Leg support not working
Discussion in '3rd Gen Tundras (2022+)' started by Ridgeman58, Apr 1, 2024.
  1. Apr 1, 2024 at 12:32 PM
    Ridgeman58
    Ridgeman58 [OP] New Member
    Scott
    Army green 1794 edition
    I purchased my 2023 Tundra, 1794 Edition, 3 months ago. I have been experiencing problems with the driver's seat leg support repeatedly not working. The dealer fixed it a couple of times, even replacing the bottom frame of the seat. The last time I had it fixed I was told that I can't push the support all the way up or down because there is no mechanical stop and it will run off the track and stop working. At this time, that is Toyota's fix for the problem. Has anyone else experienced this?
    All comments are welcomed.
    Thanks,
    Scott
  2. Apr 1, 2024 at 6:33 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Take it to another dealer.
    I've heard of this thigh extender to stop working or working intermittently on some of the trucks... And dealer would replace the unit to fix it. These issues doesn't seem to be frequent on the forum so I assume it's not as common.
    I've been lucky enough with mine to always work and I never have to think twice about extending it all the way out or in... Never heard that you aren't supposed to be doing this. Some bs
    USNVET65 likes this.
  3. Apr 2, 2024 at 5:23 AM
    Ridgeman58
    Scott
    Thanks for the input Kap1!
  4. Apr 2, 2024 at 6:15 AM
    JackMick
    JackMick New Member
    24 Platinum
    Mine stopped working twice in the all the way down position. I jiggled the wire, pushed on the seat and pushed the button all at the same time and it started working fine again. I wont take it all the way down again though.
    Tom976 likes this.
  5. Apr 2, 2024 at 6:21 AM
    Jettster
    Jettster New Member
    2023 Tundra 1794 TRD Off Road
    TRD Pro Wheels and Tires
    I had mine stop working after I raised the seat up trying to find a way for a 6 foot tall person to see out of the truck lol...found the best compromise I could and then the cushion extender wouldn't work...took it to the dealer, showed the check in guy, the service writer went out to confirm and came back in 2 minutes to show me it worked...you do have to hold the button for a second...IDK.
  6. Apr 2, 2024 at 6:52 PM
    2494 New Member
    2024 Tundra 1794
    I’ve got 800 miles on mine and it doesn’t work
    cartage1 likes this.
  7. Apr 2, 2024 at 7:38 PM
    Chugbug
    Chugbug New Member
    2023 Platinum, Midnight Black
    I noticed when I first got mine that if I keep it all the way in and leaving it there, it seems to "stick". I started to run it in then extend it out just a hair and I never had a problem with it since.
    Tom976 likes this.
  8. Apr 3, 2024 at 4:34 AM
    2494 New Member
    2024 Tundra 1794
    Ok. Mine worked intermittently at first but now not at all. I’ll try to bang it, fram it, rattle wires as others have suggested. Is it just me, or is it concerning that this forum is riddled with new owners coming up with diy tricks to overcome lack of fit and finish by Toyota on a 70k truck?
  9. Apr 3, 2024 at 6:46 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I personally think it’s great that you guys are beta testing for me. :D
    Tundrastruck91 and catus like this.
  10. Apr 4, 2024 at 12:42 PM
    KuehnMK
    KuehnMK New Member
    2023 Tundra Crewmax 4X4 Platinum
    I've had my Platinum Tundra since 08/2023....the seat leg extender button is intermittent at best....I read this thread yesterday....tried adjusting the leg extender last night... Nothing...I definitely hear clunks and thunks in the seat bottom...nothing extends though....
    THEN this AM, start up my Tundra, immediately try to adjust the seat extender....WORKED AS INTENDED.... What's up TOYOTA?!
  11. Jun 11, 2024 at 3:32 PM
    USNVET65
    USNVET65 New Member
    Sylvan
    I bought a Tundra 2023 Capstone same problem and two dealers said they know nothing about it. One even said he has no idea about the gas line recall. seems the right hand does not inform the left hand what is going on
  12. Jun 11, 2024 at 3:54 PM
    Chugbug
    Chugbug New Member
    Mine did the same. After I use it, I run it most of the way down and I've never had a problem with it since.
  13. Jun 11, 2024 at 4:05 PM
    rlc177
    rlc177 Data Logger
    Northeast PA
    I think there is a TSB about this out finally, but I don't know the number or know the text its not public on NHTSA yet.
