okay so a 16x8 wheel with a 265 75 r16 wheel would fit fine
  2. Jun 1, 2023 at 4:38 PM
    #812
    shifty` Inside his chest they found ten thousand pencils
    In theory, I think it should be do-able. What is stock, so we can compare? This is where you're add on width/height/ and appropriate wheel dims for 265/75r16:
    Bmktw2[QUOTED] likes this.
  3. Jun 1, 2023 at 4:41 PM
    #813
    Bmktw2
    Bmktw2 Yard Dog
    Nic
    AC 2001 5spd 4x4 V6
    Current wheel:
    Will a 16" wheel clear the larger 2004 front brakes?
  4. Jun 1, 2023 at 5:00 PM
    #814
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    So you're looking to go from a 17" wheel to a 16" wheel?With a 16x8" wheel on 285/75/16s, you'll need to get a wheel with a negative offset or at most 0mm. OEM toyota wheels are a positive offset, so without spacers you might run into clearance issues. Edit: Misread 265/75/16 as 285. I agree with shifty those would work in theory though.
  5. Jun 1, 2023 at 8:08 PM
    #815
    You actually may be right. For whatever reason I thought he'd be running closer to 30.5 diameter on his current tires thus only adding about an inch, which is minimal. The jump to 265/75/16 is nothing to scoff at with height, with 2.5" more over what he's running today.
    I'd be tempted to risk it, but if @Bmktw2 wanted to be a little more less risky with his choices, 265/70r17 is the 'safer' option. AC/RC seem to have more stuffability over DC. Here's what he's currently running, vs. 265/70r16 just below it, which adds the same sub-half-inch width, but only 1.5" diameter, which will definitely be beefier.
    (EDIT: Important to note, your speedo will be off a few mph at 1.5" diameter change, almost doubly so at 2.5" diameter change)
    Bmktw2 likes this.
  6. Jun 1, 2023 at 8:09 PM
    #816
    I remember there's a clearance concern with certain year calipers and 16" wheels, but I don't remember the numbers off-hand.
  7. Jun 7, 2023 at 9:32 AM
    #817
    tdavis5f15
    tdavis5f15 New Member
    2002 Tundra SR5
    Bone Stock
    I know this is old, but are you running spacers on this?
  8. Aug 22, 2023 at 3:36 PM
    #818
    manfrommarrs
    manfrommarrs Man From Marrs
    Marcus
    North Texas
    2001 Tundra SR5 White, like new
    18” TRD Alloy Wheels, BF Goodrich A/T TA’s, Chrome TRD exhaust pipes, Bilstein Shocks, Marathon seat covers, Tonneau cover
    2001 Access cab with Ivan Stewart package. FEB958BE-C940-4873-AF08-AD2CC8E2A6AD.jpg6444F4CE-9C00-4F78-86EF-CF221880849F.jpg
    HBTundra and Riverdale21 like this.
  9. Aug 22, 2023 at 5:39 PM
    #819
    daveeasa
    David
    Let’s see the grille!
  10. Aug 23, 2023 at 6:33 PM
    #820
    NomadicFrog
    NomadicFrog Took 5 yrs, finally got rid of "New Member" here
    Mark
    Flagstaff, Arizona
    2003 Tundra SR5 4x4 TRD Off-Road Access Cab
    First mod: Gaffer tape over door lock/unlock beeper
    Here's my 2003 access cab with a brand new set of F(X) Pro 17 inch replica wheels, in matte gunmetal gray. More info in post 50472.
  11. Aug 24, 2023 at 9:07 AM
    #821
    Acatlin96
    Acatlin96 amateur breeze shooter
    Austin
    Central Coast, CA
    2003 AC SR5 V8 4WD TRD
    Those wheels look great on your truck. Super jealous of your camper shell btw. Your whole setup is awesome.
    NomadicFrog[QUOTED] likes this.
  12. Aug 27, 2023 at 2:14 PM
    #822
    2004 tundra12
    2004 tundra12 New Member
    Rob
    2004 tundra
    I was looking at a set of Tacoma wheels but thought the offset difference was to much and may rub. Tundra 15mm to Tacoma 25mm was I right?
  13. Aug 27, 2023 at 3:58 PM
    #823
    Find them in this thread and you'll see if they fit. Someone undoubtedly has them already in here.
