Led Tail Lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by ZTundra, Mar 17, 2023.
  1. Mar 17, 2023 at 4:01 PM
    ZTundra
    ZTundra [OP] New Member
    ZACK
    Knoxville, TN
    2021 MGM Nightshade
    Anyone have a recommendation on led tail lights? I tried the search function, but only saw a few threads with people saying they liked a the brand they bought but hadn’t had them long. I see alpharex, recon, hirev, spyder, winjet, etc. What’s the best option? Anyone have a set they’ve had for an extended time they would recommend?
    Tundrastruck91 likes this.
  2. Mar 17, 2023 at 4:08 PM
    RobertD
    Robert
    DFW, Texas
    bulldog93, Henry1jg, GODZILLA and 4 others like this.
  3. Mar 17, 2023 at 5:56 PM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    I am considering the VLEDS tail light conversion. The products I've got from them are top notch .
  4. Mar 17, 2023 at 6:05 PM
    ThatGuyTheCooler
    ThatGuyTheCooler New Member
    I got these, AKKON for $199, very happy so far
    excelw and BlueRibbon4x4 like this.
  5. Mar 17, 2023 at 6:06 PM
    ThatGuyTheCooler
    Henry1jg and Voda48 like this.
  6. Mar 17, 2023 at 6:12 PM
    be_unscared
    be_unscared Not a truck doctor
    Brendan
    Central Cal
    21 Army Green w/skewp 4x4
    Alpharex if you can afford them, are really something special. Admittedly, I’m thinking about their headlights, but they make a great product.
  7. Mar 17, 2023 at 6:16 PM
    RobertD
    Robert
    DFW, Texas
    You get what you pay for. Still better than the 300 sets of cheap taillights that leak or burn out and have poor output.
  8. Mar 17, 2023 at 6:33 PM
    be_unscared
    Brendan
    Central Cal
    The fact that $300 is cheap for taillights makes my belly hurt
  9. Mar 17, 2023 at 7:13 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Recons here...
  10. Mar 17, 2023 at 7:25 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Second the Alpharex. Running them myself. Love them.
    Sleeper16plat and Tundrastruck91 like this.
  11. Mar 17, 2023 at 7:28 PM
    Ginsterkev
    Ginsterkev Lessons not learned in blood are soon forgotten
    Kevin
    Pennsylvania
    2019 tundra Trd pro supercharged
    Tvs1900 magnuson blower Team rxp catch can Wescott designs collar lift on fox factory suspension Front and rear TRD sway bars
    Hot tails option b here with the 3000 lumans reverse also did the vled front turn signals like everyone else says you def get what you pay for
    1lowlife likes this.
  12. Mar 17, 2023 at 7:51 PM
    ATV25
    Terry
    Redding, CA
    2019 Platinum
    It is a little ridiculous to pay $300+ for bulbs but sometimes you just gotta say f#ck it
    :spending:
    kbark, Ginsterkev and 1lowlife like this.
  13. Mar 17, 2023 at 8:11 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Now I got to compare these to the Mori's ... how long you have 'em installed and any issues ? Do these have those 'fins' like OEM ?
    https://www.morimotohid.com/
  14. Mar 17, 2023 at 10:33 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    ^ This..
    Well worth it.
    It isn't just bulbs you are paying for.
    It is the bulbs, the harness, and the resistors to prevent turn signal hyper flash as well as awesome customer service..
    It is also years of Colton's research that make this the best option for Tundra LED tail lights.
    Nothing wrong with the stock housing, it looks better than any after-market kits.
    ALL the aftermarket taillights look stupid and space-age and most use the halogen reverse bulb..
    I researched them for 7 years and settled on Hotshots.
    But I didn't settle, they are fu(Kin' awesome.
    Every time I stop and turn at night I see in my mirrors the VLEDs lighting up.
    When I sit in restaurant drive-thru lines at night I put my truck in park not to blind the cars behind me.
    @memario1214 option A kit is the second best mod I've done to my 2014 only second to the OEM headlights with the @iHacker harness.
    His communication and being a forum vendor is as good as it gets..
    You aren't going to get his customer service with other ugly aftermarket tail light assembly manufacturers.
    You are correct Sir....:cool:
  15. Mar 18, 2023 at 3:56 AM
    ThatGuyTheCooler
    I have not experienced any leaks, burn outs, or poor output, and have taken the truck through several high pressure no-touch washes. I figured multiple pressure washers at dif angles to be a pretty good test of water resistance.
    Since this is an opinion thread, I think mine look significantly better than the OE tails. How you guys can justify $400+ for a few light bulbs amazes me.
    Henry1jg likes this.
  16. Mar 18, 2023 at 4:46 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    2957E5F1-EC60-46C2-9332-CA2D01438A51.jpg Morimoto tails
    TNDRA6!9, Yodagan, jmladdy and 5 others like this.
  17. Mar 18, 2023 at 6:58 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Question is, do you want to change the taillight assembly out or keep OEM? Both good options.
    1. Aftermarket. There are a lot of good aftermarket options out there, depends on the look you're going for. Pick a reputable brand with good reviews and maybe some additional reviews from folks on here with what works and what doesn't.
    2. OEM Assembly. Personally, I replaced the light bulbs (x6) and converted them over to LED, 5000k (true white, not the blueish 6000k). I used the VLED, Vtails V6 Extreme tail light conversion kit. I liked the OEM assembly but did not care for the way it was wired up. The top light only activating when braking looked odd to me, especially when I followed other Tundras. I wanted more definition from my rear turn signals and this option fixed all that, red to amber. Both top and bottom lights are always on (low), both activate during breaking comparable to the sun (high), and it uses the same bulb for the turn signal and backup light. Great results and as others have said, you get what you pay for.
    https://www.vleds.com/featured-vehi...ndra-vt-v6-extreme-tail-light-conversion.html
    $352.76 + tax, free shipping. 15% Sale on everything going right now.
