Let’s see pics stock height Pro with 295/70r18
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by jordanpop1, Sep 11, 2018.
  1. Jul 6, 2021 at 5:56 AM
    #391
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
    2020 Tundra TRD Pro Double Cab Army Green
    Driver side grab handle Door sill protectors Falken WildPeak 295/70 R18 X-Pel clear front paint protection 20% front window tint Go Rhino RB20 side steps - Bedliner finish Lock'er Down 1/2 console safe Toyota bed cargo divider Toyota auto tail gate lock
    I can't answer that. The 295's are pushing the limits. I think the 305's may hit the UCA unless you run wheel spacers on the OEM wheels or change for more negative offset wheels. The consequence of the wider offset is to get tire rub against the front plastics. There is a kit available to move the front bumper forward. Others have used a heat gun to soften and reshape the plastics. Hopefully, some who have tried it will chime in here.
  2. Jul 17, 2021 at 8:45 AM
    #392
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Bit the bullet. Glad I did. I have CB +2 shackles and strut shims for the front ready to go. Just have to find time to install them.
    The progression from stock to 275/70’s to 295/70’s..
  3. Jul 17, 2021 at 10:34 AM
    #393
    TelemarkTumalo
    Mark
    Bend, OR
    Looks awesome!
    FISHN43[QUOTED] likes this.
  4. Jul 17, 2021 at 11:09 AM
    #394
    FISHN43
    FISHN43 New Member
    Ohio
    Thank you! As does yours! :thumbsup:
  5. Jul 20, 2021 at 3:19 PM
    #395
    cochese
    cochese New Member
    Oregon
    '21 Lunar Rock TRD Pro Double Cab
    Not too many Doublecab Pro's in this thread with 295s, so here are some pics. Went with the Falken Wildpeaks based on some good advice here. Impressions so far:
    - Smooth, but def more firm
    - Not much noise on the freeway, like I didn't notice any difference. This may change with more miles.
    - Ride comfort-wise, I can tell they are new tires but the delta from stock is not big at all
    - Just took a spin around the neighborhood and no rub whatsoever at full turn going forward. Still need to test backing up at full turn. (I removed the front mud flaps prior to install)
    Overall happy with them. I was nervous about the swap but feel better already. Gas may take a hit...meh it's already not great.
  6. Jul 20, 2021 at 6:22 PM
    #396
    FISHN43
    FISHN43 New Member
    Ohio
    Good choice! Looks great! I just put the same on mine. :thumbsup:
  7. Aug 10, 2021 at 10:18 AM
    #397
    cochese
    cochese New Member
    Oregon
    Was looking at my truck from the front this morning and noticed that the front tires camber looks a little steeper than level. Worried about tire wear on the outside edge of the new tires.
    Didn’t notice this with the stock Michelins and didn’t notice this when I first had the Wildpeak 295s installed. Do folks usually get alignment checked when moving up in tire size? Or is a little bit of camber angle in the front normal and I just didn’t notice it before?
  8. Aug 10, 2021 at 10:28 AM
    #398
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    I always get my alignment checked when installing new tires - too much investment not to be sure all is good. My Toyota dealership has a machine that auto-checks alignment when driving through - about the only freebie they offer!
    cochese[QUOTED] likes this.
  9. Aug 10, 2021 at 10:57 AM
    #399
    TommyTundra
    TommyTundra Oh God the anger’s changing me
    Long Island NY
    2019 PRO
  10. Aug 29, 2021 at 6:55 PM
    #400
    Beer Man
    Beer Man @cement.tundra
    2021 SR5 XP CrewMax Cement
    Question for you 295/70r18 guys:
    Non pro, but I’m installing the Eibach 2.5” pro stage 1 coil over lift this week. Nothing in the rear for now. I have a set of SCS Ray 10 18x9 25mm offset sitting in my garage waiting to go on shortly after. I’m so torn on tire size I can’t even think straight anymore.
    Will these 295s fit? I think from what I’ve read the 25mm offset of the SCS wheels will help get the tire further away from the stock UCAs, so that won’t be an issue right? I already took the mudflaps & inner front flaps off day 1.
    The front lift should make the 295s possible? Is the Pros rear any higher than an SR5?
  11. Aug 29, 2021 at 6:57 PM
    #401
    mfranzen89
    mfranzen89 New Member
    Mat
    Kansas City
    2021 Tundra TRD Pro LR
    Got them put on yesterday. Originally ordered the KO2’s but was told they are not made anymore.
    Navi, Cb19, WawaLunar and 3 others like this.
  12. Aug 29, 2021 at 7:49 PM
    #402
    TelemarkTumalo
    Mark
    Bend, OR
    Tire fitment issues on the Tundra are usually not with tire height to the top of the fender or the amount of lift. However, the width and offset or your wheels MAY present a challenge for you. If you love those wheels and tires, you can make them work. I can foresee rubbing issues for you directly in front + laterally. The plastic fender liner can be molded and bent forward using a heat gun to create space. Many have had good luck with this mild maneuver. There is also a kit of spacers made to move the entire front bumper assembly forward ~3/4". Apparently, it does the trick without any cutting, bending or chopping, and can be completely reversed by you or your next buyer.
    Ghosty and Beer Man[QUOTED] like this.
  13. Aug 30, 2021 at 10:11 AM
    #403
    Gamer68
    Gamer68 New Member
    2016 Toyota Tundra limited
    2.5 front lift//Hooke Road Front Bumper w/lightbar//20" Black spoke Fuel Wheels//Weather Tech Floor mats//Black Waterproof seat covers//Hard tri-fold tonneau cover//
    Looking at a KPS 3" front spacer and 2" rear spacer kit for my '16 crewmax. Just wondering if it is something you can do in the garage? The kit looks pretty straight forward, just bolt in the spacers front and rear. Maybe an alignment afterwards? Any input would be greatly appreciated my brothers.
