LED stop lights blowing fuses, stuck in park
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundraOverlord, Jul 7, 2019.
  1. Jul 7, 2019 at 3:31 PM
    TundraOverlord
    TundraOverlord [OP] New Member
    2017 Gray Tundra CM
    20 inch rims and tyres Antenna Small mods
  2. Jul 7, 2019 at 3:42 PM
    Professional Hand Model
    Hand Protectors
    Try a different brand LED. Technically, you should keep your fuse at 15amps. The problem is your bulbs.
    Try going back to your OEM bulbs to make sure everything works properly and that you haven’t messed something else up before moving/resetting into the new bulbs.
    RitcheyRch, Mr Swervlin and Sas like this.
  3. Jul 7, 2019 at 3:44 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I had the same problem. I had to end up using VLEDs LED stop lights and BAM! Worked just like it should. Look 'em up.
  4. Jul 7, 2019 at 3:45 PM
    Bill_2018_Tundra
    Bill_2018_Tundra New Member
    2018 Tundra Limited Crewmax TRD Off Road
    Line-X Premium AMP Powersteps
    According to the eBay listing, you may see that if you install a "standard" base bulb in a "CK" socket. I searched on this forum and it appears that 2017 might use the CK socket. Below is a copy/paste from the eBay listing you linked to.
    PLEASE NOTE: IF OU PLACE A STANDARD BASE BULB INTO A CK SOCKET, THE BULB WILL LOOK DIM, AND MAY POP THE ASSOCIATED FUSE, AS WELL AS BURN OUT IN A COUPLE OF DAYS SO IT IS NOT RECOMMENDED.
  5. Jul 7, 2019 at 5:09 PM
    TundraOverlord
    2017 Gray Tundra CM
    Thanks Guys. You Tundras are very responsive. I love it.
    I restored the stock bulbs and it worked.no more fuse popping.. The LED was causing the short circuit and the plastic around the contacts was already melting.If I had left it there a couple of days I would have had to replace the whole socket.
    Am now looking for another brand of LEDs.
    Any suggestions? Please send links as well.
  6. Jul 7, 2019 at 5:59 PM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    I'd go with osram LED
  7. Jul 7, 2019 at 6:16 PM
    sstoddard
    sstoddard New Member
    Shawn
    2019 Crewmax Sport
    Alarm/start (Compustar Ft7000,Rf2wl1b 2-way remotes and Drone Mobile) Tailgate inserts NSV Lightbar Tailgate actuator Blacked out decals
    V-Led or superbright led
  8. Jul 7, 2019 at 8:35 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    For 2017, stop/tail/side marker bulb is 3157KX. I'm actually using a different JDM in that application with no problems. If my current LEDs go south, I recommend and will use these...same specs as the JDM and at half the price:
    https://www.amazon.com/dp/B07MYX6Z2...&pd_rd_r=97c1c03c-a130-11e9-aa88-8925cccc9fd1
  9. Jul 8, 2019 at 8:24 PM
    Mr Swervlin
    Mr Swervlin "Yes....In Dee Face"
    O H I O
    2017 Silver Sky limited TRD Crewmax
    Line X bed liner Window tint AVS in channel vent visors Paint protection wrap Husky front & rear floor liner ESP Crewmax rear storage Console organizer and tray TRD shift knob TRD rear sway bar Thule exporter pro 500 Color matched door handles, side mirrors, and grill surround VLEDs interior/reverse/cargo Driver side grab handle 10" BAmuffler Trd pro headlights
    Vleds is the way to go. A little pricey but, outstanding quality.
    RitcheyRch and astro-jason like this.
  10. Jan 15, 2020 at 10:08 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Anyone have a link for Vled? I have a 2019.
  11. Jan 17, 2020 at 1:03 AM
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
  12. Jan 17, 2020 at 5:47 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Been using Profile leds in my brake lights for 1.5 years now in my 18’. Zero issues. 18’ trucks are no longer CK sockets. You probably have the wrong bulb.
  13. Jan 17, 2020 at 6:39 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    VLeDs.com or theretrofitsource.com
    both sites have vehicle fit just pop in your vehicle information and they will give you your options.
    georgiey22 likes this.
  14. Aug 29, 2024 at 10:45 AM
    Exile824
    Exile824 New Member
    2016 Tundra Crewmax
    My tundra has had same problem
    I’m headed out of town with spare fuses just in case.
    Can anyone tell me which fuse and exact location
    Thanks
