Leer 100 XR
Discussion in 'Tonneau Covers, Caps and Shells' started by TomyTun, Aug 8, 2018.
  1. Jan 21, 2019 at 5:41 PM
    tundracap
    tundracap New Member
    NC
    2017 CM Limited 4x4 Silver Sky Metallic
    This is how my Leer XL is clamped.
    I may replace with these as it will let me move the position of the clamps, which has been a problem a couple of times.
    Nice find.
  2. Jan 21, 2019 at 5:44 PM
    JNome
    JNome New Member
    Jake
    Michigan
    2018 Tundra Crewmax SR5 Cement
    Yeah they seem pretty solid and well engineered. Does your XL have a small “tab” of fiberglass that the bolt goes down through into the T nut? Just trying to confirm so I can explain to dealer.
  3. Jan 21, 2019 at 6:15 PM
    tundracap
    NC
    Yes, and I wish it didn't. It has interfered with a couple of things I wanted to do, and it makes it so the T-nut can't be moved in the bed track.
    Once I get some of the clamps, I will probably cut the circular section that sticks out for the bolt to go thru with a Dremel.
  4. Jan 21, 2019 at 6:20 PM
    wh4x4
    wh4x4 New Member
    I had my Leer 100XR installed Jul '16 -- options added: Thule rack and square bars, light, front drop down and sliding window, headliner, single hanging rail, single, light. It was $2212, minus a $225 factory discount. $50 for a 7-way harness for clean install to tap in to the harness for the hitch plug (e.g. no splicing). The dealer didn't charge extra for clamp to attach to factory rail. It looks to be just a washer on top (see pic).
    I would recommend getting a strip of PPF where the back glass hits the tail gate. My paint started rubbing off before I noticed and applied the PPF.
    I just noticed that the right side is a bit closer to the truck side (about 1/4 inch gap), than left (5/8 inch gap). Not sure if it has shifted or if it was like that when installed. When it gets warmer, I am going to try and loosen the clamps and even it out so it doesn't have a chance to rub the paint.
    Edit: Based on a bolt and washer system, I don't think you can re-position the location on the rail where it attaches.
    Ronin likes this.
  5. Jan 21, 2019 at 6:49 PM
    tundracap
    NC
    Correct, unless you get some of the clamps JNome noted above.
  6. Jan 22, 2019 at 6:52 PM
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    Well mine was installed right into the metal by my dealer and they still saying it ok
  7. Feb 23, 2019 at 3:56 PM
    midniteblklngbd
    midniteblklngbd New Member
    mike
    hudson valley new york
    2019 sr 5.7 4x4 dc long bed
    I just bought a leer 100R; fits well. looks good and its on a 8 foot 1" bed.
  8. Feb 23, 2019 at 5:57 PM
    SiberianTundra
    Greg
    War Machine
    Thats insane how long that camper shell is hahahaha looking good !
  9. Feb 24, 2019 at 6:37 AM
    midniteblklngbd
    mike
  10. Feb 26, 2019 at 5:07 PM
    GeoJoe
    GeoJoe 2018 Tundra SR 4x4 5.7L Looooooooong Bed
    3/1 lift on 20" OZs with KOs, LED fogs, steps and a handle
    Very cool... first I've seen of this on a long bed. Nice work.
  11. Mar 11, 2019 at 10:27 AM
    TMOD
    TMOD New Member
    2019 SR5 4X4
    So the frame-less rear door (100XR) is the higher priced trim level? Is it just a styling thing? It would seem to me the framed rear door of the 100R would be the upgrade. I got a quote for both with the 100XR being $200 more. The only difference I can find is the framed vs frame-less door and the 2 handle vs. 1. Not sure it's worth $200. What am I missing?
  12. Mar 11, 2019 at 11:15 AM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    That's pretty much it. It's obviously subjective on the looks, but if you like the double hinge framed style of the R better than the XR then you might as well save the money!
    TMOD[QUOTED] likes this.
  13. Mar 11, 2019 at 1:37 PM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    It seems to me the double handle has a better design to let water out on the two corners vs the single. But doesnt look as nice so its a toss up.
    TMOD likes this.
  14. Mar 11, 2019 at 1:47 PM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    Also on a recent visit to get new seals on my rear door dealer said Leer now owns Snugtop. But they are still manufacturing at their own facility.
  15. Mar 17, 2019 at 11:27 AM
    midniteblklngbd
    mike
    IMG_0173.jpg I paid $1680 installed for the 100R before taxes. Very happy with the look, fit, color match and was delivered and installed in about 2.5 weeks. Also got a free carpeted headliner.
    Has sliding windows on each side with screens and double t handles with locks on lift gate, third brake light and a battery operated dome light. Dome light is the only negative of the model. To be upgraded with leds in future. It was installed with J hooks directly into the cargo hold down rails. I installed the hold downs prior to the cap install. Yes, the cap is on a 8' 1" bed.
