LED strips for bed lighting?
Discussion in 'Lighting' started by JJ_TNDRA20, Oct 18, 2020.
  1. Apr 5, 2021 at 10:58 AM
    18DCTRD
    18DCTRD New Member
    Dave
    Dracut, MA
    ‘18 DC TRD Off Road
    I tapped into my cargo light circuit for my puddle lights. I tapped the + wire at the drivers side rear door sill, and I grounded them at the drivers front kick panel, there are a bunch of grounds that terminate there, behind that plastic panel.
  2. Apr 6, 2021 at 5:51 AM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
    Question to all that have used the Matt Gecko Bed lighting system. Anyone install the bed lights with a retrax Pro XR tonneau cover. That particular cover has a box that the tonneau rolls up into so I am just wondering how did you install the lights under the rear window.
  3. Apr 6, 2021 at 6:54 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    I'm sure you could just stick the rear light strip under the box for your tonneau cover. It just uses 3m tape so it should stick just fine.
  4. Apr 6, 2021 at 8:33 AM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
    Yeah I just wasn't sure how long the wire was between the two sides
  5. Apr 6, 2021 at 8:59 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    It's longer then necessary, ill post a picture when I get back to my truck. I had to zip tie the slack and it looks like you could go 2"-3" below the rail and still fit.
