Let’s see your aftermarket front and rear bumpers!!
Discussion in '2.5 Gen Tundras (2014-2021)' started by DMB4x4, Apr 23, 2019.
  1. Apr 30, 2020 at 6:25 AM
    #301
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Almost there, getting powdercoated now...
    Dantdodge, GODZILLA, equin and 2 others like this.
  2. Apr 30, 2020 at 6:54 AM
    #302
    Buckmark1
    Buckmark1 New Member
    TX
    2019 Cement SR5 CM - TSS Off Road 4x4
    For those with the Westin Outlaw front bumper........can you still use the stock fog lights?
  3. Apr 30, 2020 at 7:21 AM
    #303
    Rbohno
    Rbohno New Member
    Rich
    NC
    2020 Tundra CrewMax Limited
    Icon stage 5,method 18 x 9, BFG KO2s, Bushwacker flares, tinted windows,Havoc HST running boards,Weatherguard slimline box, DSR1, JL Audio 900/5 amp, two 10W0 subs in a box, hertz centro in the front and Hertz Uno in back doors
    Your truck and bumpers are incredible and the only thing else I would do is have the body shop cut your rear quarter panel to match bumper lines
  4. Apr 30, 2020 at 12:25 PM
    #304
    adventure-hunting
    adventure-hunting New Member
    lee
    14 blk tundra
    @matictundra is this a prototype rear for a company or one you had designed on CAD and cut on a laser jet. looks really clean and low profile. I do agree though that trimming the rear corners would make it look smooth.
  5. Apr 30, 2020 at 1:34 PM
    #305
    matictundra
    Franco
    AZ
    This my own design that got laser cut, some parts bent and welded. I also flip rotated the OEM receiver. The license plate will flip down for access.
  6. Apr 30, 2020 at 2:26 PM
    #306
    stewtopia
    stewtopia 4RunningTundra
    Stew (nickname)
    Masshole
    The opening it square, it's like 4x3.5". Don't recall how big the factory fogs are.
  7. May 1, 2020 at 5:28 AM
    #307
    adventure-hunting
    lee
    14 blk tundra
    very nice job
  8. May 2, 2020 at 6:10 PM
    #308
    Kichinko
    Kichinko New Member
    TRE 5ON
    VA
    SUPER WHITE 2016 Plat 4x4
    TBD
    Looked through the entire thread, this is still the best looking in my opinion.... now to research price :D
    GODZILLA likes this.
  9. May 2, 2020 at 6:20 PM
    #309
    Kichinko
    Kichinko New Member
    TRE 5ON
    VA
    TBD
    https://c4fabrication.com/collections/tundra/products/tundra-hybrid-front-bumper-2014
    Kinda steep once you add all the bells and whistles.... and it mentioned interfering with TSS / ACC so I was like do I have that stuff on my platinum?
    Went and looked at my specs and saw this:
    Safety & Convenience
    Rr Backup Camera,Frnt & Rr Parking Sonar Blind Spot Monitor
    Had no idea I even had sonar... guess I need to look into the settings.
  10. May 3, 2020 at 9:00 AM
    #310
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Edit, just saw you have a 2016- you have sonar for backing up and rear, but no TSS so the pre runner bar wont interfere with anything.
    Your platinum has sonar, thats the beeping when getting close to objects.
    You will need a TRD pro grill to run the bull bar on the bumper like I have, otherwise no bar works fine with the TSS
  11. May 3, 2020 at 9:19 AM
    #311
    Kichinko
    Kichinko New Member
    TRE 5ON
    VA
    TBD
    Got my Tundra, and then I've driven it all of 5 times since this quarantine BS started... I guess there's a parking sensor button to turn that sonar on (that I've never used). One of the only things I've managed to do (with shipping delays the way they've been) is swap the Platinum grill for the TRD Pro Grill, why is that required to run the bull bar? I thought they had roughly the same footprint
    Any idea if those Sonar sensors still work once the bumpers is replaced?