  14. Sep 20, 2023 at 9:59 AM
    #824
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    265/75r17 M/T Baja Boss AT 17x8.5 -10mm SCS Ray 10’s Bilstein 5100’s 2nd notch
    I looked through this whole thread and didn’t see the wheels that are in my truck anywhere. I know they are OEM Toyotas but did they not come on the tundra? I may just be cheap and dip them gloss black soon. I saw a few that were close but not the exact wheel.
  15. Sep 20, 2023 at 10:18 AM
    #825
    I believe they're Lexus wheels. I think you'll find at least a couple of examples in this thread.
  16. Sep 20, 2023 at 10:27 AM
    #826
  17. Sep 20, 2023 at 4:51 PM
    #827
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    I looked them up and google says 2006 tundra “premium” wheels who knows what that means
  18. Sep 20, 2023 at 5:17 PM
    #828
    I don't know what it means either, but they came on the 2010+ GX460 and appear to be an 18" wheel. The part number is 42611-60890 and/or 42611-60870. I don't know what the difference is between those two part numbers, but usually when the last two numbers are the only change, it's a small change, i.e. color, maybe backspace, or other small characteristics.
  19. Sep 20, 2023 at 5:44 PM
    #829
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    Mine are 16’s I think I’m going to put tires on it 265/70R16’s Falken AT3 W’s and then plasti dip them gloss black to see how they look
  20. Sep 21, 2023 at 12:49 PM
    #830
  21. Sep 22, 2023 at 4:36 AM
    #831
    shoe07
    shoe07 New Member
    Ohio
    2004 Tundra Double-cab SR5 Tow pkg
    difference is color, dark vs silver
    shifty`[QUOTED] likes this.
  22. Oct 31, 2023 at 2:43 PM
    #832
    zzyzx85-714
    zzyzx85-714 New Member
    2006 AC SR5 V8 2WD
    Our '06 AC V8 SR5 2WD came with those wheels and 265/70-16 tires.
    I went through all 28 pages and only saw a handful of Desert Sand Mica trucks lol. I'm imagining silver wheels look best (like OE) but does anyone have a Desert Sand Mica?
    There's a set of FJ Cruiser "phone dials" on sale locally. I'm tempted but I need to spend money on tires and suspension first lol.
  23. Oct 31, 2023 at 2:45 PM
    #833
    This thread is for stock Toyota wheels. So all you should be seeing in here is OEM/stock styles and colors.
    If you want non-OEM wheels and some color variety, you can find some deals over here in the Marketplace: https://www.tundras.com/forums/marketplace-wheels-tires.49/
  24. Oct 31, 2023 at 2:50 PM
    #834
    zzyzx85-714
    2006 AC SR5 V8 2WD
    I've seen Toyota wheels that have been re-colored in this thread?
    Anyone out there with a Desert Sand Mica?
  25. Oct 31, 2023 at 2:53 PM
    #835
    Other than OE color? Sorry, I'm still not following. Toyota is OE, so I'm getting hung up on "Toyota wheels other than OE". It's like saying "OE wheels other than OE" in my brain. I'd like to understand, maybe I can link you to something you're looking for.
  26. Oct 31, 2023 at 2:55 PM
    #836
    zzyzx85-714
    2006 AC SR5 V8 2WD
    nevermind. i'm an idiot and my brain is fried after going through all those pages.
    i'll just have to use my imagination/crappy photoshop/paint skills to see what looks good.
    :thumbsup:
  27. Oct 31, 2023 at 5:42 PM
    #837
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    My 2000 AC came with 265/70R16s on Patricks
  28. Oct 31, 2023 at 6:36 PM
    #838
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    This color looks cooo.
    RareRed[QUOTED] likes this.
  29. Nov 1, 2023 at 6:04 PM
    #839
    2006 Tundra AC
    2006 Tundra AC Slowly upgrading my grandfather's old truck
    Andrew
    Cedar Park, Texas
    '06 desert sand 4.0 V6
    Alumas, Alcans, TuRD Pro wheels, 285/70/17 Falken
    I have a desert sand mica with gunmetal Turd wheels from a 4runner.
    Maybe this will help you?
  30. Nov 1, 2023 at 8:54 PM
    #840
    zzyzx85-714
    2006 AC SR5 V8 2WD
    Thank you! You were one of the few I saw through the pages. Looks good with the matte gray TRD SEMA wheels on it!
