Let me see your truck with stock 18" TRD off-road wheels
Discussion in '2.5 Gen Tundras (2014-2021)' started by GT87, May 7, 2021.
  1. May 27, 2021 at 3:11 PM
    #61
    SAGE63
    San Diego County
    Do you rub when you air down to 20lbs?
  2. May 27, 2021 at 3:27 PM
    #62
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Not something I would do. Rare to see any off road time. Used to play in the mud though.
  3. May 27, 2021 at 3:27 PM
    #63
    SAGE63
    San Diego County
    got ya...
  4. May 28, 2021 at 8:01 AM
    #64
    ArdnuT trd
    ArdnuT trd New Member
    Blake
    2021 Tundra MGM TRD 4x4 CM limited
    Where did you get the kit and it is just the 4 shocks needed correct? I read you have to have a pro vin to buy is this true?
  5. May 28, 2021 at 1:59 PM
    #65
    ArdnuT trd
    Blake
    @Terndrerrr if I get the fox shocks is that all I need for it to be lifted like a pro?
  6. May 28, 2021 at 3:50 PM
    #66
    CoCotton
    CoCotton New Member
    2015 Platinum
    Bilstein 6112 on the second clip setting. 275/70r18 General Grabber ATX.
    Pbed85 likes this.
  7. May 28, 2021 at 4:02 PM
    #67
    jsteph89
    jsteph89 The wish list continues to grow
    Joseph
    South Texas
    2019 Limited 4x4
    Blacked out emblems, Leer 100XL camper shell, Magnaflow exhaust, ProComp 3/1 level kit, 285/55R20 Falken Wildpeaks AT3, WeatherTech mats, full led interior swap,
    Badass truck. My goal is to get there with mine
  8. May 28, 2021 at 4:05 PM
    #68
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
  9. May 28, 2021 at 4:19 PM
    #69
    AlaskanAssassin
    AlaskanAssassin I now walk into the wild
    David
    Alaska
    2020 DC TRD-OR, Cement
    My “stock” wheels. Took my TRD Off-Road wheels to get powder coated recently and love the black on cement.
    81 TOY and CurtisLemansky like this.
  10. May 28, 2021 at 7:27 PM
    #70
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Got my parts from Sparks. Did not require a Pro VIN. The front coilovers, rear shocks, and small speed sensor extension bracket are what make up the Pro suspension kit. That’s it. The front coilovers are 2” taller, and the shocks front and rear have quite a bit more travel than even the TRD Off Road shocks.
    Search TRD Fox suspension; there are a ton of threads with lots of info on it. Maybe even try searching TRD Fox in thread titles only. Info galore!
  11. Jul 27, 2022 at 10:47 AM
    #71
    M13tundra
    M13tundra New Member
    No spacers correct? Do you rub the sway bar?
    I'm getting the toytec eibach 3/1 setup and want this tire size.
  12. Jul 27, 2022 at 10:58 AM
    #72
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Here is an update, same tires, but with 2/1 lift
  13. Jul 27, 2022 at 11:00 AM
    #73
    mountaingroan
    mountaingroan New Member
    North Idaho
    2020 SR5 DC VooDoo 4WD Bench!
  14. Jul 27, 2022 at 11:32 AM
    #74
    kaymonster
    kaymonster Member
    San Diego
    2018 Platinum
    PXL_20220727_193741841~2.jpg PXL_20220727_183008585.jpg PXL_20220727_183023755~2.jpg
    huntsonora and J&ATundra like this.
  15. Apr 9, 2023 at 3:16 PM
    #75
    huntsonora
    huntsonora New Member
    2006 Toyota Tundra DC
    Were the coachbuilder shackles worth it? Help with ride quality at all?
  16. Apr 9, 2023 at 7:11 PM
    #76
    BulldogDan
    BulldogDan New Member
    Cement…Tundra #9
  17. Apr 10, 2023 at 10:44 AM
    #77
    eagleguy
    eagleguy New Member
    Love solid white letter tires.
    easleycrawler[QUOTED] likes this.
  18. Apr 10, 2023 at 10:48 AM
    #78
    eagleguy
    eagleguy New Member
    What would be the largest tires that won't rub but would fit a 2021 Tundra 2WD SR5 which has only a 2.5" spacer lift up front to make level and the older 18" black rims?
  19. Apr 10, 2023 at 12:05 PM
    #79
    Terndrerrr
    Music City
    6UR-FE
    I moved on from them. I don’t think extended shackles are a good idea. You’re creating more distance for the frame to hit the bump stop, and at that point, your leafs are really inverted. Seems that they’ll just wear out faster.
    i went back to stock shackles (kept the CB bushings) and added RAS. Lost of info in the build thread in my sig
    huntsonora[QUOTED] likes this.
  20. Apr 10, 2023 at 1:16 PM
    #80
    V3N0M
    V3N0M New Member
    Ryan
    Orange County, CA
    2020 Tundra SR5 Crewmax
    - Carven Type R Exhaust - TRD LED Headlights - (2) LED Ditch Lights Mounted on Hood - Cali Raised Ditch Light Brackets - (2) 42” LED Light Bars Behind Grill - Cali Raised Hidden Grille Mounting Brackets - AJT Interior Chrome Delete - AJT V3 Shift Knob - 8" ReadyLift w/ Bilstein 5100's (all around) - 18" Raceline 948B Split Wheels - Toyo Open Country MT 37 x 13.50 R18 - Amp Research Power Steps
  21. Apr 10, 2023 at 1:47 PM
    #81
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    Thanks. Got them on my taco as well.
    Badknees likes this.
  22. Apr 10, 2023 at 5:15 PM
    #82
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    So do I. I think truck wheels always look better with OWL. I'm guessing that was imprinted at an early age.
    easleycrawler likes this.
  23. Apr 10, 2023 at 7:39 PM
    #83
    eagleguy
    eagleguy New Member
    I have those same Tonka trucks somewhere.
  24. Apr 11, 2023 at 6:26 AM
    #84
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    So you sold your first gen flatbed?
  25. Apr 11, 2023 at 6:45 AM
    #85
    DBamaC
    DBamaC New Member
    Darryl
    2018 Cement Tundra Limited TRD Offoad
    BAKFlip MX4 Bed mat LED bed lights LED Interior lights 12Volt Solution’s remote start Kenwood Excelon DMX1057XR
    IMG_0548.jpg '18 Cement sitting on 275/70R-18 General Grabber A/TX's. 1.75" leveling kit and a slight roll of the bash plate to clear. Was able to leave on the little plastic aero-wings though.
    _none_ and huntsonora like this.
  26. Apr 11, 2023 at 2:11 PM
    #86
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Same tires i plan go with. Are those the SL or e-rated? SL are about the lightest 275/70 option out there, only a few pounds heavier than stock.
  27. Apr 11, 2023 at 2:33 PM
    #87
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
  28. Apr 11, 2023 at 2:52 PM
    #88
    easleycrawler
    Travis
    Yeah.
    Badknees[QUOTED] likes this.
  29. Apr 11, 2023 at 4:19 PM
    #89
    justcuz
    justcuz 2.5 Gen Member
  30. Apr 11, 2023 at 5:14 PM
    #90
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    Stock height, Cooper 275/70/18. OR wheels powder coated black.