    Sorry I'm fulla questions... Thanks in advance
  12. May 6, 2020 at 1:18 PM
    #312
    DexterL
    DexterL New Member
    TRD pro sensor is lower than the stock platinum sensor so the bull bar does not interfere. The sonar sensors work fine in the new bumper as long as you get it with the cutouts!
    Kichinko[QUOTED] likes this.
  13. Jul 1, 2020 at 7:59 AM
    #313
    SGT CRUZ
    SGT CRUZ New Member
    Felix
    TRD Pro 2019
    C4 does not interfere with the TSS of TRD Pro 2019???
  14. Jul 1, 2020 at 9:24 AM
    #314
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Subbed
  15. Jul 21, 2020 at 7:37 AM
    #315
    King R 808
    King R 808 New Member
    Ryan
    2020 White Tundra TRD Pro
    TundraOverland_2000x.jpg and the wait begins! Cant wait for the bumper to come in!
  16. Jul 24, 2020 at 9:14 AM
    #316
    matictundra
    Franco
    AZ
    Rear finally done.
    don3032, Dantdodge, Ob1 and 6 others like this.
  17. Jul 24, 2020 at 9:31 AM
    #317
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Looks great matic!
    matictundra likes this.
  18. Jul 25, 2020 at 8:42 PM
    #318
    equin
    Ed
    DFW, TX
    Nice! Which bumper is that?
  19. Jul 25, 2020 at 8:44 PM
    #319
    equin
    Ed
    DFW, TX
    Never mind! I see it’s a C4Fabrication bumper:
    weirdbeard likes this.
  20. Sep 30, 2020 at 1:06 PM
    #320
    Heatjay
    Heatjay New Member
    2018 TUNDRA PLATNIUM MG
    Are there any makes of a front bumper that allows to you keep your parking sensors, etc
    King R 808 likes this.
  21. Sep 30, 2020 at 1:09 PM
    #321
    cctxquicksand
    I think most have to be modified. Most manufacturers will drill the holes if you ask them before hand
  22. Sep 30, 2020 at 1:23 PM
    #322
    turkeycreek29010
    turkeycreek29010 New Member
    Chuck
    Bishopville SC
    2019 Cement Tundra Crew Max
    3/1 Level Kit, 20 inch Gear Wheel, 285/65/20 BFG
    Mine came with holes for parking sensors. I used the supplied plugs since mine does not need them. This is the Extreme Terrain bumper.
    equin likes this.
  23. Sep 30, 2020 at 7:01 PM
    #323
    King R 808
    Ryan
    C4 overland just got installed today!
    GODZILLA, equin, Rbohno and 1 other person like this.
  24. Oct 1, 2020 at 5:34 AM
    #324
    COTundra23
    COTundra23 New Member
    Looks great! Have any other angles?
  25. Oct 1, 2020 at 5:42 AM
    #325
    captjeff and equin like this.
  26. Oct 1, 2020 at 5:55 PM
    #326
    King R 808
    Ryan
    1F178E2B-7D4D-4825-8A1B-667F7C673243.jpg 8384CD8C-EF3C-416C-8D0F-01C7FB9A8FDF.jpg
  27. Oct 4, 2020 at 10:54 AM
    #327
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    I didn’t notice a pic of this option anywhere, but could be mistaken.
    HammockYota, GODZILLA and equin like this.
  28. Oct 5, 2020 at 3:06 PM
    #328
    COTundra23
    Congrats! What is their estimated lead time right now?
  29. Oct 5, 2020 at 4:05 PM
    #329
    2manytoys
    2manytoys New Member
    Lupe
    Carlsbad, New Mexico
    2017 black tundra crewmax
    Fab fours premium bumpers frt & rr, retracing bed cover, 5% window tint cept frt which is 60%, has lift from dealer maybe 3 inch
    On mine they asked if it had sensors, I told them no. Fab Fours frt and rr. 2017 Crew Max 2017 Tundra5.jpg
    Widows Son and King R 808 like this.
  30. Oct 5, 2020 at 4:08 PM
    #330
    Rbohno
    Rbohno New Member
    Rich
    NC
    New
    About 8 weeks, you can pay $50 week for each week to have it rushed.
    COTundra23[QUOTED] likes this.
