Led pod light wiring
Discussion in '1st Gen Tundras (2000-2006)' started by shill2002, Mar 17, 2021.
  1. Mar 17, 2021 at 10:18 PM
    shill2002
    shill2002 [OP] New Member
    Beige 2002 Toyota Tundra
    Toytec alumna series 2.0 shocks Freedom off-road upper control arms Custom retrofits Custom grille 10” rf sub and amp
    Hey all, I’m contemplating getting a move bumper and welding it myself. I found a decent pair of flush mount pod lights and a 30” light bar that I was going to wire independently to a switch I have on my dash. If I spliced in 9006 connectors to the 4 fog lights and ran that to my factory fog light harness would that mess anything up or am I missing something?
  2. Mar 17, 2021 at 11:41 PM
    irishpride114
    irishpride114 New Member
    Travis
    2015 SR5 TRD Double Cab
    Without knowing the amperage. But you will most likely need need a fused relay harness sized for the 4x led lights. This way you can still use the factory fog light switch to turn them off and on and not blow the fuse that would normally power the factory fog lights.
  3. Mar 17, 2021 at 11:44 PM
    shill2002
    Each light is about 42w so about 14 amps total for the 4 lights
  4. Mar 18, 2021 at 9:34 AM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    Youll want to use a relay and a harness.
    For rough reference on what AWG wire can handle.
    NewImprovedRon likes this.
  5. Mar 18, 2021 at 9:39 AM
    irishpride114
    Travis
    Agreed. Pretty simple to do as well.
