LED tailgate strip.
Discussion in 'Lighting' started by Rockstar72, Feb 17, 2021.
  1. Feb 17, 2021 at 6:21 PM
    Rockstar72
    Rockstar72 [OP] New Hampshire in the house
    Kris
    Manchester, NH
    2020 Army Green Toyota Tundra TRD Pro Crewmax
    Hello. Has anyone ever put one of those LED light strips on the back of their Tundra? I was looking at some that have left and right directionals as well as reverse and brake lights. Just wondering which ones are decent and will fit in the spot without blocking the spare tire hole. Lol. Thank you.
  2. Feb 17, 2021 at 7:28 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    I have the Putco one - it does block the spare slot but it's held in by clips (held on by 3M adhesive) so it can come off to access the spare. Others say the turn signals and brakes are very clear, and the reverse light is quite good.
  3. Feb 17, 2021 at 8:10 PM
  4. Feb 17, 2021 at 8:15 PM
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    2018 Gray Tundra Platinum
    I have the Putco one too. Works well, has brake, turn signals and reverse light. I have no issue getting to the spare, it’s flexible enough.
  5. Feb 17, 2021 at 8:31 PM
    BigArt
    BigArt New Member
    2008 Tundra Crewmax Limited
  6. Feb 24, 2021 at 1:06 PM
    Freeezen
    Freeezen New Member
    I just ordered the Putco Blade and it is on back order until March 10, 2021.
  7. Feb 25, 2021 at 8:47 AM
    Dwarven1
    Dwarven1 New Member
    Ross
    2018 SR5 w/TRD Off-Road.
    2018 SR5 - Bolo Mark XXb - Unit DNE of the Line. "Denny"
    Hmm. From the installation instructions:
    Since I live in New England, where car washes are required every winter to get the salt off the undercarriage, that's a deal-killer for me.
  8. Mar 10, 2021 at 6:00 PM
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    I just added the Opt-7 triple to my 2011. Used magnets to attach it, so I can still access the spare tire hole if needed. Very happy with how it came out. Survived the first trip to the car wash today.
  9. Mar 10, 2021 at 6:51 PM
    Dwarven1
    Dwarven1 New Member
    Ross
    How'd you attach the magnets to the light?
    Rerun likes this.
  10. Mar 10, 2021 at 7:22 PM
    TravisJr
    TravisJr New Member
    Lots o’ mods
    I can try and get some pictures tomorrow, but basically I ordered up some circular earth magnets from Amazon. The light itself comes with a full-length adhesive mounting strip attached to the back. Instead of pulling the protective backing off of the whole strip, I just cut out small sections on the ends and at 20-inch intervals. Stuck the magnets to the adhesive and held pressure for a few minutes to get a good hold. Then slapped the whole apparatus up against the truck. An added bonus is that you can then play around with the light placement, sort of like a wet decal application. With the adhesive application, you’d have to get it perfect the first time out.
    The magnets do make it stick out about 1/8 inch more than just the adhesive would. Not noticeable visually, but when I lower the tailgate it *just* touches the plastic cover on the front of the light. No issues so far, but if you open/close the tailgate a lot, it would bear watching.
    rdiddy5 and Occidentalis like this.
  11. Mar 10, 2021 at 7:40 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Mine is an off brand with 3m tape and does indeed cover the hole. Luckily I haven't had to change out a tire with the spare in 5 years, if I do I'll rip it out!
    mav7021234 and Mike59 like this.
  12. Mar 10, 2021 at 7:52 PM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    That's smart! I put the 60" Opt7 on my 2015 recently and just used the little self trappers with the supplied brackets. They weren't great screws, but sufficient.
    Same clearance issue but I left the adhesive pads from a previous owner's brake light strip install as a cushion in case the tailgate did push down hard on the light under load.
    I am very sure the previous install forgot about having to access the hole and ripped it off on the side of the road or something. I found where they tapped the harness and I fixed it all up back to stock while I was doing the install. I completely missed all of it when I looked to buy the truck. I wonder what else I will find?