    Ginsterkev likes this.
  18. Mar 18, 2023 at 8:25 AM
    1UP
    1UP Truck Gang
    No fins like OEM. Have had them about 2yrs. No issues, love them still as much as I did 1st day. Only regret if you could call it that was not waiting for the current gen which has amber turn signals built into it. My gen doesnt have amber color.
    IMO Alpharex are hands down the nicest design and modern without looking "ricer" if you know what I mean. I don't think a "non tundra person" would even think they are aftermarket. They come off like a "modern" styled OEM tail light.
    Good luck!
  19. Mar 18, 2023 at 8:56 AM
    SR5BART
    SR5BART New Member
    Bart
    Chicago
    21 SR5 TRDOR
    Hot tails!!!
  20. Mar 18, 2023 at 10:00 AM
    Ginsterkev
    Kevin
    Pennsylvania
    Not gonna lie this is not a great representation of the hot tails but this is after I was done , it's option B only because I wanted the 3000 lumans reverse and I wanted the turn signals to be like oem so top and bottom blink and I will tell you that it is without a doubt night and day !
  21. Mar 18, 2023 at 4:05 PM
    ZTundra
    ZACK
    Knoxville, TN
    2021 MGM Nightshade
    I should have said this at the beginning, I have the nightshade package. There is nothing wrong with the Oem tails except that the red really doesn’t look great with the rest of the truck blacked out. So no hot tails for me. I like the look of the recon, but they are pricey and you still have to purchase the reverse bulbs on top of that. I think I’ve got it narrowed down to the alpharex and the morimoto.
    Henry1jg and Tundrastruck91 like this.
  22. Mar 18, 2023 at 4:56 PM
    Tundrastruck91
    Same ... really like the full led Mori's, just debating that price, ha ! Heard they collaborated with Me-So and I have both their dome and map lights for about a year now --they are quality ! https://mesocustoms.com/collections/toyota-tundra
    Sleeper16plat likes this.
  23. Jun 4, 2023 at 9:05 AM
    Kmm4444
    Kmm4444 New Member
    Tuscaloosa Alabama
    2020 Mag Gray Crewmax
    I like the look of OEM taillights so I went with Extreme Terrain OEM style Smoked taillights with HotShot Off Road Hot Tails Option A led bulbs and the Klearz 3rd Brake light with led bulbs. Completed the blackout look.
    Hot Tails led are an easy plug and play option with the smoked lenses.IMG_3606.jpg IMG_3605.jpg
  24. Jun 5, 2023 at 6:25 PM
    GeoJoe
    GeoJoe 2018 Tundra SR 4x4 5.7L Looooooooong Bed
    3/1 lift on 20" OZs with KOs, LED fogs, steps and a handle
  25. Jun 5, 2023 at 10:27 PM
    Tundrastruck91
  26. Jun 6, 2023 at 3:53 AM
    Cody1060
    Cody1060 New Member
    Ken
    Mid Michigan
    2021 Tundra 1794
  27. Jun 6, 2023 at 10:14 PM
    sbtownsend7
    sbtownsend7 New Member
    2021 Barcelona Red Tundra Limited
    Nothing.....YET
    I installed Hirev Sports LED tail lights and love them. I wanted a little more of a factory look, but get away from the stock tail lights. These were exactly what I was looking for. I went with clear lenses to match up with the factory front LED headlights on my '21 Limited. No problems thus far, but I've only had them a little less than a year.2021 Hi-rev.jpg
  28. Jun 7, 2023 at 6:53 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    These are interesting. Definitely different than anything else out there.
    Personally, I like Hi Revs and have them on my truck.
    300BLK likes this.
  29. Jun 7, 2023 at 8:35 AM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    2017 SR5 5.7 4x4 quicksand dbl cab
    So those are the coolest I’ve ever seen
  30. Mar 22, 2024 at 2:09 AM
    Ctaylor76
    Ctaylor76 New Member
    Chaz
    Houston
    2021 Tundra Supercharged
    BDS 4.5 inch coil over lift BDS UCA’s 35 inch ridge grapplers AT 20 inch methods with offset 5.29 Nitro Gears ARB rear air locker with dual stage air compressor RC switch panel Both bumpers are RC LED Bumpers (6 pods and lower LED light bar) AMP Research power steps Lower RC Tow hooks B&M Transmission Pan CSF Radiator Radium Duel Catch Can BDS recoil traction bars Helwig adjustable rear sway bar Retrax Power Trax tunnel cover NSV LED front light bar Morimoto XB LED Head lights DOOD Rear smoked LED Tail lights (Amazon) NSLUMA Smoked 3rd brake light (Amazon) Morimoto 4 Banger LED A pillar lights Boostautoparts LED tow mirrors w/ power fold (smoked black) Full 3 inch true duel with XF Flowmaster mufflers custom Vbands Steelworks Longtube Headers RC seat covers OEM Audio plus full sound system duel sub 13 inch Phoenix Automotive In dash screen Stater X remote start system Uniden R8 Radar detector Odyssey Extreme Battery RC Seat Covers RC Rubber Mat Bed Cover Full body color door handles & TRD Grille OEM Magnuson TVS2650 Supercharger