    BuckWallace likes this.
  16. Jul 12, 2019 at 12:12 PM
    spyshot
    spyshot 1Cor 15:55-57
    Ohio
    2019 Tundra Platinum
    Platinum pretending to be Pro
    Sorry to resurrect an old thread, but I’m wondering what the access is like of the sliding side windows on the XR on a Crew max? I am thinking about getting one with the flip-up side windows so I can access the bed easier but I’m wondering if the slide windows would be just as well without the extra expense. My old truck has the flip up side windows and I love them. But the bed is a little longer.
    Anybody have any pictures of their XR side windows open?
  17. Jul 12, 2019 at 12:20 PM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    If you're frequently needing to access from the side I'd definitely get the flip-up windows. The sliding windows would give you a little less than half the access (when open, the windows stick out a couple inches past the middle divider), plus you'd have to climb inside to open them every time. You'd also have to ask for no screens or remove them as the sliding windows come with screens.
  18. Jul 12, 2019 at 12:23 PM
    spyshot
    Ohio
    Ok. Bummer. I really like the key fob locking, but getting flip up side windows will negate that feature somewhat. Thanks
  19. Jul 12, 2019 at 12:29 PM
    #49
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    You won't have nearly the same access. With just the sliders, you won't get much more access than just getting it out from the liftgate.
    I didn't get windoors on my Tacoma when I got a Leer 100XR in 2012. I did for the Tundra. If you already have windoors, I think you'd regret it. Here's both and you can see how much more access you get.
    Tundra805, Ronin and ardnutoz like this.
  20. Jul 12, 2019 at 12:56 PM
    #50
    spyshot
    Ohio
    Yep i think you’re right. I will regret it.
  21. Jul 27, 2019 at 5:12 AM
    #51
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    They have a good warranty... after 16 years on my 2002 Tundra, my 8 foot LEER 122 was returned to the factory for warranty repair or replacement.
    They replaced it with this 100R at no charge.
  22. Jul 27, 2019 at 8:47 AM
    #52
    sbxx312
    sbxx312 New Member
    I got a new window when the first one was leaking on my Tacoma. I think they can just replace the slider with a windoor.
  23. Aug 8, 2019 at 3:38 PM
    #53
    Ronin
    Ronin Hoof Hearted
    Bill
    2019 CrewMax 5.7 Tanker
    100XR
    Awesome! Paint match was beyond expectation! Fit and finish is badass.
    Thanks for all the guidance in this thread!
  24. Aug 8, 2019 at 5:45 PM
    #54
    Bigfish9202
    Bigfish9202 New Member
    Wisconsin
    2019 TRD Limited Crewmax
    Matched mirror caps, Black Door handles, KO2 275/70, 6112/5100, Leer 100XR, PRO Grille, RCI Skids
  25. Aug 16, 2019 at 4:23 PM
    #55
    dryrock
    dryrock New Member
    2019 Mesquite Tundra 1794
    Just had the dealer initiate a transfer to get a Tundra for me today. Shopping for a cap. Could someone take a measurement of the vertical clearance between the bed/tailgate and the top opening of the cap? Trying to figure out if I can fit a slider in with bicycles mounted on fork mounts and have it clear the cap in and out. Or will I have to buy one of the mid-rise caps?
  26. Aug 16, 2019 at 7:31 PM
    #56
    sbxx312
    sbxx312 New Member
    Bikes won't fit unless it's a kid's bike. You'll need one of those taller caps. Not for me, but lots of people have them.
  27. Aug 16, 2019 at 8:57 PM
    #57
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Got my xl for $500
  28. Nov 8, 2019 at 9:46 AM
    #58
    sbxx312
    sbxx312 New Member
    The hinges on my 100XR window are freezing, which is a pain in the ass. I can turn the handle which pulls the cable, but it won't release the window at the hinge. It's happened a couple times after freezing rain or snow. Thaws out and works fine. Second time my scraper was back there after a ton of snow. I never had this issue with my other 100XR, but that truck sits in the garage.
    And I have some leaking inside from the roof rails, but that's my fault. Going back in next week.
  29. Dec 17, 2019 at 7:56 PM
    #59
    kwesterh
    kwesterh New Member
    Kurt
    2023 MB Sprinter
    Ordered a 100XR today. Has anyone done any additional lighting beyond what comes from the factory that they can share?
  30. Dec 18, 2019 at 3:28 PM
    #60
    doubleHaul
    doubleHaul New Member
    2017 White TRD PRO
    RedyLIFT 2" SST LIFT KIT - TOYOTA TRD PRO PLUS 2
    Good photo. Helps seeing this to make a decision. I am unable to make up my mind with either a SnugTop or Leer. Looks like the snugtop design drops a little below the truck bed, covering the lettering on the side of the truck, from what i have seen.