    B
  14. Aug 30, 2021 at 4:11 PM
    #404
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2025 sequoia MGM TRD PRO
    Stock horse
    Just ordered a set of cooper s/t maxx 295 70 R18 for my pro I really hope they suck for New England weather. I’m coming from a 285 70 R18 Toyo open country mt which I love the look of but hate the tire. Mine started cracking 3 months in. Still have tread but scared they are gonna blow up due to the dry rot and cracks.
    mfranzen89 likes this.
  15. Sep 3, 2021 at 10:43 AM
    #405
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    Going in tomorrow for some 295-70-18 Toyo Open Country AT3s. I currently have a readylift sst pro plus 2 (extra 2"lift front and rear for TRD Pro) along with CB +3 shackles. Not to mention I will be keeping on my spidertrax 1.25" spacers. Hopefully there is no rubbing if I remove the front mud flaps so I am both nervous and excited.
    Mark73, FISHN43 and War_Wagon312 like this.
  16. Sep 8, 2021 at 4:45 PM
    #406
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Stock Pro suspension with 285/65 Nitto Trail Grappler M/T. These came on the truck and thankfully are at about 6/32nd. They gotta go, loud as hell on the highway. I gotta do something about the trailer squat too, probably order up some shackles. I’m coming from a 17’ SR5 that had a ToyTec 3.5” lift and shackles, running 35’s, and Total Chaos UCA’s. I loved the look but it’s nice to have the power and mileage back, and the Fox Shocks ride.
    Trailer squat
    War_Wagon312 and iHacker like this.
  17. Sep 8, 2021 at 5:06 PM
    #407
    War_Wagon312
    Rich
    Stock horse
    295 70 R18 cooper st maxx with spidertrax 1.25 spacers. Took off front mud flap and pushed the fender liner in a bit.
  18. Sep 10, 2021 at 6:26 PM
    #408
    Gamer68
    Gamer68 New Member
    Anybody have any input on the above question? Just looking for feedback on install and is it worth it.
    Thanks again
  19. Sep 10, 2021 at 6:52 PM
    #409
    FISHN43
    FISHN43 New Member
    Ohio
    Probably not getting any feedback because this is a thread about TRD Pros with 295/70R18 tires. You’d have better luck posting this question in the multitude of threads about lifts. The search feature is your friend! But to answer your question.. don’t use spacers. Go with 6112/5160 Bilstein combo. Theres plenty of info on here about that!
    MVRCA and mfranzen89 like this.
  20. Sep 10, 2021 at 7:31 PM
    #410
    War_Wagon312
    Rich
    Stock horse
    Ya man if you throw it in the search a ton of threads are available. If you don’t feel like searching I would start a new thread in the 3rd gen section. I wouldn’t be able to answer that confidently. Don’t want to give you bad info.
  21. Sep 27, 2021 at 7:51 PM
    #411
    jretrdpro
    jretrdpro New Member
    Cental Michigan
    2021 TRD Pro CM Lunar Rock
    Thanks for all the info in this thread, got my new shoes installed tonight.
    MVRCA, GWill, cochese and 8 others like this.
  22. Jan 4, 2022 at 8:08 AM
    #412
    TrdPro89
    TrdPro89 New Member
    Stock Height? Offset on your wheels? Any rubbing?
  23. Jan 10, 2022 at 4:26 AM
    #413
    KSshorthair
    KSshorthair New Member
    2021 TRD Pro Lunar Rock
    Toyo Open Country AT3 295/70/18 - Just had to remove the front mini flaps. All good otherwise with mild off road and city driving.
    RainMan_PNW, Steve18 and kleiker0303 like this.
  24. Jan 12, 2022 at 9:45 AM
    #414
    espdtrd
    espdtrd New Member
    21 TRD PRO Lunar Rock
    TRD PRO Inserts, bedliner, led interior lights, console lock, console charger, TRD Black Shifter, Ceramic Tint, 275/70/18 Nitto Ridge Grapplers
    What load? Looks good!
  25. Jan 12, 2022 at 9:48 AM
    #415
    FISHN43
    FISHN43 New Member
    Ohio
    295/70R18 Falken Wildpeaks only come in E load.
  26. Jan 28, 2022 at 10:58 AM
    #416
    Canadian Army TRD Pro
    Canadian Army TRD Pro New Member
    Canada
    2020 Army Green Tundra TRD Pro
    295/70 STT Pros installed while back. I ran these previously on another truck and loved them. No spacers, but have 1.25s ordered..theyre awfully close to the UCA so I'll push em out. 20220121_092813.jpg 20220121_092935.jpg
    Downytide, Cb19 and FISHN43 like this.
  27. Feb 7, 2022 at 11:35 AM
    #417
    Navi
    Navi New Member
    2019 CrewMax Limited
    are you still running the rack system i can see in this pic? would like to know what you got and how you like. i'm considering the same. did not see if you had a specific build page or i'm missing it.
  28. Feb 18, 2022 at 9:08 AM
    #418
    ackthresher
    ackthresher New Member
    Jamie
    2017 cement crew max tundra pro
    Have pics of your truck?thanks I’m thinking the same route!!!
    RoniusMaximus[QUOTED] likes this.
  29. Feb 18, 2022 at 9:13 AM
    #419
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    If you add spacers, will you rub the body mount or other spots? My 295/70/18 Mickey Thompson Baja Boss are millimeters away from the control arms at the moment.
  30. Feb 18, 2022 at 7:08 PM
    #420
    RoniusMaximus
    J
    Yeah of course. Here you go.