  14. Jun 11, 2024 at 5:17 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    I work on the other end of Toyota and sure as Hell don't know every TSB! NOT all dealerships are the same I agree, but knowing all the TSBs on alllll of these vehicles is impossible without putting in the Vin and start searching.
    Probley call and ask form them to look up a particular issue and have them call you back or ask for the service manager or call Toyota directly? Service writers are none stop, been there done that lucky if you get a piss break some days.
    My seat (leg ext) have been working great @ 9500 miles.
    Hella Krusty likes this.
  15. Jun 11, 2024 at 5:25 PM
    Hella Krusty
    Hella Krusty New Member
    Mine works fine, I adjust it every few days depending on the duration of the drive. Its a 22
  16. Jun 11, 2024 at 7:23 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    If heated or cooled seats are on it won’t work, search feature works wonders folks!
    TundraDan723 likes this.
  17. Jun 11, 2024 at 10:59 PM
    jduffy192
    jduffy192 New Member
    2024 Platinum TRD OR standard bed
    Mine stopped working the second time I tried to use it under 500mi. Have an appointment Friday to have it looked at. 24 Plat TRD OR
  18. Jun 11, 2024 at 11:30 PM
    Rockpig
    Rockpig You did what?
    08 Limited
    Just picked up my 1794LE today, didn't mess with the seats to much but will check this in the morning! I can say this though, my tailbone hurt after sitting in it for 3 hours on the drive home. The saddlebag seats are gorgeous but very stiff.
  19. Jun 12, 2024 at 6:07 AM
    pwpblue
    Greensburg,PA
    I did not know this:monocle: I will confirm this after work today.:hattip:
  20. Jun 12, 2024 at 6:55 AM
    TTman
    TTman New Member
    2024 1794 Celestial Silver
    Stock
    I have a '24 1794. I have found if I run the leg support all the way out it will stick there. When I try to run it back I hear the mechanism trying to work but it sticks. If you bump the switch a few times it seems to free the issue. I hope Toyota has put out a TSB on this. It seems to me a stop just prior to full extension would do the trick.
    MoeChins likes this.
  21. Jun 12, 2024 at 8:36 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    thats why they gave you heated seats...turn it on once it starts hurting. These have got to be the worst seats ever
    Rockpig[QUOTED] likes this.
  22. Jun 12, 2024 at 9:00 AM
    Hella Krusty
    I would take these seats over the planks in my 2012 Tundra
  23. Jun 13, 2024 at 9:16 AM
    DexterL
    DexterL New Member
    The 2g and 2.5g seats are light years better in terms of comfort. My 3rd gen was always just “okay”. Our pro Seqouia with seat jackets is a damn lounge chair, only thing I’m really missing are vented seats- all my prior gen tundras were platinums with the vented seats, which barely worked but made a big difference
  24. Jun 13, 2024 at 9:35 AM
    Hella Krusty
    My 3rd Gen cool vents are lame compared to the wifes 2019 Lexus. I prefer the 3rd Gen for comfort, polar opposite of you LOL
  25. Jun 14, 2024 at 3:45 AM
    pwpblue
    Greensburg,PA
    False!
    C6Bill and Tundrastruck91 like this.
  26. Jun 15, 2024 at 10:52 PM
    jduffy192
    Techs said the driver seat track/frame assembly is the issue. Part is on back order
    pwpblue likes this.
  27. Jun 16, 2024 at 11:53 AM
    TheMuffinMan
    TheMuffinMan New Member
    Idaho
    2021 DCLB SR5
    Next step is to replace your legs! :D
  28. Jun 18, 2024 at 12:41 PM
    Marc4x4
    Marc4x4 New Member
    Dealer replaced seat track and frame, works sometimes mostly doesnt.
  29. Jun 18, 2024 at 12:57 PM
    jduffy192
    sweeeeeeeeet
  30. Jun 26, 2024 at 9:14 AM
    anthonyo89
    anthonyo89 New Member
    Anthony
    2023 Platinum
    Hey Scott. My 23 Platinum has been to the dealer 5 times for the leg extender. Just picked it up yesterday and it was because the “track” was bound up. They’ve replaced the assembly twice. Basically what I’m saying is you’re not the only one unfortunately!
