LEDs in 2008 Tundra causing electrical problems?
Discussion in 'Lighting' started by firetac, Jun 26, 2016.
  1. Jun 26, 2016 at 11:54 AM
    firetac
    firetac [OP] New Member
    Rich
    2008 Toyota Tundra
    Yesterday, installed LEDs in my 2008 Tundra. Daytime running, stop, directionals and back-up. After installing, brake lights stopped working. replaced blown fuse. Then all lights quit working and transmission shifter locked into park. After checking all of the fuses and replacing ones that were blown, took out all of the LEDs and replaced with OEM bulbs. Problem solved. These were not "cheap" LEDs. Have to return them.
  2. Jun 26, 2016 at 6:13 PM
    David2013Tundra
    David2013Tundra New Member
    David
    2013 Tundra DC 5.7
    I installed the led on my 2013 DC just like yours, including my dome and map lights...everything works fine. A load resistor needs to be installed for your DRL and rear turn signal to prevent issues. When I did not install the load resistors, I got blown fuses.
  3. Jun 26, 2016 at 8:33 PM
    DLack33
    DLack33 New Member
    Dylan
    2010 Slate Tundra SR5
    You might have used standard bulbs instead of CK bulbs
  4. Jun 26, 2016 at 10:33 PM
    mdc1192
    mdc1192 New Member
    Matthew
    Silver 2010 Tundra TRD Off Road.
    I did the same thing for my Front turn signals. And it blew the fuse to my tail lights. I later learned you have to add a Resistor.
  5. Jun 27, 2016 at 11:36 AM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    If you don't use CK style bulbs it will definitely cause major problems. Regular bulbs will short out your lighting circuits.