    All my wiring was done into a coupler that just plugs in and adds and extended and 4 pin split to the backside of the 7 pin under the hitch. The opt7 light just plugs in and you can just positap into the reverse in the extender. No factory harness mods required!
    Very easy install and happy with it so far. The one thing I will mention is that the coating over the leds is sort of tacky still, and was stuck with Florida sand in it before I even finished the install. I'm not worried about it but it will be something I want to watch as that sits out in the sun and heats up and whatnot.
  13. Mar 10, 2021 at 8:25 PM
    TravisJr
    TravisJr New Member
    Lots o’ mods
    I did the same. It was a Curt product that I also got from Amazon. Definitely recommend doing it this way. Extremely easy.
  14. Mar 11, 2021 at 7:18 AM
    Rockstar72
    Kris
    Manchester, NH
    I really like the magnet approach. The wiring I'm a bit nervous about as I've never wired anything but car audio and it's been years. Lol
  15. Mar 11, 2021 at 10:07 AM
    Freeezen
    Freeezen New Member
  16. Mar 15, 2021 at 12:18 PM
    BlueTundra2019
    BlueTundra2019 New Member
    2019 Voodoo Blue Tundra TRD Pro
    Lifted 8 inches, 37x13.50R22 on 22x12, Rhino BR5 Bumper with Warner winch, TRD Sway Bars, Full-size spare with matching rim in bed, Train horns, Rigid LED lights, Monster Hammer Head rope hooks.
    Which wire is the reverse wire in the extender ? Is it the center of the 7-pin ? Thanks!
    Mike59 and Occidentalis[QUOTED] like this.
  17. Mar 15, 2021 at 12:21 PM
    Occidentalis
    North Florida
    Yep! Very center, white wire. My tundra has the pinouts for the wires right on the plug at the hitch. First vehicle I've had that they thought to include it. This is my first personal Toyota and between the yellow replaceable interior panel clips and helpful stuff like that I have been impressed.
  18. Mar 15, 2021 at 12:29 PM
    TravisJr
    TravisJr New Member
    Lots o’ mods
    Yep.
  19. Mar 16, 2021 at 10:13 AM
    BlueTundra2019
    Works like a charm Thanks!
  20. Oct 24, 2021 at 12:56 PM
    Mike59
    Mike59 Kentucky Traveller
    Central Kentucky
    2021 Tundra DC Limited 4x4 SSM
    just now installed mine, looking for the reverse light wire.
  21. Oct 24, 2021 at 1:22 PM
    Occidentalis
    North Florida
    It's labeled on the rear bumper
    Mike59 likes this.
  22. Oct 24, 2021 at 2:22 PM
    Mike59
    Central Kentucky
    got it. It was a lot easier than I expected. This thread helped a lot!
    Occidentalis likes this.
  23. Jun 27, 2022 at 7:32 AM
    Hulkster529
    Hulkster529 New Member
    Ohio
    2018 SR Double Cab
    Running Boards, Delay Wipers, Interior Green LED Lights, Bug Shield, Bed Rail System Factory Fog Lights, Black Wheel Skins, Remote Start, FRAC System, 33% Tinted Glass, Heated Seats,Leveling Kit, Factory Entune Nav System, Spectre Air Box , Drivers Side Grab Bar, Window Vent Shades
    My light has a 4 pin connector. I don't want to have to plug it in the plug above the bumper. How did the rest of you wire yours? Mine came with no instructions. It is made by Auskin.
  24. Jun 28, 2022 at 7:07 AM
    TravisJr
    TravisJr New Member
    Lots o’ mods
    See post #15 above.
  25. Jun 28, 2022 at 7:38 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Pillar Tape, Bullet Liner, 20% Tint, Tyger Star Armor Kenwood amp & AudioControl LC7i Tech12volts JL Tweeters
    y'all gonna make me spend $ on the lightbar and the curt plug.
    Been wanting one but didnt want to splice any wires.
