LED turn signal drl swap
Discussion in '2.5 Gen Tundras (2014-2021)' started by Youravguy, Aug 12, 2017.
  1. Aug 12, 2017 at 5:59 PM
    Youravguy
    Youravguy [OP] New Member
    Black Tundra
    Anyone has any good luck with changing out the DRL/Turn signal bulb to a white LED bulb that works good? I tried one off of Amazon and it kept blowing a fuse. Recommendations needed. Brand and bulb size pleas. TIA. I have a 17 Tundra btw.
  2. Aug 12, 2017 at 6:09 PM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    Are you trying to do a switchback type bulb( amber colored with headlights off or turn signal on and white with headlights on)? Also if it kept blowing the fuse check the base to see if the metal around it is grounding it out. Had this problem with a led conversion in my dome lights.
  3. Aug 12, 2017 at 6:12 PM
    Youravguy
    Black Tundra
    No. Just wanted it white and not amber. I checked with manufacturer and they said I needed a resistor. I've checked to see if it's grounded out and it's not.
  4. Aug 12, 2017 at 6:14 PM
    Juanjoolio007
    Oregon
    its a 6ohm resistor that you need for the flasher. You can get them on Amazon or lots of other places....but for simplicity sake start at Headlight Revolution. Look for the switchback bulb...i know you want just white but they have a video on how to do install.
  5. Aug 12, 2017 at 6:15 PM
    Youravguy
    Black Tundra
    Ok I'll try that. Thanks.
  6. Aug 12, 2017 at 6:17 PM
    Juanjoolio007
    Oregon
  7. Aug 13, 2017 at 4:15 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    White turn signals will earn you a fixit ticket in most states.
    SouthBoundSteve likes this.
  8. Aug 14, 2017 at 7:40 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    not in ours ;)
  9. Aug 14, 2017 at 8:09 AM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    On the front anyway
  10. Aug 14, 2017 at 6:04 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
